Page 922 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
poke01
4,903
6,246
I know, but can you game with it below 10W? In those few games which Notebookcheck tested it use significant more power to game compare to LNL.
M5 offers around the same perf in CB2077 as Lunar in 1080P Ultra testing and the power consumption at the wall is the same or a bit lower than Lunar(depends on the laptop model)
not sure where you got significantly more power hungry from.
Reactions: controlflow and 511
511
5,534
4,925
No guarantee unified core will be all that great either tbh. Esp in perf, even if we see a large uplift for Intel in perf/mm2 and perf/watt.
It will be cause actual competent people are leading this time I trust Stephen Robinson cause they made a core worth giving a damm with better branch prediction than
I don't think skymont is the best core in it's area class either. And perf/area is by far Skymont's best attribute.
Tbh it is if given proper cache not cache starved it's like 1.1mm2 Core+L1 don't forget that on N3B it clocks like 4.6Ghz easily and on refresh it's going at 4.8 GHz
Link please.
N3 is N3B here
Reactions: OneEng2
hemedans
309
178
Different laptop shows different results, some LNL laptop use as low as 27W while giving almost same perfomance as Macbook pro m5,
Thinkpad T14 gen 6
For comparison Macbook M5 use 43W same game. Apart from that lenovo there are number of laptops which use 30ish watts play that game at ultra settings.
Am not sure what cause that difference but my guess is scheduler, you get less power consumption by using Skymont over LC.
poke01
4,903
6,246
Thinkpad T14 gen 6
Ahh that’s using the Thinkpads internal screen which is 1200P and LED which is less power consumption than the 120hz mini-led
If we check with the external monitor it’s the same
OneEng2
1,013
1,212
N3 is N3B here
I was mistaken. Thanks.
Reactions: 511
hemedans
309
178
That doesn't make sense, even if display is efficient it shouldnt use more power with external display unless scheduler detect external display and assume it's on table with adapter connected hence it run at full power.
There are plenty of other LNL design which use less than 40W while using external display.
Reactions: poke01
poke01
4,903
6,246
yep in which case fps is lower. to maintain a near 30fps in fhd ultra, LNL must use around 40watts when using an external monitor
Reactions: hemedans
Geddagod
1,683
1,720
I don't think the E-cores rn are all that great in comparison to ARM stuff either.
It's not gonna be uncore/cache starved in comparisons to mobile CPUs.
The mediatek 9400 X4 looks like an outright better core in the same area class. It might be close in perf and area but should get dog walked in power.
Reactions: CouncilorIrissa
511
5,534
4,925
Yup nope it is it might not be better than the Cortex X series but it is damm good vs A720/A725 FWIW it's 4MB L2+8MB SLC vs 512KL2+16MB L3 and that is it's area class
caches have to be fast not as poor and botched as ARL's L3 85Cycles is very bad and on mobile i think it's even worse than that
DavidC1
2,192
3,343
That's how behind x86 cores are. Saying a particular x86 core is good is only relative to other x86 cores. Compared to ARM.... long, long way to go.
The cores are partly hampered power-wise by the Intel/AMD's inability to get their uncore power low. It's a skill issue not ISA. Although in the big picture you could say they are related as the perception that x86 sucks can propagate into the minds of the engineers, moving smartest, brightest and hardest working to the ARM camp.
DavidC1
2,192
3,343
Yeah it's hilarious, isn't it? everyone else is getting more clock speed along with IPC increases, whether they are smaller or larger, but somehow it is acceptable for Intel to be able to maintain clock speed and not increase it.
Based on what evidence? Using ARM parts?
511
5,534
4,925
Money is the biggest factor in this
ARM Cores do the stuff of cleaning out their ISA which simplifies the design and Validation ARM will get the same bloat if they have to support stuff for years. I disagree on PPA when AMD is on a node behind in ARM Camp their IPC is surely lower than ARM but they have beefy SIMD Units let's wait for N2 to drop next year for reality check of the Core PPA cause we would have sorted out the node variable​
poke01
4,903
6,246
it will be same as now. AMD will be lead SIMD by a significant amount, Intel will be a bit slower than AMD, Apple will hold the INT/FP crown for mobile.
These things don’t change as rapidly unless either one these implements a clean sheet design.
