Page 682 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
921
836
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
AcrosTinus
221
226
I went through the hassle of testing the storage performance of my Raptor Lake system 14900K unleashed vs 7950x3D vs U9 285K.
Conclusion: 14900K@5,8Ghz>7950x3D>>>> U9 285K.
The test was done with 2x900P 280GB in Raid0 as well as a P5800x 400GB using CrystalDiskMark 8.0.4 on Windows 11 Pro 24H2 with virtualization on as well as the core isolation enabled.
The drives were connected if possible to the CPU Lanes using a U.2 adapter card or a m.2 to slim SAS with a redriver (switches were left default). Cable Length is 50cm.
  • Sequential throughput is mostly the same across all platforms.
  • Biggest Difference in the Q1T1 RND4K
    • 14900K:
      • > 450MB/s Read // 396MB/s Write (P5800x)
      • > 310MB/s Read // 295MB/s Write (2x900P SW Raid0)
    • 7950x:
      • > 360MB/s Read // 285MB/s Write (P5800x)
      • > 250MB/s Read // 276MB/s Write (2x900P SW Raid0)
    • U9 285K:
      • > 180MB/s Read // 120MB/s Write (P5800x)
      • > 165MB/s Read // 76MB/s Write (2x900P SW Raid0)
Funny result, the IO die on Intel is a shame, even AMD can realize the Optane advantage. Only the U285 had worse load times in all respects.
AMD has somehow managed to craft a lower latency chiplet architecture that has latency so good that you won't be feeling the difference even on Optane.
SAD!
Hulk
3,862
    • 14900K:
    • 7950x:
    • U9 285K:
SAD!
Do you have a 285K rig? If so can you run our Handbrake benchmark?
DavidC1
2,021
3,157
Big question... ARL-U has HT?
If not... damn Intel is speedrunning to end the U tier.
Very likely. Lion Cove doesn't have HT at all. ARL-U uses Redwood Cove core.
The things exist50 says is amusing. He's basically completely discrediting Intel's claim that MoP on Lunarlake is to save cost, because ultimately a worst product will cancel out any lower costs.
There is some merit to this. My laptop with Kabylake-Y and LPDDR3 memory doesn't go below 0.6W. On Lunarlake I saw it low as 0.2W. Now, MoP isn't enough, you have to optimize for it. But in Lunarlake it does. Lunarlake's MoP is offering anywhere from 10-15% battery life increase by itself.
So Intel was focusing too much on margins that led them to this mess today, and because of that mess and resulting low revenue they are focusing on margins even more.
511
5,124
4,606
    • 14900K:
    • 7950x:
    • U9 285K:
SAD!
Also Intel has accidentally crafted 13/14th gen that is giving everyone trouble in area like these it's 10th -> 11th gen fiasco all over again 🤣
511
5,124
4,606
If it was Intel's Fab they would have saved the cost
As for this they specifically said they optimised the PHY for low power and it is showing PTL is going to regress how much depends on whether PMICs are used or not cause MOP ks not coming
majord
509
711
thanks. Sorry i'm a bit behind on the full notebook stack , Seems strange to use the Arrowlike nomenclature without LNC/ . So these are sort of budget, mass-market chips? are there no lion cove /Skymont based higher core count U parts? I'm just trying to visualise what the halo parts are in various TDP classes. Obviously Luna lake there for very low core count, low power, then it seems like a performance gap between that and the LNC/SKY based H / HX parts?
Kocicak
1,177
1,232
    • 14900K:
    • 7950x:
    • U9 285K:
Interesting results, do you have the complete result screenshots? Would anything change, if you used a "leashed" 14900K?
coercitiv
7,447
17,752
The halo part for the U class is Lunar Lake. It might struggle against ARL-U @ 28W in "Cinebench", but should be superior in all aspects that really matter, except cost ofc.
SteinFG
737
872
Intel is being shady. It is an small upgrade over Meteor lake, cause ARL-U chips have higher boost clock, but that's pretty much it
Yeah, 2P+8E for mainstream.
LNL (lunar lake) is 4P+4E, tdp is configurable from 8 to 30W. It's a halo part in its TDP range.
ARL-H is 6P+8E. most likely 30 to 65W tdp (following MTL-H tdp numbers). It's a halo part in its TDP range.
Both lunar lake and arrow lake-H have new cores (lion cove and skymont). And with such core counts and TDP ranges, there is no need for something in-between.
Reactions: majord
511
5,124
4,606
ARL-U is way inexpensive compared to LNL that it is hilarious and regarding battery life MTL-U/ARL-U have better battery life than H comparison not good as lnl but very good and for cheap
96mm2 N6 SOC
10mm2 IO
40mm2 CPU on Intel 3
24mm2 GPU Die
coercitiv
7,447
17,752
The halo part for low-power class is Lunar Lake V series.
Sorry, had to nitpick a bit 😛 though I totally get what you're saying
I stand by my correct use of "U class" according to certified British classification:
On a more serious note, while I agree LNL is supposed to be the halo for a "low-power class" mobile chips, I disagree with the idea that "low-power" goes up to 30W and therefore I don't consider U series to be "low-power" CPUs. That's why I used the rather awkward "U class" term.
dttprofessor
163
45
96mm2 N6 SOC
10mm2 IO
24mm2 GPU Die
It‘s not good compare to 8845,but not bad for U15.
511
5,124
4,606
Doubt it's less expensive than hawk point, TSMC keeps raising prices and theres Foveros overhead as well
You know that tsmc raised Price on 5/3 nm class node N6 was low utilisation vs 5/3 nm and the only N5 die is 23mm2 which is getting raised which will not affect it much and the price raise is customer dependent we all know for sure who is getting the price raised the most everyone will not get the same increase the highest leak was 10% 🙂
AcrosTinus
221
226
No, it is not my own rig, a friend wanted to build a new machine (he is still on a 6700K,1070Ti) and I convinced him to buy Arrow Lake, what a good friend I am I know. While assembling the machine I ran some benches.
  • Love
5,124
4,606
Lol should have at least bought him 265K and put the money in 4090 or saved the money 🤣
19,203
No, I fully support you being a GOOD friend because coming from a 6700K, that is INDEED a huge upgrade for him.
