gaidensensei
Banned
Thats what the eternal warriors ring is for 😉
😀 Did you know it shaves half a second (0.6) stamina regen seconds at maximum?
That's how crazy I was with knowing about Demon's souls mechanics. :sneaky:
Thanks a lot. Yeah, I'll probably work on getting intel to 14-15 for 2 slots, and then 18 later on.Enchant magic and MAG weapon builds are based on MAG, like all stats it starts the first diminishing return around 30+, then the second severe return at 40+. Same thing goes on with STR DEX Faith etc.
INT is useless except for the mp and the slots it awards. I believe it's the second slot at 15 int, the third is 18 int.
For STR and DEX builds, in PvP most of them will use Cursed Weapon (gives a purple weapon aura), which requires 3 slots. Cursed weapon is a flat out +50% bonus to overall weapon attack, stacked with the bonus. You also lose a fixed percent of health per each hit, similar to Hiltless katana.
Magic weapon, on the other hand is a flat direct damage.. It also only requires 2 slots. I think it was like +100 magic damage or something over that, and there's a small modifier so when you add more MAG it goes like 100 + modifier*points added.. This is the stronger version of enchant weapon.
Based on your build, it's up to you which direction you want to take. Are you a PvP type, or are you a PvE. PvP tweak their characters to allocate the most they can get out for their soul level. PvE you can pretty much be all rounded and get by. In NG+ and after though, all monsters gain a huge innate resistance to magic damage and (speculated) some physical damage as well.
An STR build for PVP at level 100 would be something like, for cursed weapon:
STR 40+
DEX base or depends on final weapon choice.
VIT 40+
END 40 (stamina cap)
INT 18
Magic, Faith, Luck base.
Weapon: usually a Crushing +5 2h based weapon, like Crescent Axe (2h) or Great sword/Claymore -> instead of running around swinging like a fool, they do roll + r1 for a ~360 degree spin attack.
There are also 1h Crushing users though, Guillotine Axe is fairly popular.
The goal with 2h crushing builds are to knock down and beat their foes in a couple of hits.
Oh yeah, you CAN'T use warding and magic/cursing/enchant weapon at the same time.
My bad for wrong information. There's something I remember that can't stack with warding, what was it?
If you want to use the meat cleaver, you should either make a dex build or a str build. As the meat cleaver has an S rank in both dex and str - you don't need to get them both to high levels. If I were you I would make a str build. Thats what I'm in the process of doing and hes my strongest character so far. I've had magic, dex and faith builds. Cursed DBS +5 is hard to beat.
currently I'm a strength build, but going through the playthrough, the ability to do high damage with arrows is so useful. Makes bosses soooo much easier. I figure if I can have a good end game PvP build that makes the playthrough easier, then I'll choose that.
Just use the lava bow and you wont have to worry about dex
I'll try that, have to get enough hardstones to get +7 though.
You can buy them for pretty cheap from the merchant in 2-1 and 2-2.
I think he's in 2-2 now. Only thing is, I've never actually been to him. I found the long path to flamelurker confusing with all those bugbears, so I've just avoided that area and used the short one. Guess I'll go farm souls and just buy a ton.
iirc, he actually doesn't move on. He stays at both locations, but only sells the large shards in 2-2.
I just got my str build up to lvl 60 last night. He has 31 str with the DBS+5/enchant weapon and I am just 1 hitting people in pvp, its awesome lol - Its already is doing over 600dmg
Something to note, I think it's really a competition between, Great Axe, Meat Cleaver, and DBS.I've used both the meat cleaver and the DBS and the DBS just feels like it has more range. I invade 1/4 or 4/1 in soul form or just wait around in body form. I'm going to get the meat clever when I get home from work and see how it compares to the DBS+5 on my str build.
My biggest problem seems to be that I really want to get pure black, but playing online, it seems the entire world is pure white all the time? Is it really pure white? Because it's bright. Even after invading and killing 1 person, then dieing, I still see light, like it's not even back at neutral in a world. Pain in the ass.
I need pure white to get DBS, not sure how to do that. My character tendency is at pure black from invading so damn much so I have poor health. 🙁. Need to farm greystones, but I don't feel like using ephemeral stones yet. Save it for later. Also need to grab colorless. I wish there was a guide listing the pics and the specific number so I could check. Going by the brightness is a bit difficult.
Invading doesn't change your world tendency only character. If you want to get back to white character tendency, just put your blue soul sign down and help other people. Also, when you log off and log back on, your worlds go back to neutral.
I thought my world only went back to neutral if I logged off in the nexus.
I know invading only changes character tendency, but I swear i thought killing someone lowered your world tendency by 1 in that world. guess I was wrong. Oh well, seems the easiest way to do it is to regain my body then by beating bosses, and then just repeatedly dieing.
An easy way to get Pure white world tendency is just go to stone fang and beat all the bosses without dying in body form.
If you log off the DS servers while in a world then log back on your world tendency will be the same, but once you go back to the nexus it will be reset.
If you want to get pure black world tendency, just use an ephemeral eye and kill yourself, don't let enemies kill you. Repeat 5 times and go back to the nexus to see your world tendency change.
