Page 981 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
inquiss
649
914
Single CCD Strix Halo doesn't exist, and probably never will. If someone wants to pay for the design ala MS/Sony and have the chips fabbed separately then so be it. Thus far nobody seems to be lining up to do so. AMD isn't going to carry another SKU in hopes that people will use it in handhelds.
What? It's a 2 CCD design. They just omit one of the CCDs.
Josh128
Banned
Oct 14, 2022
1,542
2,297
Yeah, it does >2x here at ~45-50W and these game settings, but the entire dynamic changes as you go up or down in power levels and resolutions. e.g. @ 15W I doubt Halo would have much of an advantage, if any. @4K, Halo might do more than 3x Point due to mem bottlenecks on Point, etc.
Thats my point about Switch 2. That thing almost certainly operates sub 10W (maybe significantly less) in hh mode, yet by most accounts can produce some pretty kick-ass visuals considering that.
It all comes down to the targeted power envelopes /sweet spots for each SOC.
Jun 1, 2024
983
1,095
TBH this is the future of laptops
handheld high end APU w HDMI into portable foldable OLED and optional dock with extra cooling and fans for higher W
I tried the Asus Halo 13'' tablet, it's supposed to weigh 1.2kg (super lightweight) but it felt way way way heavier than the 2.5kg 9955hx3d strix g16 laptop... I guess weight uniformity, too much density in a 13'' laptop
itsmydamnation
3,147
4,041
it all depends on voltage , if there is little voltage difference between 50watt and 20watt sure. but if those CU's can run at low voltage you will be well wrong.
DrMrLordX
23,233
13,324
Carrying a separate SKU incurs costs. Unless some would-be handheld manufacturer specifically requests the design (and if they requested such a thing, they'd be insane, when AMD could sell them something semicustom that would do the job much better), it's not happening. At least not with 8060S.
There is one, with 32CUs instead of 40.
Yeah that doesn't have the full iGPU so it's not really applicable to the discussion. Yes it's technically Strix Halo, but . . .
Reactions: ToTTenTranz
LightningZ71
2,717
3,423
It is though. The Z2E is STP minus a couple of cores. AMD isn't above making specific gaming SKUs. They already have a packaging process for single CCD SKUs. It's literally just choosing to bin a specific way.
Given the low volumes of handhelds at the top end in general, the number of IOD that get produced with a faulty CCD link but are otherwise whole in the iGPU may be sufficient to cover that market...
Abwx
12,038
5,013
Power scaling :
Det0x
1,490
5,121
Dont know anyone who seriously use ryzen master as its a resource drain on your system, and half of the time it don't even work properly
Would much rather recommend something like ryzen debugtool as a much lighter and better application for Zen overclocking
Its made from the same auther as Zentimings
Asus "worktool" is also a good option if your rocking a asus motherboard
dr1337
548
837
Thats weird, I've never had issues with ryzen master across several builds.
do these tools actually tell you anything that RM wouldn't?
DrMrLordX
23,233
13,324
32 CUs is not that much less, so much that there s a STH 385 variant of this handeld.
That's still a relatively poor compromise for a gaming handheld that's so heavily biased towards CPU performance. Compare the resource balance to something like the PS4 or 5 for example. Or really any purpose-built AMD chipset for consoles.
LightningZ71
2,717
3,423
Roughly the same performance as a game system with a 9700x on eco mode with a 7600 video card without the vram or PCIe bus choke points is fine for a small 1080p screen. No one is going to have anything real to complain about for performance or image quality undocked.
Josh128
Banned
Oct 14, 2022
1,542
2,297
Same. There is zero reason to use it instead of just going into the BIOS. Its not as reliable and requires reboots anyway.
19,219
Not my experience. If you mess something up with Ryzen Master, you can usually get into the BIOS to boot with default settings. But mess something up in BIOS and it's CMOS reset time which is way more annoying. I enjoyed using Ryzen Master because of this. Intel seems to have gone the other way with their latest XTU. You can make your system unbootable with XTU and then require a CMOS reset to boot.
Reactions: Mopetar
