Page 613 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DZero
2,154
781
Intel pulled a Conroe Jump it seems and with their next in house node, seems that they are about to retake the crown. Still, since E core might be discarded, they should give the advancements to a minor maker like DM&P (taiwanese one)
Hitman928
6,754
12,500
Results are better than the last two, but still behind overall some of those results seem strangely GPU bound at 1080p with a 4090. Hopefully the picture gets clearer with higher quality reviews.
tsamolotoff
261
512
Gaming perf is weird
CS2 probably bugged / GPU-bound benchmark, as x3d is typically 20-30% faster than non-x3d in this game. Also, 7600x somehow faster than 7950x which shouldn't happen with substantial frequency gap (I guess gamebar is broken / disabled).
vanplayer
78
121
66
They shut down E cores and gain 4% fps in gaming. WOW surprise! And still slower than 9700x (default 285k is 100% while 9700x is 107%).
Don't ask why there's no 9950x in gaming test.
For this reason, we specifically turned off E-Core in BIOS and retested the game results using 8 P-Cores. The average frame rate of 14 games can be increased by as much as 4%!
While Chadmont is so hyped then people are still forced to shut it down and only 8C8T P cores left. What a design, what a day.
MS_AT
937
1,856
Lol, in CB 2024 optimised for Intel, barely better in Povray that enable AVX2 only for Intel and of course CPU Z who definitively crippled AMD back in 2017, quite some "wins".
I will be grateful if you could point out where Pov-ray enables AVX2 for Intel only. Here is the source code https://github.com/POV-Ray/povray. According to windows readme the official way to build is using Visual Studio 2015 that supports either SSE2 or AVX.
GTracing
478
1,114
Honestly, a 4% performance drop from enabling the e cores doesn't sound bad at all to me. Hyperthreading has a similar performance hit, and Intel choosing e cores over hyperthreading gives consumers much more multithreaded performance for the dollar.
SolidQ
1,542
2,547
That strange test, because in every test i see X3D beat easily 14900k and every other CPU.
3months ago.
Abwx
12,022
4,982
It was demonstrated by forum member MarkPost, he showed the difference before and after recompiling Povray to enable AVX2 for AMD, his numbers can be found somewhere in this forum.
How about wait before you declare the results rigged? Who knows, Zen 5 might win and it won’t be rigged.
It s documented that Povray use AVX2 only for Intel, and it s also documented that CPU Z crippled AMD since 2017, their excuse was that Zen was taking advantage of their bench because the 4 ALUs did execute very well some parts of the code, too well for their liking apparently, but i wont abund on this debate in this thread.
tsamolotoff
261
512
3months ago.
In their case gamebar is also broken as 7950x3d should be on top if this list. I've recently tried to 'fix' it on my ages-old W10 setup and it's actually not that evident that it is broken (when it is actually broken), even reinstalling W10 on top of existing iinstallation did not fix it for me (but copying some files from the clean installation did)
MS_AT
937
1,856
I don't know what he compiled, but the problem with Visual Studio compiler is it doesn't have a notion of CPU architecture or vendor. Just instruction sets. I hope Mark will see this post and will join the discussion explaining what he did exactly.
Oh and for Skymont running in SSE mode is more beneficial than AVX if the SSE only binary is used to compare all CPUs. Just a detail.
it s also documented that CPU Z crippled AMD since 2017, their excuse was that Zen was taking advantage of their bench because the 4 ALUs did execute very well some parts of the code, to well for their liking apparently, but i wont abund on this debate in this thread
Well, CPU-Z does a poor job as a benchmark, so it's results should be generally ignored either for Intel or AMD.
