Page 692 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
RTX
187
132
N2P and A16 arrive within the same time frame according to TSMC.
"The roadmap you see here is pretty much the same, actually it is the same technology roadmap that I think you saw during the [technology] symposium six months ago," said Dan Kochpatcharin, Head of Design Infrastructure Management at TSMC. "[…] We have N2, N2P, which is coming [to] productions next year and the year after. And then [they are] followed by A16."
Sounds like A16 arrives after N2P.
Hitman928
6,755
12,503
Keep reading. . .
I asked TSMC's heads of the PR department to clarify. Indeed, all of these process technologies are slated to be ready for high volume manufacturing (HVM) in late 2026.
Doug S
3,858
6,822
N2P and A16 are released at the same time, or at least close enough in time that TSMC's roadmap shows them hitting mass production in H2 2026. All evidence is that A16 is identical to N2P except for the addition of BSPDN. That's just a minor variation on TSMC's original stated plans which had them release N2, then six months later follow it up with a version of N2 that added BSPDN.
I'm still operating under the belief that TSMC is working to get "back on schedule" for Apple's needs, like they were until their N3 problems caused them to go off the rails a bit.
Panino Manino
1,156
1,402
Bringing this video here for now particular reason, other than it talks about Intel and that I don't remember even seeing this channel being mentioned here.
Hulk
4,144
The US government will bail out Intel if need be. It's simple. A guaranteed supply of wafers is requied for defense and other mission critical applications. At the end of the day it doesn't matter if these chips are produced on an old node. As we all know, NASA was using 20 year old nodes to mitigate the effects of radiation exposure to space bound CPU's and most of them are still operational.
Reactions: OneEng2
Hulk
4,144
Okay, but is a leading-edge foundry producing consumer or even enterprise products necessary to fulfill that purpose?
I don't know and that is a good question. What other US based and owned foundries are available and what how do they compare to Intel in terms of process technology and capacity?
511
5,537
4,931
Answer is simple No one besides Intel not even in the US in the entire West no one outside Intel can do advanced logic and Micron for Memory
maddie
5,204
5,616
Does GloFlo not exist? They aren't on the cutting edge but quite adequate for defense. Things like background radioactivity, increased in (God forbid) an ultimate war, plus electromagnetic pulse effects have to be assumed. Smaller nodes are more susceptible.
Reactions: Thunder 57
511
5,537
4,931
We need analog as well and we have TI for that Global Foundries can't even make anything below 14nm which is sufficient for most unless you require custom silicon on advanced logic do you have any other option for that also Intel has Intel 16 as well 🙂 they already signed Mediatek as a customer for that and it is based on tried and tested the exalted "14nm" do you think any process is as mature as Intel 14nm ?
If you are bringing EM Pulse/ radioactivity you to have design and fab considering it regardless of node features process are designed with this in mind
19,219
Resharing Google Lens translation of a slide posted by Flametail:
I think 258V could've won this test in battery life per watt hour too if two of the Lion Cove cores had been replaced by Skymont ones.
DrMrLordX
23,232
13,321
GlobalFoundries does exist, and they do work with the DoD:
Meteor Late
347
382
Until they increase the IPC of E cores by another 20% to 30%, there’s no replacing the P cores.
Totally! Intel should get rid of Skymonts asap.
I mean, Geekerwan showed how Skymont is much less efficient than Lion Cove at the upper end of the curve at the same performance. Same trend shown by Oryon M vs Oryon P.
So it's not as easy as just increasing another 30% IPC for E cores and replacing P cores. Battery life will be worse unless you worsen the user experience a lot when on battery by heavily downclocking max clock speed even in lightly threaded workloads.
What I could see, though, is reducing the number of P cores, at least on Laptops, 2 could suffice tbh if E cores are really good.
LightningZ71
2,709
3,417
The 2+8 ADL p and u chips do just fine in most general use cases. 2 P cores is plenty for web browsing and light usage. It's not amazing, but, having used them for work, it's not hampering me in any way.
Reactions: SiliconFly
coercitiv
7,506
17,944
Falling behind at high perf levels is normal, as currently they are built with a different performance target in mind (both core layout and cache structure are aimed at PPA). You can think of this as the reverse of what happened to Zen and Zen C, when optimized for PPA the Zen core loses efficiency at high clocks (and clocks lower too). So in theory, if you wanted to make a P core out of Skymont, you would optimize the layout to ensure better voltage scaling at 4-5Ghz and give it access to proper L2/L3. The core would be bigger, use a bit more power at lower perf levels, but would scale much better at high clocks.
I think folks in the forum should talk less about replacing P cores with E cores, and more about replacing Cove with Mont (arch families). P and E are roles, and they can even be played by the same arch with some tweaks (as shown by AMD). A real world product based on the pedigree of the Mont cores would benefit from a properly planned architecture, they would have this target in mind as they plan the core. Ideally we would want a core close in size to the latest Coves, but with performance to justify the area.
