Page 685 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ajsdkflsdjfio
185
133
I might be wrong, but this doesn't sound right at all.
We know part of it is Intel's P core being bad, but if you look at Granite Rapids vs Turin, GNR loses badly in all metrics and has a much lower base frequency. Not all of the difference is architectural imho. At "not 5GHz+" frequencies Intel 3 seems to be inferior to TSMC N4 in many metrics.
Yea isn't it the case that in power constrained scenarios, intel's poorly optimized core design may perform worse regardless of node? You see this same thing in Lion cove where "magically" N3B seems to be inferior to TSMC N4 in many metrics. Ofc arrow lake performance problems are from a myriad of differing issues not just lion cove, but lion cove is still obviously part of the issue of performance stagnation. If lion cove on n3 fails to perform vs zen 5 on n4, why would redwood cove perform any better vs n4 in a server application where power efficiency is paramount when redwood cove is basically a node-shrink of golden-cove from intel 12th generation?
Reactions: DavidC1
511
5,545
4,943
Yes, best performance for like 6 months and then their CPUs would've started degrading...
You know that debacle was a design issue not a process issue the oxidation was mishandling of batches at a fab well TSMC node can't even clock high as intel nodes they would die at way less voltage than Intel's 🤪
511
5,545
4,943
We have Sierra Forest on Intel 3 process that can do 144 Cores 2.7-3Ghz all core at 250W!
19,219
If it simply were an issue with a small number of batches, Intel could've simply recalled the affected CPUs. They went through multiple (more than 3) microcode updates trying to fix whatever issue there was. If I had a grandma who hid her cash under her mattress, I would steal some and buy a 14900KS to test for science and see how well it hits 6.2 GHz with constant workloads and everyday usage for six months. But the general consensus now is not to trust Raptor Bake and Raptor Re-bake :p
coercitiv
7,508
17,949
And you think that makes it better?! Mishandling of batches is hardly reassuring for a potential customer.
Zen 5 on Intel nodes would have been great on paper, then would have gotten delayed like all the Intel products on Intel nodes have been for the last couple of years. More performance but zero market relevance.
19,219
AMD engineers probably don't want to work so closely with Intel Foundry personnel anyway coz leaking of their trade secrets to Intel Design Centers would come into the picture sooner or later. Intel Foundry needs to become US National Foundry before AMD will risk doing business with them.
Reactions: 511
511
5,545
4,943
I am just talking about theoretical performance.
Delays and intel had been amazing combo for the last few years I can't deny that 🤣
511
5,545
4,943
You should hope so & you can always admit anytime. I'm assuming this so called Bartlett lake is a cpu based on the already outdated RPL on Intel 7, right? If so, then it is going to inherit all the issues related to RPL. And frankly, why on earth would anyone root for such an outdated product like Bartlett Lake which imho shouldn't even exist? An Intel 7 based cpu in 2025? Yikes!
It's a 12 core monolithic CPU
RTX
187
132
Now of course through publicly available TSMC and Intel density figures you would assume this difference would be much larger, but I believe that the on-paper difference between the density of Intel 4/3 nodes and TSMC N3E are largely due to TSMC offering an actually high density library using a 2-1 fin arrangement which is around 32% more dense than their HP high performance library, while Intel 3's "HD" library is only 10% denser than their HP library leading me to believe it isn't prioritizing density as much as TSMC's 2-1 fin=flex offering. Intel markets using their high density(not really) library densities, while TSMC markets their 2-1 fin or even 1-1 true high-density libraries as the face of N3 achieved densities. Either way in reality it is shown that at-least in client computing chip design, TSMC's N3 designs are not all that much denser than intel 4/3 designs especially if you are comparing N3E or N3P versus intel's nodes with only a 10% or less gap (at least in cache density) between intel 4 and N3E/N3P.
Chip density for intel 3 is up to 1.08x vs intel 4 and logic density is up by ~15%. Their 2-fin should've been -2xfin pitch ( 180nm ) instead of -1xfin pitch ( 210nm ). The additional 10% ppw from intel 3-PT should be enough to allow them to do 180nm 2-fin and still gain ppw vs intel 3 210nm.
Reactions: SiliconFly
LightningZ71
2,712
3,421
they'll probably relax the density metrics on Intel 7 one more time, just like they did from Alder Lake to Raptor Lake, then Raptor Lake to Raptor Lake Refresh...
511
5,545
4,943
Nope Intel 7 is done for as a node in terms of development there is nothing new to add
DrMrLordX
23,232
13,323
More likely they identify the structure that was burning out due to the old voltage spike behavior and change it (if possible) to handle higher voltages so they can go back to the original TVB.
511
5,545
4,943
The 12 core die is a new die altogether and it is for networking group so they should pay attention
OneEng2
1,014
1,212
Yeah they did.
No they didn't.
No they didn't.
Best xtor performance.
N3e did not exist when the decision was made.
Ok, so let me get this straight ......
Intel decided INTENTIONALLY to abandon their own fabs, pay MORE to have their core processor tile produced at TSMC, and ALSO decided to spend billions of dollars to continue making their own 20A, 18A and 16A processes as well ...... all culminating into the biggest losses in the companies history?
