Page 406 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
911
829
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Saylick
4,096
9,574
I'm not sure which profile was used for 14900K but according to CPU monkey, the SKU should score 38700 pts.
For reference 7950x gets 38.6K , while unofficially the 9950X gets 43.9K pts.
I think we’re realistically looking at ARL-S and the 9950X trading blows in MT, thanks to Chadmont. But the ST is anyone’s guess right now. What we need are ST clocks. Need to understand at what clocks are those ST scores being delivered at.
cebri1
373
405
This, without clocks the benchmark is mostly useless.
Reactions: Tlh97 and Saylick
inf64
3,884
4,692
I think that the max boost clocks for ST will be 5.7 or 5.8Ghz, according to leaks. I guess that the QS sample was probably running at close to the max ST boost.
dullard
26,138
4,797
I think the 14900K does a little better at CB23 than that Xitter post shows. For example, from TechPowerUp:...
One thing to keep in mind is that the data you posted are not at 250 W. Whereas the leak claims 250 W.
  • TechPowerUp tested at ~280 W (hard to get an exact number from the top chart here: https://www.techpowerup.com/review/intel-core-i9-14900k/22.html) and got a Cinebench R23 multithread score of 38746.
  • Anandtech tested at max 428 W (didn't breakout exact power in R23) and got a Cinebench R23 multithread score of 41211.
  • Tweaktown tested at max 330 W (didn't breakout exact power in R23) and got a Cinebench R23 multithread score of 40525.
Also, what is the single thread power usage in the leak? Same ~35W to ~55W? Or different power levels between Arrow Lake and Raptor Lake Refresh?
jdubs03
1,333
935
With PBO+EXPO enabled.
jdubs03
1,333
935
We are talking about intel CPUs here, not AMD. I was questioning the power profile of 14900K that was mentioned to score less than what we have in reviews.
Indeed, just wanted to point that out the stock values as that it’s probably most representative of the QS from Intel. The percentage difference is a decent amount there.
Reactions: inf64
DavidC1
2,006
3,153
nah, disregard my post, the issue is with the ST performance. Also MT is behind expectation, still a QS sample tho.
Actually.
If you take the assumption that 2 E cores are equal to 1 P cores for Raptorlake,
RPL: 8x1.3 + 8 = 18.4
ARL: 8x1.15 + 8 x 1.5 = 21.2(15%)
15% is roughly the figure for MT. We could say it's even outperforming expectations a bit as the above suggests MT clocks haven't went down from the 14900K.
6% in ST is basically 1.15 x 5.7/6.2.
(I know Intel said 14% but 1% is easily swayed by benchmark choices)
Hitman928
6,746
12,468
Crossmark is a mix of workloads. The overall score will be influenced by the multithreaded performance. Looking at just the single/very lightly threaded results, it shows the ARL QS as being either the same or less performance than a 14900K (which is 6 GHz boost, not 6.2 GHz). It's not a good showing in terms of ST performance. Of course, it is just an unverified leak of a QS so there's nothing to conclude here, but if this is representative of retail performance, it's not going to be a good look for Intel.
Edit: Using GB5 ST results, the IPC increase would be 6.3%. The browser benchmarks show no IPC gain (WebXPRT) and a -4.5% regression (Speedometer). Leaked QS sample caveat obviously still applies.
Reactions: exquisitechar
Hitman928
6,746
12,468
Yes, but we kinda knew the gains based on ARL leak a while ago that people dismissed as sandbagging. And the recent numbers are roughly on par with it.
The best we're going to get in single thread is 5-7%.
I added an edit, but these results don't even show that. It's basically a wash for ST performance at best. Of course, retail samples could perform better but there probably won't be a big difference.
DavidC1
2,006
3,153
Hitman928
6,746
12,468
From Igorsleak: https://www.igorslab.de/en/intels-i...n-for-raptor-lake-s-refresh-and-arrow-lake-s/
Hmm, I guess it is.
From the Spec 1-copy results though, it only shows 2-3% gain over RPL-S Refresh which would be the 14900K.
If this QS is retail performance and it is under performing compared to projections, they will probably miss SPEC 1T performance projection as well, so even that 2-3% gain is in question. Not drawing a conclusion yet, we are still a few months off from retail release, just commenting on the results we have.
Hitman928
6,746
12,468
Even if this QS is representative of final performance, there are still 2 very big unknowns. First is what memory config was used, this can make a significant difference in some benchmarks. The second is power/efficiency. I know it says that it was set to 250W, but we don't know how much it is actually using in CB (my guess would be 250W but we don't know for sure) and how much it uses in idle/ST scenarios.
jdubs03
1,333
935
Intel better hope they can achieve those values. Because it isn’t looking like it as of now.
Philste
307
485
Did you all miss the fact that it says "preliminary"? Jaykihn himself posted that Arrow Lake QS is Week 34, which is 4 weeks from now. I don't know where this data is from, but definitely not from a QS.
Hitman928
6,746
12,468
Where did he post the date of the QS? It would be pretty strange to get a CPU to test that was manufactured in the future.
Other than that, everyone knows it's preliminary, that has been repeated multiple times now. If it really is a QS though, those are typically very close, if not equal, to retail samples. There's a reason they get listed as QS. That's not to say there can't be a difference, just that typically, there isn't a significant one between QS and retail, though it is possible.
