Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 815 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
764
721
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
coercitiv
7,212
16,923
Others aren't very intuitive to use.
If you really cared just about efficiency and memory usage, you would have used Ollama, like a true command prompt warrior. The UI and improved design in LM Studio have a time cost attached, and that time cost is partially offset by using a fast development method.
Sounds to me like you're preaching, but you're not practicing.
17,601
I don't have time to go exploring looking for better options than LM Studio. My being forced to use LM Studio doesn't change the fact that native applications offer the best user experience and there would be a lot more of them on Mac Silicon if it were properly opened up to Linux. Could even thrive as a decent Steam machine.
Mac users are blissfully unaware or maybe deluding themselves that being stuck with MacOS is best for them when in reality, their choices are being limited by a huge corporation and somehow they don't feel angry about it.
poke01
3,553
4,885
You don’t even see the irony in what you wrote. No one’s stuck to macOS, there are people in this very thread who use all operating systems.
No one’s stuck or delusional, you yourself make these assumptions and presume it to be true. You bring your opinions on others and say it as fact.
Doug S
3,224
5,556
Native booting Linux is the least useful of the possible solutions. If you do that you cut yourself off from all the macOS applications, and would have to continually boot between environments. The only people who would truly appreciate that solution are the people who bought a Mac for its raw performance not because it was a "Mac". I doubt that's a significant market, and would be a highly fickle one since it would abandon Apple the moment someone else takes the performance crown.
What's wrong with running it in a VM? That sort of thing is pretty seamless these days, the average person would hardly notice they were running that app inside a VM.
Another better solution would be to port Linux's userspace to run on top of macOS, like Microsoft did with WSL. Not sure that's really worth the effort given how easy it is to spin up a VM, but it is another alternative.
I remember when Apple announced Apple Silicon Macs there were a lot of people claiming how it was going to crater their market because so many people dual boot Windows. Turns out that was never a big market, because it is a real pain in the ass to work that way.
Reactions: Io Magnesso
CouncilorIrissa
654
2,529
The choice isn't between a native app vs a React Native app. The choice is between a React Native app and no app.
moinmoin
5,225
8,413
That's silly. macOS already has been Unix based since the move to X/NextStep. A Mac user is a brew install away from most Linux CLI applications. That's one major reason why Macs are popular with web developers. WSL was actually Microsoft catching up with that after 15 years.
Reactions: dacostafilipe
Io Magnesso
164
56
56
Homebrew is just a package manager after all
The Linux package doesn't work when you install Homebrew
Only software made in accordance with POSIX is compatible with Linux
moinmoin
5,225
8,413
What's a "Linux package"? There are plenty different package managers for different Linux distributions. What does it matter whether homebrew is "just" a package manager as well?
Point is you can install and run plenty CLI applications under Linux, Darwin (macOS) and other UNIX based systems. Windows wasn't among them before WSL.
Io Magnesso
164
56
56
Certainly, the number may be smaller than the Unix OS. but Windows also had multiple CLI applications prior to the launch of WSL
I guess it depends on the human interpretation...
Io Magnesso
164
56
56
Windows commands and powershell are completely incompatible to typical UNIX shells like bash, sh or in current macOS' case zsh.
Your comments so far are correct
However, please disagree with this comment.
Sorry for my poor explanation, but...
What I wanted to say is that even if you put homebrew in, you can still do the Unix standard (POSIX) Conformance.
Of course, shell commands and shell scripts can perform the same operation as long as they have the same shell.
However "Linux CLI Application" does not always work on macOS
No, it may be better to say "it depends on the situation whether you can access it rather than Behavior".
If you want to run a Linux (CLI/CUI or GUI) application completely, You have to prepare a separate Linux Kernel in some way
For example, containerization
I wanted to say the above in this comment.
Sorry for the misunderstanding
It's also unfashionable to talk about it in an Intel CPU thread any more.
If you want to keep talking with me, let's go to the software forum.
moinmoin
5,225
8,413
There is no such thing as a "Linux CLI Application", Linux is just the kernel. It's all about the so called userland, so the chosen shell environment and installed applications therein. Typical Linux and BSD distributions, UNIX systems and macOS are all pretty close by default or can easily be made close by installing commonly used applications which again is easily done with package managers. Not so with Windows.
I'm honestly am not really interested in further pursuing this particular topic. I just think it's important to correct misleading statements wherever they are made.
Fjodor2001
4,097
520
Do we have any expected release date for NVL-S? I'm guessing it'll be some time soon after 2026-10-13.
Reasoning:
* Windows 10 EOL is 2025-10-14 (after which you won't get security updates)
-Has been extended to 2026-10-13 if you agree to sync your system settings to your Windows account (i.e. pay for the extended lifetime by selling your user data to MS). After that date you won't get any updates.
* Windows 12 - Unknown release date. Sometime in 2026? Likely just after 2026-10-13.
I guess most users that are on non-Win11 compliant HW would like to wait for both Win12 and NVL-S before upgrading, since NVL-S is expected to be a major upgrade.
But I suspect MS policy will go against that. So I'm expecting a NVL-S release at some time after 2026-10-13, meaning that users that are on non-Win11 compliant HW will be forced to either:
a) Before 2025-10-14 get a new PC with current generation CPU which supports Win11. Then upgrade to NVL-S and Win12 soon after that (if they want that).
b) Sell their user data to MS to get Win10 support until 2026-10-13, and then upgrade to NVL-S + Win12.
In short: MS wants to either push you onto Win11 (before upgrading to Win12 shortly after), or to sell your user data to MS.