511
5,534
4,925
i expect Intel close in SIMD Performance with Coyote/Panther vs Zen6 as for ST Perf maybe desktop Zen 6 can match Apple but at higher power ofc
Oryon is the newest clean sheet design followed by Zen Intel's P/E Designs are dated tbh they need to start new but thanks to cancellation of Royal it will have to wait till UC and Apple's i forgot tbh i think they made a clean sheet design when they moved to 64 bit
Geddagod
1,683
1,720
A N3 A725 with 512KB pL2 is smaller than a Skymont core... without considering the shared L2 cache.
It's way smaller.
How much difference does this really make when we also account for capacity? LNL LNC trades of 30 cycles of latency but is only 12MB, yet has the ~same IPC as LNC ARL. An E-core is both slower and also have more L2 to help as well. It doesn't change the comparison much.
Things are so bad that one can compare the geekerwan smartphone core+cache power (should be a large overestimate) vs the AMD/Intel modeled core+cache power and still have ARM either leading or at worst, on par, in perf/watt.
Even iso node (X4).
It's not a good look iso node either
Well, I already claimed that Skymont doesn't look great compared to the X4 on 2-1 cells in the Mediatek 9400. Using that as a baseline...
You can remove the entire FPU block on Zen 5C, and the L2, and you would still get a core larger than Skymont. I'm extremely doubtful that it performs as well as Skymont either. Prob will have decentish power though, unlike Skymont.
regen1
365
456
But Unified Core isn't a complete clean-sheet design, is it ?. They are going to iterate and bring new ideas to works from both(P and E) sides(but perhaps mainly from E-core side). Even from an E-core PoV they have been iterating with large Performance gains every ~2(to 3) years.
Royal Cores was a clean-sheet design but the risk with clean-sheet designs is sometimes they might not tick all the necessary boxes(and Royal Cores didn't). If not cancelled we could have got a teaser(limited test vehicle release) in 2026 alongside NVL but full family(notebook/server/desktop) was targeted only around 2028 H2+ which is kinda similar or getting close to Unified Core timeline(Unified core seems to slip to 2029).
511
5,534
4,925
LNC L3 is 55 Cycles not 30 also LNL Skymont don't have ring it only has SLC ..
Reactions: Joe NYC
Geddagod
1,683
1,720
Yea sorry I meant 30 fewer cycles
Yeah and LNL skymont is mid.
I'm talking about LNL LNC. If LNL LNC has the same IPC as ARL LNC, then I don't think it's a stretch to claim that Skymont on LNL's ring is going to be all that different than Skymont on ARL. Skymont is both less performant and has a larger L2 to compensate for a slow L3 compared to LNC.
Meaning that ARL's terrible L3 latency isn't really holding Skymont back all that much in comparison to mobile SOCs, since LNL on ring isn't all that different than mobile SOCs either, at least the mediatek 9400.
Seems like it, and this is the problem.
If current E-cores aren't PPA competitive with ARM...
and unified core is supposed to be based on E-cores....
What makes people think that Unified Core can get back to stock ARM levels of PPA?
Hopefully it does, but I'm not holding my breath on it.
Covfefe
123
229
I'm not about to argue that Unified Core is necessarily going to match ARM PPA, but Skymont compares pretty decently against the ARM A725.
The screenshot that 511 shared was Skymont in Lunar Lake, which doesn't have L3. Skymont in Arrow Lake scores higher. In David Huang's SPECint2017 chart it's 40% faster than the GB10 A725. Skymont without L2 is roughly 35% bigger than the A720 without L2 (I couldn't fine any A725 die area estimates).
Reactions: hemedans and DKR
511
5,534
4,925
I did some and A725 is roughly 0.84mm2 without L2 and 1.15mm2 with L2 in Xiaomi Oring1 on N3E Skymont is rougly 1.09mm2 N3B and Darkmont is 0.94mm2 18A.
Skymont used for E cores in ARL is same as in same phys design if i am not wrong have to check but LNC in LNL vs LNC in ARL is a different Physical design.
Reactions: DKR
Geddagod
1,683
1,720
Totally different weight class
So skymont is ~30% larger...
There are slight power delivery differences between the two, it's nothing major.
regen1
365
456
I am hopeful of what Unified Core brings but it's too far away and too little known at this stage plus what's the competitive landscape in 2029 ?
It may not be a complete clean-sheet design but they have been able to bring relatively big improvements on a shorter period.
As for ARM A720/725, Skymont is fairly competitive considering it additionally has a frequency advantage but I get it their design objectives might be different in some or more aspects.
*51 cycles for L3 (LNC in Lunar Lake config). Sorry for nitpicking :p
Reactions: 511
