Page 693 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
mzocyteae
26
19
The 2+8 ADL p and u chips do just fine in most general use cases. 2 P cores is plenty for web browsing and light usage. It's not amazing, but, having used them for work, it's not hampering me in any way.
Browsers have lots of threads/processes and workloads are irregular.
2P and 0P will make little or no difference, unless there is some steady workload (usually js + webgl, but then 2P is probably insufficient).
mzocyteae
26
19
Falling behind at high perf levels is normal, as currently they are built with a different performance target in mind (both core layout and cache structure are aimed at PPA). You can think of this as the reverse of what happened to Zen and Zen C, when optimized for PPA the Zen core loses efficiency at high clocks (and clocks lower too). So in theory, if you wanted to make a P core out of Skymont, you would optimize the layout to ensure better voltage scaling at 4-5Ghz and give it access to proper L2/L3. The core would be bigger, use a bit more power at lower perf levels, but would scale much better at high clocks.
I think folks in the forum should talk less about replacing P cores with E cores, and more about replacing Cove with Mont (arch families). P and E are roles, and they can even be played by the same arch with some tweaks (as shown by AMD). A real world product based on the pedigree of the Mont cores would benefit from a properly planned architecture, they would have this target in mind as they plan the core. Ideally we would want a core close in size to the latest Coves, but with performance to justify the area.
Coves aren't that big -- any core will be similarly big with a big cache (under similar process/library).
Maybe Intel should consider Telum 2's shared L2/3 approach (plus vertical cache), which looks pretty good on numbers.
LightningZ71
2,709
3,417
While the numbers are empirically measured, you aren't necessarily comparing apples to apples. The Lion Cove cores, as implemented in Alder Lake, have different frequency targets, and as such, have more transistors added to help with getting there. In addition, they have more blank space between transistors on critical paths to assist with speed as well.
A more accurate comparison would be to compare the number of core logic transistors that it takes for each one to function. Unfortunately, Intel no longer releases those numbers. I suspect that, were one to add the needed transistors for frequency scaling to the mint cores and also intentionally added buffer space to critical paths, they would find that the size comparison is much closer. Also, keep in mind, Lion Cove is carrying unused functional blocks for SMT and AVX-512 as the core will be reused in servers.
mzocyteae
26
19
From what I gather, (without L2, L3, etc.), the sizes of the core (with just L1) are:
  • Lion Cove - 3.4 mm2
  • Skymont - 1.15 mm2
The size ratio of Skymont to Lion Cove is 1 : 3 which is massive! A Lion Cove is like 3X bigger than a Skymont!
This is what you wrote:
Actually, coves are big. They're super big compared to M3, Skymont, Zen 5, Zen 5C, etc.
M3 is around 2.5m^2, 1.36x is normally not in the range of "super big".
Skymont doesn't reach the performance level of Lion Cove, so the comparison is moot.
Reactions: SiliconFly
LightningZ71
2,709
3,417
It's not.
Woah... I thought the "dirty little secret" with Lion Cove was that they have a full SMT implementation in the cores as lithographed in Lunar and Arrow Lake CPU CCDs and that it wasn't enabled because they validation wasn't possible to complete by their ship to market deadlines. It's been discussed on the forum several times... I thought I read the same for AVX-512 being in the core, but not enabled on client.
511
5,537
4,931
Someone needs to do an autopsy on ARL Silicon to verify it btw if it had HT and AVX-512 and it was disabled in silicon it would have been plus points that would might justify this area
DavidC1
2,192
3,343
Yes, but it doesn't take 3x the size for the mediocre gains over Skymont. Some tests show even gaming performs better with most of Lion Cove cores off.
And a more straightforward comparison is against AMD. Less dense process but the chip clocks just as high, supports SMT, and is slightly faster, while being a smaller core too.
LightningZ71
2,709
3,417
I'm just discussing the approach differences between Skymont and Lion Cove. One is aimed for higher clocks, particularly sustained higher clocks, and that takes more transistors and effective density sacrifices. I'm not saying that Lion is particularly area efficient in and of itself, just that it does have different targets and, to my personal understanding, transistors present for unexposed features.
The actual functional transistor count difference between the two is not as great as implementation area makes it seem.
GTracing
478
1,114
The thing is it's not hard to increase clocks. That'll be the easiest thing to change if the mont lineage takes over as the p-core. Intel also needs to greatly widen the FPU and add AVX10, improve the L3 cache latency, and get another 30%+ int ipc (which they've been doing every two years, but it's not guaranteed that they can keep up the pace).
But I wouldn't be surprised to see Intel go wider and slower like the arm cores anyways.
DavidC1
2,192
3,343
It takes heroic effort beyond the 5GHz frequency range.
Proof? 9 stage CPU clocks at 4.5GHz while a 19 stage one does 5.7GHz.
All the while:
-The lower clocked chip performs better in absolute performance
-It uses multiples of power to reach those clocks
-Cores are much larger
-Sucks for mobile and server, while being mediocre even for desktops
Nevermind chips like Raptorlake.
It used to be doubling the stages got you 80%+ gains. How is it worth now? Unified Core should aim for at maximum low-5GHz.
As for FP, it should stay 256-bit for client. 512-bit is a waste, and was a mistake to do it with AVX-512. It should have been AVX3-256.
