Page 403 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Aeonsim
22
63
Nope. First off, HT loss in ARL isn't 30%. It's upto 30% on very specific cases. Generally, it's around 15% (and maybe even upto 20% on occasions). But when HT is removed from a core, ST gets a solid boost which offsets the HT loss. So, the effective loss due to lack of HT is not that much. Instead, we can expect better ST boost than normal. Thats the reason Lion Cove dropped HT.
In short, ARL is expected to post a solid Geekbench 6 MT score compared to previous gen and compared to competition. All those low MT perf numbers that are projected are pretty much fake/rumors.
It's very easy to test this, simply run your fav multi-core benchmarks, reboot, enter bios, disable hyperthreading. Load into windows run your fav multithreaded benchmarks.
Note GB isn't great for multi-core testing so use something more intense that runs for a while.
AcrosTinus
221
226
I believe Intel has something special on their hands:
  • A new P core designed with industry standard tools for rapid iteration
  • A new P core and E core layout around the ringbus
  • dedicated PCIe5x4 lane for faster storage
  • new caching structure on the P cores
  • Skymont being on Raptor Cove performance level when on ring
  • Lion Cove with still secret changes on the desktop version
  • IGPU with the industry best encoders and decoder for 4:2:2 10bit
I will give Intel the benefit of the doubt, 2 machines need an upgrade and if they hit my low bar of being 10% faster but coolable, I am fine with it. I want to get rid of all those 420mm and 360mm AIO i deploy.
If they fail to meet this bar... I will wait for AMDs active substrate CPUs with COWOS and such and hop over.
CakeMonster
1,663
843
I remember when we had rapid iteration of the architecture. I loved reading the AT architecture overviews when Intel tweaked the architecture on a yearly basis, from Core 2 up to Skylake. It felt like we were going somewhere, even if the changes weren't always huge.
AcrosTinus
221
226
Those times might be coming back, the competition is too strong for that to not be the case. Qualcomm, Apple, AMD everyone wants a piece of the computing pie and Intel despite their failures still has the capacity to excel.
Furthermore I also think that SYCL/oneAPI is a good alternative to CUDA. Intel has the tech to compete, it might not always be the best but it is still high tech.
Geddagod
1,683
1,720
you think they gonna hit 5.4Ghz all core load? Seems a bit wishful thinking, but we'll see. I guess 347A will help 🔥
That's the current rumor according to Raichu. 5.7GHz peak.
I just want to point out, the 14900k did 5.7GHz all P core boost. And it was consuming a peak of ~280 watts in nT workloads. The 13900k did 5.5GHz all core boost.
dullard
26,196
4,869
Seems like power limits also are going up.
Must say this don't fill me with confidence..
Once again your data and your conclusions aren't quite in sync. (1) Your chart doesn't include Raptor Lake Refresh. (2) That is absolute max allowed -- not what will actually be used.
On your table, ICCMax for Arrow Lake-S (347 A) is actually down from Raptor Lake Refresh (400 A). Here is Anandtech's quote on Raptor Lake Refresh: "Intel has added a new 'Extreme' Power Delivery Profile, implemented through the firmware on capable boards, and increases the ICCMax to 400 A, up from the default 307 A value."
As for actual power used in setups that aren't in the 'Extreme' category, the latest rumor that I have seen shows PL2 and PL4 are DOWN for Arrow Lake:
  • Intel Raptor Lake 125W (PL1/PL2/PL4) 24 Core SKU - 125W / 253W / 420W
  • Intel Arrow Lake 125W (PL1/PL2/PL4) 24 Core SKU - 125W / 177W / 333W
Reactions: Henry swagger
MarkPost
378
794
and consequently we have the Raptor Lake debacle
Reactions: lightmanek
Henry swagger
514
314
Shut him down real quick 🥇
DavidC1
2,187
3,340
Shave 1000-1500 pts off from that if you want to compare at 15 W, and even then LNL should score 14K in CB23 MT.
