Page 612 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Goop_reformed
316
341
I meant properly. We've had cases when reviewers thought some security features were disabled but were in fact still active. What we think about security and the recommended settings is another issue.
Have a feeling this is just gonna be stability, not performance issues
MS_AT
937
1,856
We have reports that disabling VBS improves memory latency, people expect we'll see big swings in performance from one review to another, based on wheter security features are (properly) disabled or left enabled to emulate the casual user experience.
By reports do you mean people have confirmed in the past that VBS makes the mem latency worse, or do you mean this one guy who got Arrow Lake ahead of release?
Joe NYC
4,216
5,824
Hmmm. Last time I checked, tiles are chiplets. Also, I thought Zen 6 was using silicon bridges, not an interposer?
According to some rumors, it will more likely use the same fanout packaging as Navi31 / 32. Which may also be used in Strix Halo.
We will see if Strix Halo achieves some improvement in latency vs. desktop Zen 5. Except, using LPDDR5, which has higher latency, is going to make it more difficult to get apples to apples comparison.
But, the fanout packaging should have similar latency as Foveros in Arrow Lake.
511
5,454
4,879
Zen 6 is N3P though by TSMC Timeline and 18A is for Nova Lake DMR with Coyote/Panther Cove
coercitiv
7,485
17,891
I meant the one guy, obviously nothing is certain until we get the first wave of reviews out, and it's not worth investigating if the report is real when more trustworthy data is just around the corner.
Hulk
4,110
As for review quality, I would much prefer quality of quantity.
For example, instead of 35 benchmarks that include no specifications as to how they were performed and operating parameters, provide 10 or 12 fully documented benches showing at least average power during the benchmark run and average frequency during the run. Other details like Vcore would be nice as well. Also please include all important bios settings used for testing.
Unfortunately we generally only get those types of benches when WE perform them and report back here.
cebri1
373
405
Phoronix is the one to look for.
19,218
Remind me again, please? What was the final concenus regarding Lunar Lake? Total fail? Amazing? Good battery life/ST performance, not so good MT performance? Where Intel's performance/efficiency claims substantiated by reviews?
I just want to know where we are before we dive into ARL.
My takeaway from reading the reviews is that it's way more preferable to MTL-H. Can't wait to see 258V laptops at least get to the $500 mark (they usually do for certain brands like Lenovo and sometimes even HP). But right now, they seem to be priced $150 more than Ryzen AI laptops which are themselves overpriced to begin with.
Hitman928
6,754
12,500
Not entirely. Tiles are not like AMD chiplets. Conversely, AMD chiplets can't be called Tiles either.
Tiles are an advanced from of chiplet design compared to older chiplet design AMD uses. AMD chiplets are hardwired on substrate. Intel Tiles sit on interposer that sits on top of substrate.
AMD is expected to switch to Intel's advanced Tile like chiplet configuration with Zen 6.
You could call AMD's approach tiles and Intel's approach chiplets, there's no technical distinction that causes the different naming. AMD was first and called its approach chiplets. Intel followed and didn't want to be seen as copying AMD, so they called their approach tiles, that's it.
Josh128
1,542
2,295
Watch out for David Huangs and Chips N Cheese's articles. Those are the most technical reviewers on the net.
dullard
26,196
4,868
Again with this. Intel was first (Pentium D), AMD and the internet called intel's Pentium D chips glued together. Years later AMD comes out with chiplets\tiles and Intel jokes back that they are glued together referring back to AMD's swipe at Intel. Suddenly everyone in all forums says AMD was first with chiplets\tiles. AMD was first with a good implementation. But that doesn't make AMD first.
cebri1
373
405
The game power consumption of Ultra 9 285K is significantly reduced compared with the previous generation. The average power consumption of the 7 games is only 76W, which is less than half of the i9-14900KS, and even lower than the 8-core Ryzen 7 9700X
At least power consumption is now at reasonable levels.
Hitman928
6,754
12,500
Again with this. Intel was first (Pentium D), AMD called intel's Pentium D chips glued together. Years later AMD comes out with tiles and Intel jokes back that they are glued together referring back to AMD's swipe at Intel. Suddenly everyone in all forums says AMD was first with tiles. AMD was first with a good implementation. But that doesn't make AMD first.
Pentium D and chiplets are actually technically distinct though. Pentium D put 2 full dies on a package and connected them through FSB. Chiplets actually break up the die into incomplete dies that all work together to give full functionality. It’s not the same thing.
gdansk
4,776
8,071
Again with this. Intel was first (Pentium D), AMD and the internet called intel's Pentium D chips glued together. Years later AMD comes out with tiles and Intel jokes back that they are glued together referring back to AMD's swipe at Intel. Suddenly everyone in all forums says AMD was first with tiles. AMD was first with a good implementation. But that doesn't make AMD first.
Disagree. Pentium D was a different approach. Two of the same chip, either of which was viable alone. AMD disaggregated cores from SoC hence chiplet as either chip is rather useless by itself. And MTL/ARL are like the AMD approach, not the Pentium D approach.
Timorous
1,989
3,918
Intel also had the IO die 1st with Clarkdale.
Timorous
1,989
3,918
Pretty sure Pentium D was still using a northbridge and FSB. In fact if I recall correctly for core 1 to speak to core 2 it had to go out to the northbridge over the FSB and back again.
Fundamentally the difference between Pentium D and Zen 2 is that instead of having the northbridge on the motherboard the northbridge is on the CPU package.
You could easily call Pentium D the 1st multi CCD design.
cebri1
373
405
So pretty OK MT results, latency killing latency sensitive apps. We’ll see if with some fine tuning you can get more acceptable results. Pretty impressive gains in performance per watt.
Kepler_L2
1,083
4,683
