MrMatt
Banned
- Mar 3, 2009
- 3,905
- 7
- 0
I never said bulking meant you get fat. I was talking about "quick bulking" and of course it correlates with fat or you would never need to cut. Is it really any surprise that a quick bulk requires a cut cycle after it? You are basically increasing your calories (in some cases by a shit ton) and doing roughly the same amount of work. Alllll those unspent calories go somewhere and they don't all magically turn into muscle no matter how badly you want them to.
And last I checked, the best way to avoid stretch marks was to avoid sudden weight gain and make gradual changes.
That's not to say 12lbs in 12weeks is ridiculous either but some of the other numbers thrown around this thread have been a bit ridiculous. I still believe he should focus on his lifts instead of hyper-analyzing his weight numbers and trying to make judgment calls from them.
I think 12 lbs. in 12 weeks of lean body mass is easily doable, I will say that. I'm not sure what the OP is doing exactly to fuck this up so bad....
