Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 680 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
763
719
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Hulk
3,650
Igor sent me a review of the 285K that seems quite favorable to Intel. Some of the stats made me go "hmmmm?"
Accord to this review the 285K is much easier to cool than the 9950X.
Also showing idle system power for Intel as half that of AMD. Total load system power is much lower as well?
Not what I had previously thought?
Abwx
11,824
4,761
Lol, here what he says, that the 9950X power increased unexpectedly without even touching something since his first review, just in time apparently.
At stock the 9950X is limited to 200W.
  • Screenshot 2024-11-17 at 01-39-33 Intel Core Ultra 9 285K CPU Review Performance Thermals & Po...png
  • Screenshot 2024-11-17 at 01-44-38 Intel Core Ultra 9 285K 7 265K & 5 245K vs. AMD Ryzen im Tes...png
DavidC1
1,546
2,555
You will have a hard time degrading it at 5 GHz. These chips are very easy to cool, so beside the lower voltage you get a huge benefit of low temps.
I thought it was the ring that degraded because it was too high on Raptorlake?
Let's hope that isn't the case. Doesn't seem like Alder Lake had that problem.
Alderlake had the ring clock much lower than Raptorlake. There's a 900MHz difference. I think it's 3.6GHz vs 4.5GHz. Arrowlake is 3.8GHz. Don't think it's a coincidence. Haswell with the 4790K was when they really started ramping the clocks again. Haswell was also the chip that made ring asynchronous with the clocks. Sandy Bridge's CPU clocks were identical to ring.
IO is generally harder to clock higher so that's why I keep saying back off from the ridiculous clocks.
I do believe Intel's claims that they messed up on the optimization part with Arrowlake though. Probably can get ~5% in gaming and reduce variations run-to-run without needing to clock any parts higher.
DrMrLordX
22,610
12,532
What's the point of running a 14700k @ 5 GHz max frequency versus just running a 12900k/s? Would there be any performance advantage at that point? You'd get a few more ecores, but that's about it . . .
Reactions: Thunder 57
Hulk
3,650
I was thinking about that today. 200W on my 14900K. 8+16 CB R23 = 35000, 8+12=31000
Handbrake test on this forum time goes down by 10 seconds when you add in the additional 4 cores for the same total power.
So yes, for applications that will use the additional threads the E's, even an additional cluster make a significant difference.
Reactions: lightmanek
poke01
3,540
4,867
Some 12900K dies can make use of AVX-512 when e-cores are disabled, you are not getting this done are you :p
Hulk
3,650
I had a 12700K a few years ago and was able to enable AVX-512 and run the Handbrake test with it enabled in the app as well. The improvement in performance wias negligible.
Reactions: 511 and poke01
OneEng2
640
875
Foolish advice IMO.
If Hulk is a gamer, the answer is clear. The 9800 X3D shortly after the release of the higher clocked models will be the best gaming processor for the money on the planet for quite some time I would expect.
There is even the opportunity for a future Zen 6 upgrade in a couple of years.
How is spending more money on an obsolete platform with inferior performance a good investment?
511
2,518
2,349
The best bet is 14700K on Black friday safer than 14900K and he saves money for future upgrade just buy Zen6 when it comes out
