Page 534 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hitman928
6,752
12,486
It’s because it’s a 16 in… wait, what?
Again, that is just 1 element at play. Look at the below example for the Proart and Zehpyrus; same size screens, same CPUs, same battery size, very different battery life results.
It is not unreasonable to have CPUs in completely different laptops drawing the same amount of power, but the system as a whole has wildly different power consumption.
The CB results in JT’s review show the 28W limit is correctly in place, so pointing at system level consumption to try and prove the 28W limit isn’t working is just not good enough when direct performance measurement shows it is working and the difference in system level consumption is explainable.
Edit: it’s probably not a coincidence that the model showing high system power consumption in JT’s review is the same one showing significantly worse battery life in the above screenshot.
KompuKare
1,234
1,606
Hitman928
6,752
12,486
15W TDP vs 28W TDP, I’d say is very aligned.
TDP is basically meaningless now. What matters is what the PL2/PL1 are set at. According to NBC, the Zenbook 14 with the 155h has a lower PL1 (20 W) than the Yoga with the 125u (29 W) but a higher PL2 (64 W vs 41 W). The big reason the Zenbook has such worse battery life is that it has a higher resolution, higher refresh rate, OLED display which will draw way more power than the IPS panel in the Yoga, despite the Yoga having a bigger screen size.
poke01
4,757
6,094
If it hasn’t been obvious outlets and YouTubers promote the latest and the current product they are reviewing in the best light possible unless of course the product is so bad they can’t do so.
That being said there a few decent outlets that test everything. So how will Lion Cove hammer Zen5? Probably only in ST and memory support even then most DIY users will pick the X3D parts and creators Intel.
coercitiv
7,462
17,810
I'd say the days when Intel U chips had chipset on package while H chips did not are gone since MTL. AFAIK the SoCs are functionally the same, hence the difference in power under very light loads is only attributable to the rest of the system (components & firmware).
511
5,340
4,753
Well the efficiency problem will be solved as well so it will be even difficult Choice to prioritise what now Unless you have a drop in mobo upgrade
gdansk
4,722
7,996
As far as I can tell neither Arrow Lake nor Zen 5 have changed anything. Based on Geekbench they both look like very unimpressive improvements for typical PCs. And it took both far too long to deliver.
Even process parity with LNL wasn't enough to match the year old M3 in some ways. At this point it really does look like the ARM and Apple yearly cadence - afforded by the smartphone market - will win and remain on top.
KompuKare
1,234
1,606
When team red's advocates were spreading the *exact same* hyperbole for the past couple of years, it was okay. But now the tables have turned, it isn't okay anymore? Thats hilarious! Thats hyperbole.
Reading comprehension? Because I said no such thing - just that I have a very low opinion of what passes for tech "journalism".
Reactions: rosetta
DavidC1
2,106
3,224
Hitman928
6,752
12,486
I'd be interested to see how LNL performs at 20 W or lower, especially in gaming. It probably can't run AAA games well, even it minimal settings, but for light or medium weight games, it should do well and I'm guessing nothing else can keep up with it at the lower power levels.
Josh128
1,508
2,260
Lunarlake system has 1800p 120Hz OLED display while Ryzen HX 370 system has 1200p 60Hz OLED display.
Lunarlake is a lot lower power but not enough to make up for that difference.
Precisely, and that was point-- to show how much the display impacts the battery life. Others were implying that I was making it up.
The chart I posted even shows the Strix system beating the Snapdragon X Lenovo system with 14.50 inch 16:10, 2944 x 1840 pixel 239 PPI, Capacitive, OLED,90 Hz display.
itsmydamnation
3,122
3,971
Battlemage supports upscaling for ray-tracing perf using XeSS. Offers excellent quality (comparable to DLSS). But it still lacks FG. I think frame-gen uses less than half the gpu compute to generate a frame rather than rendering it. Intel did mention that it's coming out with its own FG a.k.a ExtraSS soon. But when it'll reach the masses and/or whether it'll get adopted by popular games is still a question.
Once they release it, LNL should be able to handle AAA titles at a good frame rate with normal settings.
You can use FSR 3.1 FG with XeSS on anything , XeSS is not as good as good DLSS 3.7 generally speaking, you might find specific situations but not overall, not in motion , its probably a bit better then FSR 3.1 upscale overall ( most games better some not). FSR 3.1 FG is basically the best FG so unless intel has something really good cooking I wouldn't bother re-inventing the wheel.
Reactions: lightmanek
511
5,340
4,753
The x86 duo has been focusing Clock Speed for decades and now Apple//ARM is following the suite with M1->M2->M3->M4 soon apple/Arm will hit the wall of clockspeed meanwhile Intel/AMD should focus on their ST Perf/ lower power levels LNL is a very nice step they need to keep improving it
Nothingness
3,364
2,457
Well, in the grand scheme of things, those are all mostly ES. Now this looks like a QS. And it's killing it...
And it says: "it's 8.4% faster than Ryzen 9 9950X" in multi-threading! And this is just a 265K. :tearsofjoy:
It's pretty much clear now that ARL-S 285K is clearly the leader this gen. Both in ST & MT.
Have we reached the point where we take wccftech seriously? What about waiting for release? Or let's switch this to a "8.4% over 9950x!!!!!!11111" hype train thread. Or even 10% (or even more!) because it's a QS (which is not even proven) so final will go through the roof when released.
cebri1
373
405
I agree with you in principle, but this thread is thrash (like the other Intel threads) thanks to the the usual suspects. I think wccfftech has higher standards than most posters here.
Edit: The GB6 entry: https://browser.geekbench.com/v6/cpu/8030562
