Page 694 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,192
3,343
Anyways anyone having area value for 4C Skymont+L2 ?
Can't really figure out the 4C+L2 size from that figure. The compute tile has other stuff such as the interconnect necessary to connect to other tiles. It has EMIB too, so that takes a bit. If it needs a router, it'll take little bit more too.
55mm2 for 24 cores on 18A is ok considering.
mzocyteae
26
19
It used to be doubling the stages got you 80%+ gains. How is it worth now? Unified Core should aim for at maximum low-5GHz.
As for FP, it should stay 256-bit for client. 512-bit is a waste, and was a mistake to do it with AVX-512. It should have been AVX3-256.
It is Intel's (political) stubbornness to not implement avx512 in client cores. AMD already proved that avx512 can be implemented with 256 datapath and gets reasonable throughput gains.
If you ever touched simd codes, you won't spam "AVX3-256" bullshit. Most (all?) avx512 instructions have xmm/ymm counterparts.
IMO neither intel nor arm did it correct.
SIMD should be designed with both fixed-size vector width and predicate registers.
Reactions: Gideon
511
5,539
4,931
I meant for Arrow Lake 4C+L2 on N3B
This confirms the die has empty area to facilitate EMIB+Mesh+TSV
Reactions: Elfear
DavidC1
2,192
3,343
If cluster size is similar to Skymont, and doesn't have more L2 cache, then it means 18A is similar to N3B in size.
DavidC1
2,192
3,343
And what's the BS? That 512-bit FPUs are overkill for CPUs in this day and age?
AVX3-256 means ALL AVX-512 instructions should be kept, without needing 512-bit registers and FPU.
AMD cores are also very far away from being the most efficient design so it very much applies. Go look at many of Intel's older presentations. 512-bit was solely to stave off Nvidia's advance in HPC, note the first AVX512 product was supposed to be Xeon Phi. And they paid for it with decreased clocks and fragmented ISAs. Something they could have avoided if they focused on GPUs way earlier and stayed on a far sane 256-bit FPU.
ARM vendors and Skymont does a far better approach of adding more FPUs. It straight up benefits everything without putting the burden on users and programmers.
adroc_thurston
8,687
11,413
Lmao no, 2 FMAs is the maximum anything real SIMD code would saturate.
It literally puts the burden directly on the SIMD slave. You need to juggle more math to saturate moar FMA units.
Man, you really never ever heard SIMD people ranting?
Reactions: lightmanek
mzocyteae
26
19
Lmao, do you understand what is ISA?
And you can't even understand this: :p
avx512 requires much less effort to programming than avx256.
The only (albeit big) problem is ISA fragmentation caused by Intel's silly decision to not implement avx512 in client cores.
OneEng2
1,013
1,212
Which is what has been the general consensus among speculations with the information available to date.
It looks to me like AMD intends to complete with these chips from N3P in desktop and laptop while in server, N2 will be used.
... which again brings me back to the financial implications of Intel using a more expensive process and more expensive equipment. Of course some of this cost is mitigated by Intel not having to pay for TSMCs profit.
I wonder if CWF has AVX512 and SMT? Hard to see how it can compete in DC and HPC without them.
511
5,539
4,931
Yes we all have been Saying N3 Density and Slightly better performance than N3P but bit less than N2 and danniel nenni confirms it
From where do you get the expensive equipment both use almost the same equipment there is no dual sourcing in many of the critical things in semi manufacturing. intel sells one such equipment masks which Intels subsidiary produces so they can charge TSMC more for it lol.
How do you rate one process more expensive than other without proof and you simply said the most important point doesn't matter the foundry you know that if foundry has 30% margin on 18A and product another 30% that is roughly 70% margin on a chip vs AMDs which would not be that much
Also Zen 6 is not arriving before 2H26 at the earliest so it has like 1 year of reign
First thing it is not a HPC Chip it would loose to 5C in AVX-512 but that's about it does it states anywhere SMT is necessary it is entirely dependent on the people who buy it how much they feature Security SMT is not necessary. AVX-512 might be which might be mitigated by AVX10/256 somewhat
Reactions: ajsdkflsdjfio
OneEng2
1,013
1,212
First thing it is not a HPC Chip it would loose to 5C in AVX-512 but that's about it does it states anywhere SMT is necessary it is entirely dependent on the people who buy it how much they feature Security SMT is not necessary make or break AVX-512 might be
Your last sentence is a bit confusing, can you clarify?
Intel originally purchased 5000 series ASML machines (high NA) which for 18A. Now, Intel intends to wring out the high NA machines in 2025, but not use them for production.
GAA and BSPD both cause more passes of process steps over FinFET and FSPD do. This makes the process more expensive. Intel also produces fewer chips on their high end equipment than does TSMC which makes the amortization costs higher for Intel. Furthermore, without High NA, Intel will have to rely on double patterning which will also raise costs. Throughout 2025, Intel will be producing only CWF chips on 18A as I understand it. This is a pretty low volume chip compared to desktop and laptop markets.
AMD using N3P for the high volume desktop and laptop segments significantly reduces their cost over Intel's use of N3B today (N3B also has more passes as I understand it than N3E, N3P and N3X) and (my guess) Intel's own 18A process.
It seems like Intel is willing to throw money at their chips to keep them competitive while AMD manages to maintain competitive products at much lower production costs on less expensive process nodes.
cannedlake240
247
138
18A production fab won't be online until 2H 25, where it'll make PTL, CLF and external foundry chips. And CLF isn't very low volume, each one has 660mm2 of 18A silicon.
511
5,539
4,931
I meant that SMT is not a break or make feature as some people will turn it off some may not also for AVX-512 CLW-F support AVX10/256 so it gets everything AVX-512 has just with 256 bit data path
That is a gamble will it pay or not only time will tell
Both TSMC/Intel will use multi patterning at N2/18A but BSPDN allows Intel to relax pitches a but increases complexity as for how expensive it is only Intel/TSMC know the cost
N3P products(Zen6) won't be launching before 2H26 as for cost of 18A N3B/N3P you are assuming this on the basis of Intel 7 cost structure also N3B and N3P price difference won't be significant both are N3 family.
we will know more details by IEDM 24 in December so hold your horses before making conclusion 🙂
This is true rn but how true it will be next year oncw it ramps the process
