Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 679 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
763
719
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
AcrosTinus
191
195
Thank you to the person who told me to ask Intel for a refund. I did just that and they are going to refund me the purchase price of my 14900K. Looks like I'm moving to AMD.
I don't want to be an AMD hater but never forget that AMD still sucks in these departments (I have a 7950x as a server):
  • Worse Chipset, connected over 4xLanes
  • Worse storage performance compared to raptor lake
  • 6000Mhz ram speed ceiling, infinity fabric limit
  • chiplets on mainstream have one GMI link, leading to lower memory bandwidth than raptor lake
  • Lower memory bandwidth limits the advantage of AVX512
  • very good gaming but only on x3D, standard parts are a regression compared to raptor lake
  • slow boot times, memory training
  • flaky usb speeds that changes with every agesa update due to mainboards integrating many more chips from other vendors compared to Intel.
  • Issue with 8K polling rate peripherals
  • very bad IGPU with bad encoder and decoder support, and very bad H.264 quality
I would wait for the 9950x3D or the fix for Arrow Lake.
Of course you could also go all out on a Threadripper 7960x on an Asus SAGE.
Hulk
3,650
Uh oh, analysis paralysis incoming.
Thunder 57
3,747
6,334
I know this is an Intel thread, so I will tread lightly. I mean, I could argue some of these but I'll leave it to one.
In what world is that a "regression"? A regression in gaming would be a 14900K to a 285K. AMD hasen't had a regrssion since Bulldozer and even then it depended on the application. This basically reads as AMD sucks because all this, but I'm unbiased because I have a 7950X. @Hulk was right.
gdansk
4,161
6,949
Don't forget Intel sold you broken chips.
Intel doesn't have AVX512 support.
Does AMD need faster than 6000MHz memory to be faster than the 285K in gaming?
Are you using an 8000Hz mouse? Do you plan to?
The slow boot times are an issue that was fixed nearly 2 years ago. It's still slower than Intel DDR5 boards but not a lot.
USB does seem to be an issue for some people.
Are you planning to use a bunch of drives connected to the chipset instead of directly to the CPU?
Do you use your iGPU? You will probably use your graphics card unless you're in an unusual scenario like using a 9950X as a plex server.
Most these criticisms are not relevant to most people. Personally I would take being sold broken chips as a clear message to at least try the competition. But maybe try to wait for the 9950X3D if you care about having 5% better rather than 5% worse gaming performance.
DavidC1
1,546
2,555
They themselves don't expect meaningful revenue till 27 so we should know there is nothing material now for external
In comparison to Samsung Intel wins easily just the fact that Intel's own volume is more than Samsung currently(samsung counts internal volume as well in their foundry) they are number 2 foundry and they don't have samsung bad yield hell Intel 3 is already at good D0 and is producing more wafers now and very large one have any of samsung recent node done that ?
It is unfair to samsung 🤣 cause intel is killing it in comparison
Why does that matter? Intel as a whole is actually in some financial trouble while Samsung is a conglomerate and does well in many other markets. Intel is a dedicated computer chip maker where their own product division is reluctant to use the in-house manufacturing division.
It's not even remotely comparable. If Intel Foundry lost internal sales then they are done. Samsung can not only afford to do this, it wasn't their main business anyway.
More importantly, Samsung had and still has notable customers. Intel is at zero.
poke01
3,544
4,874
These are the only big ones for me but none of these is equal to a CPU failing. I would pick AMD anyday over raptor lake
I notice the weak USB speeds. My 7700X system is slower in external SSD R/W than my 2019 i7 9750H Macbook.
511
2,522
2,358
If you put entire samsung conglomerate than any company is going to struggle to compete but I won't deny Intel's life hangs on the line and Samsung doesn't but if you compare the foundry part Intel is superior than Samsung
AcrosTinus
191
195
I never said that these are deal breakers, I even mentioned ahead that I use the 7950x in my server build, hence these are the problems I encounter. Here Intel is still ahead and I guess AMD will catch up as the userbase is steadily increasing.
I was sold broken stuff by AMD as well in the Phenom days, they were failing in a 6M interval but here in Germany, we kept on buying due to the sentiment of supporting the little guy. So one fail from a company does not taint my view of them. These are super complex items where issues are preprogrammed, It even amazes me that things work in the first place.
My encouragement to go 9950x3D still stands, even the 7960x Threadripper route might be viable or the Zen5 version of that.
AcrosTinus
191
195
As I said, these are not deal breaker issues, I just encounter them using my AMD server. Each vendor has their pros and cons, I even encouraged to still go AMD if the mentioned issues are minor.
Furthermore don't forget that AMD had CPUs failing too in the past but people forget (Phenom days), I just don't use one fail to call in the death of Intel. If they had 4 generation fail or had a history of that I would agree, but this is one generation and will never use an outlier to destroy Intel's reputation of stability.
True that reputation is now tainted but in all honesty this is the first time in 17 to 20 years I have been dealing with Intel that they even failed this hard in the stability department.
Reactions: poke01
Markfw
May 16, 2002
27,059
15,994
Where is Intel still ahead ? curious, as I am not aware of any place that they are ahead.
511
2,522
2,358
Can we skip the Raptor Lake debacle in this thread we have a seperate thread no vendor is clean in this regard point is After Kranzich we had stagnation and what not with intel and ut will take time for them to sort their mess AMD sorted their mess and are in good position now
Kocicak
1,177
1,232
The most clever thing to do: get a new cheap 14700K, pocket the difference, set the frequency limits so that it lasts, enjoy it and start choosing your next platform the next year or even later.
  • Love
Reactions: 511 and Hulk
Kocicak
1,177
1,232
Oxidation counts as a major defect.
Yeah, sure. So far the oxidation problem is a tale with no concrete information about what products, batches etc are affected. The products are sold with warranty and only Intel cares about the reasons why their product failed, customer does not need to care - they just get a new CPU.
