Asrock Z77 Extreme 4 Owners Thread
Discussion in 'Motherboards' started by HexiumVII, May 7, 2012.
  1. WiseUp216
    WiseUp216 Platinum Member
    Mar 12, 2012
    2,134
    11
    Either one will be fine.
  2. davidthemaster3
    Mar 11, 2011
    190
    Either one is fine. I had a CM Hyper 212+ before and then I switched to a Noctua NH-D14 and it didn't seem to be a problem.
    #177 davidthemaster3, Nov 8, 2012
  3. Deaks2
    Deaks2 Member
    Oct 6, 2006
    93
    I have a CNPS10X hanging off of mine. No issues thus far.
  4. Nohr
    Nohr Diamond Member
    Jan 6, 2001
    7,268
    4
    2.50 is out.
  5. Despoiler
    Despoiler Golden Member
    Nov 10, 2007
    1,136
    17
    Nice because their last BIOS to improve compatibility still had issues.
  6. Knytestorme
    Knytestorme Member
    Sep 12, 2005
    52
    Made the shift from X58 to this and a 3770k last night to see if it fixed the 7970 hardlock problems I was having.
    So far it seems good, though I didn't realise it wasn't ATX size until I went to put it in the HAF-X and found the 3rd row of stands to be useless lol....also, has anyone else had issues with the driver cd not running under Windows 8? I get read-access error when I try to use the "Install All" option and not sure if it's due to Windows 8 compatability issues or just a scratched disc.
  7. Despoiler
    Nov 10, 2007
    1,136
    17
    Don't use the driver CD. Download the newest files from Asrock's website.
  8. Ksyder
    Ksyder Golden Member
    Feb 14, 2006
    1,828
    I just picked up one of these boards with an i3-3225 and 8gb of Corsair Dominator ram. Looking to make into a near-silent htpc that does dvr recording from 2 hauppauge hvr-2250 tuners. Also have a Seasonic ss-400fl fanless psu on the way to complete it.
    The crazy part is that the only fan I plan on having is one Scythe low rpm 120 mm fan on the rear of the case. The cpu/gpu (lol) is being cooled by a coolermaster hyper 212 evo with the fan taken off. As far as hdd's go, I have a couple of samsung 2tb 5400 drives for storage.
    Is this going to be alright in terms of heat?
  9. Ksyder
    Feb 14, 2006
    1,828
  10. yothiele
    yothiele Junior Member
    Nov 18, 2012
    Hey all.
    Building my first computer soon. Just waiting on parts.
    ASRock Z77 Extreme 4 LGA 1155
    Intel i5 3570k
    32gb Mushkin Memory
    XFX 3Gig Radeon 7952
    My question after reading this forum is, given that the mobo is not full ATX size, do I only mount using 6 screws instead of the regular 9, and just let the bottom hang free?
    #185 yothiele, Nov 18, 2012
  11. Ksyder
    Feb 14, 2006
    1,828
    Can't remember how many screws exactly there are on the board, but the bottom will not hang free, but the right side will since the board is not wide enough to reach the right most standoffs. An easy solution to this would be to get some plastic standoffs with the flat bottom that connect to the board with pushpins.
    something like this: http://icrontic.com/draco/images/ar...rtainment_pc_part_2_motherboards/standoff.jpg
  12. lkailburn
    lkailburn Senior member
    Apr 8, 2006
    338
    uhhhhh wtf do I do. Loaded up the 2.5 file on a fat32 thumbdrive, went into bios and selected instant flash. A popup showed in bios and I saw the 2.5 file and then immediately the monitor turned off. Been waiting for 5 minutes now.
    The code on the LED on the mobo is 64 which from the book says "CPU DXE initialization (CPU module specific)?
    I'm new to these fancier mobo's and freak out when there's a flash update problem. I poked the little reset button inside on the motherboard and i'm back into windows. Maybe i'll download another fresh copy of 2.5 and try again. I was successful in loading 2.4 using the same thumb drive maybe a month ago
    #187 lkailburn, Nov 20, 2012
  13. Rhezuss
    Rhezuss Diamond Member
    Jan 31, 2006
    4,037
    Damn on Newegg.ca, whe you buy the ASRock Z77 Extreme 4 they give you a 70$ Gift Card redeemable at Newegg.ca...that would make a i5 3570K really cheap!!!!!!!!!!!!!!!!!!!!!
    I'm sooo tempted right now!
  14. Deaks2
    Deaks2 Member
    Oct 6, 2006
    93
    Do it :p
  15. Rhezuss
    Jan 31, 2006
    4,037
    Please stop...
  16. davidthemaster3
    Mar 11, 2011
    190
    Buy three get one free :D
  17. Rhezuss
    Jan 31, 2006
    4,037
    LOL!
    The deed is done...ordered the Extreme 4 a minute ago. That 70CAD gift card sealed the deal...the i5 3570K will cost nothing!!!!!
    I'll try selling my M4A77D+PII X4 955+Xigmatek Cobra HSF+6gb DDR2-800 for a good price after I install everything. Will lower even more the cost of that upgrade.
    At least i'll be able to finally use my G.Skill Ares 8gb DDR3-1866 I have since last month!
  18. OVerLoRDI
    OVerLoRDI Diamond Member
    Jan 22, 2006
    5,475
    Wow, that is a solid deal.
  19. Remobz
    Remobz Platinum Member
    Jun 9, 2005
    2,452
    Would this board be overkill if someone had an Ivy i5 3550?
    With no intentions of overclocking.
    Or some good but cheaper board like the B75 would be more appropriate?
  20. pauldun170
    pauldun170 Diamond Member
    Sep 26, 2011
    3,836
    137
    My board came with 2.20
    To update my bios to 2.5, I went into UEFI and ran the internet update.
    Quick and easy.
  21. lkailburn
    Apr 8, 2006
    338
    ^ I might try that next time
  22. pauldun170
    Sep 26, 2011
    3,836
    137
    Just noticed in fan profiles that you can now set custom speeds (vs levels). Cool
  23. Rhezuss
    Jan 31, 2006
    4,037
  24. RJRD2
    RJRD2 Senior member
    Mar 10, 2000
    642
    guys pretty simple question. will 560ti fit in this board.
    I have
    EVGA GeForce GTX 560 Ti Superclocked 1024 MB GDDR5 PCI Express 2.0
    01G-P3-1563-AR
    some guy on newegg said it wont fit. heres the review.
    Cons: I cannot believe they messed this up. GTX 560 Ti's and relatively sized GPU's do not fit into the socket. I have to return the whole motherboard just for this little mishap.
  25. WiseUp216
    Mar 12, 2012
    2,134
    11
    The motherboard doesn't have anything to do with whatever his problem is. You could fit two of those cards on this motherboard.
