Page 533 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hitman928
6,753
12,489
The issue is that we are seeing differences of 20W under load and people are attributing it to the OLED display.
The display is completely different and has 2x the max frame rate as well as being larger. It probably doesn’t explain the whole difference, but it’s a huge chunk of it. Lots of other little efficiency points can add up to the rest, or close to it.
controlflow
198
348
The conclusion there is certainly different than the general sentiment here towards Lion Cove.
Lion Cove is a much improved architecture compared to Redwood Cove, and shows Intel still has potent engineering muscle despite recent setbacks. Traditionally Intel delivered significant architecture changes during a “tock” in a tick-tock cycle. That reduces risk by separately handling process node and architecture changes. Lunar Lake not only combines a new architecture with a move to a new node, but also drops system level changes on top. At a time when Intel’s facing increased pressure from all sides, a move like Lunar Lake is a sign that Intel can adapt and survive.
Intel’s upcoming Arrow Lake desktop CPU will let Lion Cove stretch its legs with more cache and a larger power budget. Lower latency DDR5 should improve performance even further. After seeing Lion Cove perform well in a mobile form factor, I’m optimistic about what the same architecture can do on desktop. Recently Intel has is sitting on a rather unstable foundation right now with Raptor Lake, and Arrow Lake’s release will be a great time to put the company’s high performance chips back on stable footing.
MarkPost
378
794
dude, thats the whole laptop! not SOC. SOC is fixed to 28W for both.
Thats the reason why any battery life or efficiency comparison between laptops with different components is just misleading and useless (if your goal is to compare SOCs in that regard).
So for that, you need to compare the exact laptop model with the exact other components, SOC apart.
Its not that hard to understand.
9949asd
139
What are you talking about? Are you saying 2 more inches screen will use 20+w??? I am so tired about this.
poke01
4,769
6,100
ROG Zephyrus G16 have dGPU so this impacts total system power draw but they should be disabled right?
So yeah where is this extra 20+w difference coming from if all CPUs were limited to 28W, this may mean that AMD's Strix and MTL iGPU is more power hungry then.
NTMBK
10,520
6,034
Yet Intel's bottom line is bleeding red while AMD's books are flush. Can you explain this?
AMD is making huge inroads in the high margin datacenter market, even though they're not really getting anywhere in laptops. (Since they make much higher profits for the same number of wafers, it makes sense that they prioritise that market.)
Hitman928
6,753
12,489
The iGPU power is part of the 28 W limit. If you check the CB result in the review, it’s clear the 28 W limit is in place. It is not that crazy that a near 20 W difference can exist at the system level between these laptops, outside of the SoC power.
Reactions: lightmanek
KompuKare
1,234
1,606
I think that's mostly a strawman though.
I think what people have been saying repeatedly is that the extra 2 inches on an OLED explains SOME of the difference, not ALL of the differences.
Anyway didn't this start with those WHOLE system power differences with the synthetic scores to make it out like Lunar Lake's was some iGPU miracle?
Because while BMG seems to translate synthetics into gaming performance a lot better than any previous Intel iGPU, there is still a huge difference between synthetics and gaming. At least on the CB review where the synthetic Steel Nomad score was almost double the Strix score, but in games they were almost tied. This may mean that Intel's driver team may be able to squeeze out more performance eventually, on the other hand BG3 and Cyberpunk are both games for which Intel's driver team should already have optimised extensively.
511
5,346
4,760
IMO
>Synthetic is best case scenario with proper Drivers
> Real games shows how good the game is actually optimized for
It's! Basically Potential vs Actual performance
KompuKare
1,234
1,606
IMO
Theoretically, but my point was there is no way that Intel's drive team have left that much performance on the table for a game like Cyberpunk:
Steel Nomad is 191% Vs Strix
Cyberpunk is 98% Vs Strix.
Further optimisation might gain a few percentage points but almost double? Intel's driver team is not that incompetent.
Also, ComputerBase only tested two games and ComputerBase is notorious for not offending big companies - especially Intel - so neither BG3 nor Cyberpunk are unlikely to be some badly optimised outliner; they are more likely to be featured in any Intel reviewer's guide IMO.
5,346
4,760
Further optimisation might gain a few percentage points but almost double? Intel's driver is not that incompetent.
Also, ComputerBase only tested two games and ComputerBase is notorious for not offending big companies - especially Intel - so neither BG3 nor Cyberpunk are likely to be some badly optimised outliner; they are more likely to be featured in any Intel reviewer's guide IMO.
Cyberpunk is fair game but i want some older games like shadow of war Deus Ex Mankind Divided Prey tested as well it can take time but i want many games from past 7-10 years nowdays we get Buggy mess in the name of video games and no youtuber tests crysis 🙂
The Hardcard
346
442
Better we compare HX 370 with Lunar Lake. Cos, if we try to compare HX 370 with ARL-H parts, it'll be a complete bloodshed!
It's time for Lisa Su to retire.
I’ll be comparing ARL-H to Strix Halo. It’ll be interesting to see how they land in performance, price point, and power consumption.
Reactions: cebri1
Josh128
1,509
2,260
Excellent article.
A snippet from the Chips & Cheese article:
"Intel’s upcoming Arrow Lake desktop CPU will let Lion Cove stretch its legs with more cache and a larger power budget. Lower latency DDR5 should improve performance even further. After seeing Lion Cove perform well in a mobile form factor, I’m optimistic about what the same architecture can do on desktop."
And like always, with ARL-S 285K final, I still think we can expect 15% to ~20% IPC uplift (over 14900K). And >10% to 15% overall ST performance uplift. I've been saying the same all along and I stand by it.
Many initially claimed no more than 5%. Some of them eventually revised it to 9% and some 10%. But I'm saying with very high confidence that it's definitely gonna be greater than 10% easily. Time will tell.
Zen 5 may get hammered!
Recent Geekbench 6 runs dont support the hammering part at all.
