Page 614 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
tsamolotoff
261
512
Which files?
Related to something that is called KGL in the 'debug info' of gamebar, it looks like these files don't get updated automatically in some cases (no idea why) on older OS installations even if you completely delete and reinstall gamebar, xbox app / services and even ms-store itself. In any case it's offtopic for intel thread, better continue this discussion in the Z5 topic if you wish
9949asd
139
So its a fantastic step forward for Intel that will build the foundation for a solid future then? When do actual Western reviews publish?
but intel did learn the example of amd, they should come out with something like x3d in the first place for the gaming improvements.
Abwx
12,019
4,981
I don't know what he compiled, but the problem with Visual Studio compiler is it doesn't have a notion of CPU architecture or vendor. Just instruction sets. I hope Mark will see this post and will join the discussion explaining what he did exactly.
Oh and for Skymont running in SSE mode is more beneficial than AVX if the SSE only binary is used to compare all CPUs. Just a detail.
Well, CPU-Z does a poor job as a benchmark, so it's results should be generally ignored either for Intel or AMD.
Check here and the following posts :
Reactions: GTracing
Hitman928
6,754
12,500
AMD employs older style chiplet interconnect. Physical wires connecting die-to-die routed thru the substrate itself. Intel employs more advanced packaging (stacking) where the chiplets sit on the interposer which in turn sits on top of the substrate itself. That is the technical distinction between the two imho.
My point is the name is meaningless. You are correct that there are technical differences between the approaches but the names are just marketing. AMD could use Intel's packaging and still call it chiplets. Your original post made it sound like the names referred to the technology they are using but the names are arbitrary.
cebri1
373
405
Very good step forward in perf/watt. But imo 50$\€ too expensive. Tough sell with platform cost. IMG_0799.jpegIMG_0798.jpeg
Hulk
4,102
I have gone over the Intel provided CB R24 data in some detail and here is what I have found. Please let me know where I've lost the trail.
Based on my testing of my 14900K in CB R24 MT, Raptor Cove does about 21.2 points/GHz (no HT), 27.8 points/GHz (with HT) and Gracemont about 12.8 in MT.
Using these numbers, a 14900K at stock 5.6/4.4 speeds from Intel Ark would score 2147 points.
Intel claims Arrow Lake is 18% faster or would score about 2525. Stock Arrow Lake speeds are 5.5/4.6 as viewed in Intel Ark.
Since the P cores are similar architectures we'll start with the +9% for Lion Cove over Raptor Cove, using the non HT Raptor 21.2 points/GHz and increase it to 23.1.
So, assuming +9% IPC ST increase for Lion Cove compared to Raptor Cove ST (Raptor Cove ST IPC derived from 8P only run without HT, not ST run, they are different, ST run is generally a bit higher than score obtained by taking MT score most likely due to multithreading overhead), then Skymont would need a 60% IPC increase in CB R23 vs Raptor Lake Gracemont or an increase from 12.8 points/GHz to 20.5 points/GHz, or in other words 3.5% less IPC than Raptor Cove.
Looking at ST scores, Intel claims 8% better for Lion Cove. Now we're looking at 6GHz for Raptor Cove and 5.7GHz for Lion Cove. This would require a 13.5% IPC increase for Lion Cove over Raptor Cove and the Lion Cove score would be about 146.
So, let's review.
According to Intel, looking at Cinebench R24 MT:
Lion Cove will have a 9% increase in MT score when you look at Raptor Cove without HT on vs Lion Cove.
Skymont will have a 60% increase in IPC over Gracemont or be 3.5% below Raptor Cove IPC.
For Cinebench R24 ST:
To achieve the Intel claimed 8% increase in score Lion Cove will need an IPC increase of 13.5% over Raptor Cove.
According to this data, Arrow Lake at 5.5/4.6 should score 146/2525 in Cinebench R24 ST, MT, respectively.
So if these numbers (Intel's claims) turn out to be true then Arrow Lake will be a good CB R24 performer mainly due to the astounding uptick in IPC of Skymont. I did not expect to see +60%. That's Conroe territory:eek:
One more thing I forgot to mention. In CB R24 if you compare the MT IPC performance of Lion Cove vs. Raptor Cove without HT, Lion Cove is only better by 13%. If you take the clockspeed deficit into account Lion Cove is better by 35%. Skymont looks to be formidable in FP.
It may be time for Intel to start considering a "workstation" version of Arrow Lake that is 6+24. That would be quite the MT powerhouse especially if they can creep up the clock on Skymont to ~5GHz without dramatically increasing the area.
One final, final thing. With RPL the P/E split for compute with CB 2024 MT was 58%/42%, now with ARL it looks to be 40%/60%. The P's and E's have reversed with Skymont carrying more of the compute load.
Here is my post from a few weeks ago where my CB R24 "Predictor" for ARL based on Intel pre-release data predicted a MT score of 2525 and ST of 146 vs and 2545 and 148. I was really close to this review at least for CB R24.
gdansk
4,774
8,066
So HUB reports the 285K does indeed have some stability issues, and has major stability issues with Win 24H2.
I also see some tests in Phoronix where it seems possible it's scheduling on Skymont instead of Lion Cove. So maybe not only Windows scheduler problems but also in Linux. Or it really is on the right core and it somehow became much worse? Weird in any case.
Hitman928
6,754
12,500
So from a quick read/watch, it seems like ARL is good at rendering and video encoding. For everything else, it ranges from terrible to mediocre performance. Power consumption is way down from RPL but not as efficient as AMD. Additionally, it seems to have platform issues causing inconsistent performance/instability. This is not P4/Bulldozer levels of bad, but it's pretty ugly.
AcrosTinus
221
226
So, I'm done consuming some of the biggest reviews:
Here is the autopsy:
  • Power consumption is indeed lowered
  • ST performance is the best currently in x86 world
  • MT performance is great and Skymont compensated the lack of HT
  • CUDIMM advantage consumed by the latency of the Tile architecture
  • If you don't game on a 4090 or game in 4K, these CPUs and any CPU will make no difference
  • AMD wins in all cases when it comes to gaming
  • Basically a nice entry level workstation chips that games well enough for GPUs up to 4070Ti Super or 4080.
  • For anyone on Raptor or Alder, SKIP
  • The foundation is not as bad as I though, It might need a new revision
Reactions: Saylick and Hulk
Hitman928
6,754
12,500
I'm not so sure it takes the ST crown and MT is very hit and miss.
