Page 344 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
inf64
3,884
4,692
So 10-15% bigger, and likely 10-15% better IPC (I think that RWC is ahead of Zen 4?). If so, that seems fine.
Edit: Actually if Lion Cove now is physically missing AVX-512, I would expect a bigger uplift, though again Zen 5 IPC numbers include some AVX 512 workloads, so comparison outside AVX 512 is not clear.
Edit2: Raptor Cove is only around 1-5% ahead of Zen 4 according to Spec 2017. Not sure what Zen 5 uplift is outside of AVX 512, so hard to compare to Lion Cove in lunar lake.
Raptor cove is around 2-3% faster than Zen 4, while RWC is around ~3% slower than Raptor cove (so RWC and Zen 4 are ~even). Zen 5 should end up having a slight edge over Lion Cove if both IPC projections are confirmed in reality. In AVX512 optimized stuff Zen 5 should have a big advantage though.
FlameTail
4,384
2,762
Well yeah e-core team if they truly are progressing as good as this, should just replace the P core team and one unified core type again and bye bye hybrid arch and back to same type of core as only reason hybrid came about is because Intel P core team had cores too large and power hungry to get as many as AMD in a consumer sized socket at reasonable power draw and they needed the quantity of much weaker e-cores to be competitive in perfect parallel workloads with AMD. Otherwise Big.Little does not exist in desktop.
Conroe moment maybe in a few years and e-core team should replace P core team if things are truly progressing as rumored form e-core team?
Intel will still need an Apple-style E-core. An E-core that prioritises power efficiency above all else. This is for their laptop chips though. Desktop can use one core type.
Reactions: Wolverine2349
Jun 4, 2024
Process leadership is 2025.
Can’t wait. Finally competition is returning. AMD has been stagnating with the lack of it. No core count progression, niche improvements focused on trendy AI crap. I’m running a Zen 3 still because all the new stuff is mid. Looking forward to upgrading to 32 core chadmont_dark + lion_cove_next_brad or zen 6 32c
Hulk
4,051
What structures in a CPU are generally referred to as being in the "front end" and which ones are in the "back end?"
Hitman928
6,753
12,492
Raptor cove is slightly behind Zen 4 in IPC according to Anandtech’s SPEC results. RWC may have a slight IPC regression, there’s conflicting data on that. If we assume Intel and AMD IPC numbers for next gen exactly match SPEC, then Zen 5 should be ahead in IPC by like 7% or so. Close enough that it shouldn’t matter much in a generalized performance way.
lightisgood
250
121
86
Could you tell me why you are only thinking about SPEC CPU?
GB5, GB6, PCmark and so on are major benchmark, today.
Besides, Lisa avoided cleverly telling about Zen 5's SPECint score...
Hitman928
6,753
12,492
This has been discussed multiple times in just the past few weeks so I’m not going to rehash it again but in summary, SPEC is the industry standard for generalized benchmark and has been the measuring stick for IPC measurements for generations now.
AMD never includes SPEC in their consumer products announcements.
Reactions: Racan and Tlh97
Jun 4, 2024
I had read this writing in the review of Rocket Lake, 2021 and feel an irony of history now...
Yeah. I don’t understand Intels long term plans here. I currently wish they hadn’t removed support on consumer parts, because I care about
it for ML (I have a 4090, but that’s only
24GB, and CPUs are just easier to work with). But maybe in the next 3 years their plan comes together with the move to NPUs and AVX10?
FlameTail
4,384
2,762
This matches what Exist has said for years, including that P Core tried to kill E core team and also others Cores projects at Intel. And that they were very adversarial against Jim Keller while the E core team was very helpful and accepted his guidance.
How does that dude keep making so many good predictions?
lightisgood
250
121
86
Again, could you tell me why you are ONLY thinking about SPEC CPU?
Okay. That is to say, Turin was not unveiled in Computex 2024.
Hitman928
6,753
12,492
I'm not saying that SPEC is the only benchmark that should ever be considered, but for comparing generalized IPC, it has been the tool used for several generations now. There are multiple reasons for this which I'm not going to rehash because we have recently discussed it for pages already.
I don't understand your point. The only things AMD showed for Turin was HPC and AI related stuff compared to Xeon.
Reactions: Tlh97
Abwx
12,000
4,954
It is not, Computerbase provided a comparison at same frequency, and in all cases excepted CBR20 Zen 4 has better MT IPC than the P cores used in the 12900K, how is this possible if ST IPC was lower by 10%..?..
And before one comes for a theorical better SMT scaling of Zen 4 that s just moot, because 5% better ST IPC cant be compensated in MT by marginaly better SMT yield, let alone with 10% better ST IPC as proven by the estimation below.
If a core has say 100 ST IPC and 30% SMT yield it will perform at 130 in MT.
A core that has just 5% better IPC and only 25% SMT yield is at 131.5 in MT.
Now a core at 110 with only 25% SMT yield would do 137.5.
SMT yields of AMD and Intel are not as far apart as in this exemple, so it s obvious that Intel having better IPC is just an urban legend that doesnt pass the most basic examination, actually it s the contrary.
H433x0n
1,224
1,606
ARL-S P cores are slightly different with more L2$ and HT present (although maybe not enabled).
Based on the disparity of how transparent IPC was calculated for both - I would wait for 3rd party reviews before saying anything conclusively.
Reactions: carancho
lightisgood
250
121
86
Reactions: invisible_city
