Page 404 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
PL1+PL2= 15W
If that is the case, and if LNL preliminary estimated perf in CB 23 is +50% over MTL-U which scores ~6700 at the same power levels, then LNL is already ahead of Phoenix:
This is from Geekerwan.
Note that Intel's own nodes till Intel 7 don't scale well at low power, and LNL is on N3(B?) - which means that power scaling at the low end is going to be similar to competition.
So LNL should be doing 6700*1.5 ~= 10000 pts in CB R23 with MTP and PBP both capped at 15W (or 17W if you include the MoP).
Reactions: 511
I have Ultra 9 185H i can try restricting it to 15W with 2P+8E+2LPE
I'm not sure if this was posted or how reliable it is (but it looks very much in line with the expectations):
If true, that would be at the top of the single core list, above the i-9 14900KS (143) and M3 Pro (142): https://www.cpu-monkey.com/en/cpu_benchmark-cinebench_2024_single_core
And basically in the middle of the i-9 14900K (2177) and i-9 14900KS (2252): https://www.cpu-monkey.com/en/cpu_benchmark-cinebench_2024_multi_core
According to this slightly different list, it would be the top of the single core and just below the i-9 14900K (2211): https://www.cgdirector.com/cinebench-2024-scores/
We also have these two tweets:
One more model with 5.9Ghz ST boost
Zen 5 9950X ES scoring the same at ST at the same clock 🙂
Would put it at an around ~16-17% IPC uplift compared to the 5.8GHz 13900k, not bad.
The leaked ARL's MT performance is disappointing, as it should be higher than the ST gains. So still have to wait.
Surprised no one saw this tweet:
Or for those who dont wanna click on the link
It seems to be one rare generation where the BTB size didn't increase. That might explain less-than expected gains.
Skymont didn't get BTB increase either, but it benefits from the changes made to enhance the clustered decode scheme further.
last time i saw,the es frequency is 4.7g. We don’t know what is the frequency that r24 run at.
Agree, this result is a fake. We have an actual 9950X ES @5.65GHz scoring 143 in the Zen 5 thread. The same Haytam guy posted like 153 for 9950X ES a few days before that. Scores seem made up-- I dont believe Haytam is a reliable source. Plus, the guys handle has the word "meld" in it. Instant skepticism just from that. 🙂
The 4.7GHz ES you are talking about is DIFFERENT from this ES, as the ST performance is up to par.
But people are calling him out as fake, so there it is.
Look, no x86 CPU(Zen5 or ARL) is going above 150 ST (Cinebench 2024) at stock. Only one non-x86 CPU will, that would be Apple's M4 Max(4.5GHz) now that its got a ~17% ST boost over M3 Max.
If AMD or Intel boosted above 5.7GHz this gen, then yes 150 would have been possible.
Just to follow up, it’s the M4 series in general that will be over 150 points. Based on geekbench (I know it’s not ideal), the M4 gets 19% better single-core scores compared to the M3 (it is cross OS, but the M2 differences aren’t much when using each OS). If that improvement remains the same, then the M4 should score around 170 points in Cinebench 2024.
It will not cross 170 cause the geekbench inflation is due to the Matrix extension it will be around 165
Also i winded what happens if Cinebench ran on Linux than we would have both the macos and Linux with posix thread model minimising the difference