... and they did this by design?
Please explain this logic to me.
OneEng2
1,014
1,212
It's an RPL REFRESH REFRESH so if the process can handle it, it should theoretically launch with 6 GHz boosts and 6.2 GHz for the halo part.
My guess is that Intel is done pushing the process and design through the red and into failure modes..... but then I have seen some pretty crazy decisions before.
moinmoin
5,248
8,463
Swan's decision.
Pat's decision.
Contracts were already signed. Both Swan and Pat were and are in the position of having to try the best given a bad hand while trying to reach completely different destinations.
DavidC1
2,192
3,343
I'd say density wise intel 3 is already comparable to N3.
Redwood cove on intel 4: 5.33 mm^2 (5.33 on semianalysis 5.05 according to reddit post i used for lunar lake) Lion cove from lunar lake on N3B: 4.53
Lion cove has 2.5 mb of l2 cache per core while redwood cove has 2mb. which is a 25 percent increase of 1.25x. Multiply the cache area for Redwood cove by 1.25x to get the theoretical area for 2.5mb l2 cache on intel 4: 1.215 mm^2.
That's cause your analysis is flawed. SRAM scaling is reaching a hard limit, similar to DRAM running into a limit like ten years ago. Also, Lion Cove expanded significantly, hence why it's 4.5mm2. If it was a straight shrink it's probably in the 3.xmm2 range.
Logic scaling shows TSMC has a substantial advantage.
The P cores are terrible. It requires more power and die area for less performance than the competition.
What you are saying is basically Intel's 65nm process sucked because of Presler. Yet we also had Conroe/Merom, a far superior chip.
Some is likely due to process but mostly it's architecture and implementation. Implementation, in that they're still learning to get the disaggregated thing right, and GNR itself had troubled development, based on how the scaling sucks with just 2P.
DavidC1
2,192
3,343
There is a documentary about Centaur called Rise of the Centaur which was somewhat informative and entertaining. But since then Henry retired and the team was sold to Intel and the IP licensed to Zhaoxin.
I guess they were in the same city as the Intel 'mont team at the time too?
It seems Stephen Robinson, the leader of the E core team came little before the purchase. I'm pretty sure it's not a coincidence.
The Centaur team was said to achieve what they did with fraction of the human and financial resources of a typical MPU team. Certainly they can do good when they need to.
In 1995, Centaur Technology set out to prove that a small team of microprocessor engineers could design an affordable x86 processor for the neglected sub-$1000 PC market. At the time, it was a visionary idea. Now, fourteen years later, Centaur has successfully designed the world's smallest x86 processors, has shipped thirteen different parts, and consistently provides the fastest design cycle in the industry-from concept to completion in about 9 months, 1/3 the time of our competitors. Centaur’s relationship with parent company VIA Technologies, the #2 chipset maker in the world after Intel, has positioned us to be the dominant force in bringing PC power to developing nations. New challenges are just ahead for Centaur Technology’s visionary solutions.
ajsdkflsdjfio
185
133
Yea never mind you are right about the SRAM scaling, I looked it up and N3B and N5 and intel4/3 have similar SRAM cell sizes. Still I think intel 4/3 is more impressive than at first glance even though it hasn't really been proved in any real application yet since meteor lake was basically a test platform for all their new technologies. Hopefully panther lake turns out well, it'll be perfect for comparisons between N3 lioncove/skymont vs 18A cougarcove/darkmont. It'll also be the first time that a (hopefully) decent product is released on an intel node other than intel 7.
DavidC1
2,192
3,343
If you compare the smallest sizes, N3B has a 20% advantage over Intel 4. Which is roughly same as the numbers you calculated.
I'm not sure why anyone is surprised at Intel processes being a performance leader and density laggard. It has always been the case. It has to do with the mentality and vision of that team.
That's why even Intel themselves admit 18A isn't a perfect fit for mobile. I think perf wise even Intel 3 will be very close to N2, but density wise it'll only take maybe N3 to match 18A.
Reactions: ajsdkflsdjfio
OneEng2
1,014
1,212
Swan's decision.
Pat's decision.
So you are saying that Arrow Lake, Lunar Lake were both originally targeting using TSMC? That is not at all what I had heard. Do you have a link? Every resource I can find states that Intel originally targeted 20A for these processors and had to go to TSMC OR wait until 18A was ready. The rest is history.
If you are correct, that isn't a great strategy IMO. In a server environment, the limiting factor doesn't end up being die size since you can conceivably put as many tiles/CCD's on an SOC as you want and cost is largely not relevant.... but socket power is. Thermal issues and power issues would limit such a design.
In desktop, this is also a losing strategy for a different reason. Die size (cost) is suddenly VERY important. With die size pricing increasing super-linearly (exponentially?) a strategy that doesn't compete in density is a loser IMO.
I do tend to agree with you though that Intel has been targeting max performance from every point of design. At some points in history, they did this to such an extreme that it was comical. I recall joking about what a great space heater P4 was :).