Which is just a random guess on your part. We know from the frequency curve Meteorlake drops off in performance quite drastically. So if it's 7K, then LNL is 10.5K.
"Rapid iteration" nonsense has been paraded by Intel since they introduced the ringbus with Sandy Bridge. The reality is these projects are immensely complex and increase in complexity every generation that new different methodologies are needed just to compensate for increase in complexity.
It looks like Granite Rapids core has quite nice changes, but it's also part of the move to intel 3 and delays quoted by Pat so I would not attribute it entirely to the new design process either. Previously it took them more than a year to add extra L2 cache and the 512-bit FPU, so if it indeed comes with 8-way decoder and backend, it is an improvement.
Don't expect client to have big changes though.
There's nothing secret about it other than the 0.5MB extra L2. In fact before the Computex reveal people said Lunarlake used Lion Cove+ and had extra changes over Lion Cove on Arrowlake. Now people are saying the opposite? I say just pure denial over the mere 14% gains being lower than expected. I don't see the AMD camp in denial over 16% even though most were certain it would be in upwards of 30%?
mikk
4,333
2,414
If the leaked CB23 scores are from Jaykinn, then it is likely that those are outdated information.
Because the 165U scores 10.5K in CB23 mT with a 21 W PL1.
But yes, all this is irrelevant. The point is that Lion Cove, even with acceptable levels of IPC uplift, will have no problem keeping up with the competition at similar clock speeds.
MTL-U at 15W does 6681 points in CB R23 according to Jaykihn.
AcrosTinus
221
226
I have hope, my expectations are quite low.
I want 10% better performance in general compute and lower cooling requirements as well as a word from Intel regarding the defects problem of 13th and 14th gen.
If they can deliver I am happy, this is not a cake they are baking.
The people at Intel are doing super complex work, so I have respect even if things don't pan out.
AcrosTinus
221
226
On the contrary, I think the idiots at Intel were well aware of the defect already, but it appears they've grossly underestimated the scale of its impact. It's just Intel desperately trying to match/outdo competition at the expense of customers. Just plain bad. It is very important that they do a full recall, otherwise everyone's gonna spit in their face sooner or later. I'm just waiting for Pat to get back to his senses before it's too late.
I hope you are exaggerating, these are not idiots. Most of them have advanced degrees. I know two intel engineers, I have never met people with that much passion for tech.
In a huge company like that many decision are out of the hand of people in the lower ranks or RND level. I work in a larger company and get tons of restrictions even if solutions to problems seem so obvious.
DavidC1
2,187
3,340
Not necessarily. The purpose of their new methodologies is to reduce turn around time. Modular design divides a large IP into smaller IP blocks which in turn significantly reduces design, development & validation times. And also, it enables IP reuse.
For us consumers and users of the said product it makes zero difference. I don't see next generation coming earlier do you? Nor the gains greater than before? It requires MORE work today to get LESS benefits.
One benchmark Intel used in their testing to showcase the advances of their processors over the years was used for designing ever more complex designs. The gains in that benchmark over generations were noticeably lower than the increase in complexity over the same time. More work, less benefit!
In the black box scheme of things all the fancy terminologies such as "methodologies", "modular", "tiles", "disaggregation", "chiplets" didn't make an ounce of difference in more iterations, nor the timeline between generations become shorter.
DavidC1
2,187
3,340
If not for these "terminologies", the timeline between generations will become even more longer.
Exactly, and don't expect it to become shorter. "Revolutionary" advancements are merely there to enable continued progress, not some radical step function increase in development.
I'm saying to outsiders it did nothing to make it shorter. Therefore, they could call it what they want, but doesn't really matter.
Reactions: Racan
DrMrLordX
23,229
13,312
HT "threads" are just emulation. The loss of thread count won't bring MT perf down by much cos each physical core tends to gain ST perf when HT is removed which compensates well.
That's only true for workloads that can keep the pipeline full. Gaps or stalls make SMT shine.
N3B has more mask layers and has less performance than n3E.. intel will use n3E for arrow refresh i think 🤔
. . . if they can afford the capacity.
