Page 532 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Khato
1,360
449
Including the DRAM on package is a design choice, it also brings important advantages not just another contributor to package power. You get slightly better memory tuning, you get considerably lower mem controller voltage and Intel also gets to ensure all chips have LPDDR5X 8533. The price they pay by lowering max available package power is arguably more than made up by higher memory performance in combination with around 100mV less voltage needed to drive the memory chips.
Nobody brings up the advantage of having mem on package when comparing battery life, because it would be absurd to penalize LNL for an advantageous design choice. The same applies when scaling power though, it would be absurd to penalize Strix, MTL or even the upcoming ARL-U for their design choices.
Not sure what the point of the above is?
My point is that if you're trying to compare CPU + iGPU efficiency by providing same power to different designs, then the same power budget should be provided to the CPU + iGPU. LNL has about 1.5-2W less power available to the CPU + iGPU if set to the same PL numbers due to the inclusion of DRAM in those numbers, no?
Hitman928
6,752
12,486
Are we unironically arguing that battery life doesn’t matter? If we’re using this argument, isn’t RPL a superior mobile product over Phoenix & Hawk Point? It had more cores, better multi threading and a slight edge in single threading.
There definitely comes a point where a person doesn’t care about additional battery life, but there are plenty of people out there for whom that line is still far away and they will take all the battery life they can get.
OneEng2
973
1,183
I've been hearing this since the Llano days. "Wait for Trinity, that's the real competitive laptop part!"
AMD just don't have the connections and the volume, and I don't know why at this point. Their APUs have been excellent for years now, but they're still losing out to Intel left right and center. My only conclusion is that Intel can out manufacture them with the sheer capacity of their fabs, while AMD has to fight Nvidia and Apple for space.
Yet Intel's bottom line is bleeding red while AMD's books are flush. Can you explain this?
18A looks to be a lot better than TSMC N3 and very close to N2. Also, 18A is expected to have higher performance than N2 because of BSPDN (higher Fmax than N2, cos N2 doesn't have BSPDN).
Not what I have read anywhere. 18A looks to be about on par with N3P.... which isn't a bad thing for Intel who have been horridly behind. It is not expected to be competitive with N2 and I believe even Intel has stated this IIRC.
No more free hall pass for Turin. Looks like it’s gonna be a tough fight after all.
Looks like ;).
My feeling is that with full Zen 5 cores and better power efficiency, Turin 128 will likely exceed Granite Rapids by >30% ... but no longer a bloodbath.
Reactions: Markfw
coercitiv
7,464
17,822
LNL has a different design, the mem on package is a tradeoff that introduces both a penalty and a series of advantages. One cannot ask for the penalty to be nullified while the advantages are still in effect.
Imagine asking for LNL to run higher uncore voltages during battery life tests because MTL does not have mem on package. Sounds absurd enough to get the point across?
AcrosTinus
221
226
Looks like ;).
Exceeding Granite Rapids in what ? By 30% or more, people consider such lofty predictions a "bloodbath".
The Zen5 cores are great but they are not 1.5 Generations better. The IPC is similarish, maybe due to the core being more efficient they might clock higher in the same 500W envelope.
yuri69
696
1,248
AMD basically goes one server gen per 2 years. Intel goes one per year - 2023 Sapphire + Emerald; 2024 Granite; 2025 Diamond
Intel is gonna be server leader from 2025 Diamond Rapids launch 'till late 2026 Venice launch.
Reactions: Henry swagger
adroc_thurston
8,264
11,020
cebri1
373
405
Seeing the performance gains, I would say these refinements are pretty good.
Well SPR was horrible lol. EMR was a very nice jump considering it was built on the same core and the same node, but with a fixed memory subsystem.
GNR is more of a jump, due to RWC+ (Still GLC++++) & Intel 3.
DMR should be what's propels Intel ahead. 18A plus first really new CPU architecture since Golden Cove on server.
Josh128
1,508
2,260
So its been established that display has a huge bearing on battery life then, no?
Heres how the same Vivobook S 14 with HX 370 faired in runtimes vs the super-duper ARM- beating efficiency Core Ultra 2 258V. Whats that, Strix gets
10% better average runtime despite having only 4% larger capacity battery? How can that be?? Maybe display type and size does matter after all. :rolleyes:
Reactions: lightmanek
cebri1
373
405
Yes it has been established by every single reviewer. Stop polluting the thread. And no, display size from 14 to 16 barely affects power consumption.
poke01
4,764
6,097
That Jarrod video is not good at all. Many shortcomings and his results are different to many other reviewers because of this.
cebri1
373
405
Yeah it does, especially for OLEDs.
There's a good reason OLED TVs aren't efficient at all.
2 more inches, 5W more? 7-8W tops. And the 16 inch laptop has a larger batery as well.
However it's nice to see that the battery debate, that yesterday was stupid because there are power outlets everywhere, today is relevant again.
But let's keep polluting the thread.
edit: btw, 5-8W on average. If you test an OLED laptop, depending on the content, it can even be more efficient that an IPS.
cebri1
373
405
That's a ton of power, big dawg.
It's only ever more efficient at absolutely miserable APL levels which is not laptop usage model at all!
Hope that helps.
The issue is that we are seeing differences of 20W under load and people are attributing it to the OLED display.
