Page 922 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Jun 1, 2024
983
1,095
Apropos practical reality. You must have missed at least two thirds of my post, if not more. I direct your attention to just the topmost of the several parts of my post:
Even if we restrict ourselves to a PC with the power and performance level of the 7945HX (and which GPU?), your portable computer is a *lot* louder than a decently built stationary computer. Furthermore, keyboard and screen of your portable computer are bolted onto each other and are therefore by definition not ergonomic. Unhealthy in prolonged use.
oh come on bro
ergonomics: laptop wins period. use it as-is or with peripherals monitors keybmouse etc. no questions
performance: 10-30% delta at most, always. that's like 70fps instead of 90fps.
economics: lower or same prices. you can have just 1 computer and take it anywhere you want
again, in the next years this will be a reality: unless you're an enthusiast or a passionate overclocker g4m3r 4k 420fps no scope there will be no point for client desktop PCs.
laptops or workstations (threadripper/epyc)
(still for professional reasons 9950x pcs are easier to find/build than TR/epyc so this is a factor too)
Jun 1, 2024
983
1,095
I joined 7 months ago and already made 4 prophetic posts that became reality.....
Admins thought my comment about Gelsinger dancing desperately was very offtopic, 2 months later he was 'fired'
Here is another prophecy: the Fall of the Desktop, Crumbling Under the Superior Ergonomics, Economics and Performance/Convenience ratio of the Beast Ultrabook
coming soon to a theater near you, I will make sure to notify you all when it happens
with the prophecy foretold, we can move on from the offtopic the admins will be mad at me again 🤣
Glo.
5,930
4,991
No.
The ISA games are compiled into is mostly a non factor. You write in C or whatever and compile it, and it doesn't matter much whether it compiles into x86 or ARM. You might call some libraries or even write a few short assembler sections in tight loops to insure the best SIMD code can be used, that's about it.
The difficulty in writing and porting games is in everything that surrounds that code you write - the OS and GPU drivers. Having competitive ARM SoCs does nothing to help Android games run on Windows.
Absolutely nobody have said anything about scaling Andoid Apps to Windows.
I was talking, for very reasons you mentioned, about scaling Android OS to desktop and laptop form factors.
Vertical integration of Android ecosystem with ARM chips becomes absolutely possible now.
Josh128
Banned
Oct 14, 2022
1,542
2,297
It's not N3e.
Either N3p or N2p/x, depending on the timeline.
Wont be N2 unless its still 3 years out. N3P is possible, but so is N3E. Either way, max frequencies arent going up, and it will bring a ~10% IPC uplift. Most important changes will be in idle power consumption, 12 or 16 core CCX for consumer, memory controller/subsystem/interconnect, iGPU.
Josh128
Banned
Oct 14, 2022
1,542
2,297
[citation needed]
Im talking about consumer Zen 6. It will not use N2. Enterprise will use 2nm for dense just like Zen 5 did. We have the roadmap, it was 100% accurate for Zen 5. The only possible thing that could change is if 2nm gets delayed. Zen 6 +10% IPC. Only mysteries will be what they choose to do with X3D this go round. Mark it.
CouncilorIrissa
789
2,858
I'm aware of the slide. It does not say anything about clock speeds.
The slide is also not entirely correct wrt/ Zen 5. There is no low power option (yet at least).
Josh128
Banned
Oct 14, 2022
1,542
2,297
Its correct. Depending on what its referring to, which is not entirely clear, there's low power cores in Strix Halo (this is probably what its referring to), low power 5c cores in Strix and Krackan Point, and low power Zen 5c 3nm cores in EPYC.
CouncilorIrissa
789
2,858
No? The official term for 5c is "Dense". You don't need to go further than the Zen 4 roadmap item to verify that.
Josh128
Banned
Oct 14, 2022
1,542
2,297
From ChipsNCheese:
So the CCDs that are featured to a first order in the desktop part, they have an actual PHY that connects the two dies. And so there is there's actually a distance that it needs to travel. It's a SERDES and you're able to go some distance between the two. That's how we've always connected the two. And that's a low cost interface, if you will. It is a high bandwidth interface. But that had low power states that could only take it so far. And you had retraining and latency implications every time the chip went down and came back up and so on. So for an always on kind of a desktop kind of machine, that seemed like the best interconnect to connect that as we try to build this into an APU. The first thing we had to do was to change the interconnect between the two dies. And so the CCD that you see here, the core die that you see here, has a different item. That's the first change.
That's a sea of wires. We use fan out, we're for level fan out in order to connect the two dies. So you get the lower latency, the lower power, it's stateless. So we're able to just connect the data fabric through that connect interface into the CCD. So the first big change between a Granite or a 9950X3D and this the Strix Halo always the die to die interconnect. Low power, same high bandwidth, 32 bytes per cycle in both directions, lower latency. So everything that and almost instant on and off stateless because it's just a sea of wires going across. So it's a little [bit of a tradeoff] of course, the fabrication technology is more expensive than the one over there [points to a 9950X3D], but it meets the needs of the customer and the fact that it has to be a low power that can actually connect.
Josh128
Banned
Oct 14, 2022
1,542
2,297
Yes it does. Do you think they built a completely different CCD if they didnt need to?
19,219
coercitiv
7,510
17,967
You're quoting a typo in the transcript, what he actually said is the following:
And so the CCD that you see here, the core die that you see here, has a different die to die interface. That's the first change.
Timestamp from the video:
Later he goes into more details:
These have the 512 bit data path. It is a full desktop architecture. We have binned the parts for efficiency. So it might not hit the peak frequency that you would see on the desktop. That's one of the second differences in the cores you would find over here and the cores over there.
So these are binned, the same architecture, the same set of pipes, the data parts are the same. The differences are in how we bin the part and how we connect the two dies.
Hitman928
6,758
12,504
Even without the typo it was clear by the surrounding context they were talking about the d2d connection, but it’s good that the correct transcript says it outright.
Reactions: Tlh97 and MS_AT
Josh128
Banned
Oct 14, 2022
1,542
2,297
Die to die connection changes require a new die. This is done for low power, who here is disputing that? Its a new low power core option. You want low power cores, you need that different CCD and die to die connection. Its not mentioned, but probable, that the die to IOD connections differ as well, designed for power savings.
I still maintain that the roadmap is referring to the Strix Halo cores, as they are not C cores, yet can operate at much lower power than standard cores. Y'all dont believe that, fine. If thats not what the roadmap is referring to, its referring to something else that we dont yet know about or was an option they had but decided not to use. The point is, the roadmap is 100% legit and theres zero chance it didnt come from AMD. And while plans can change, there is absolutely no reason to expect more from Zen 6 than what it is projecting.
StefanR5R
6,854
11,036
No, they do not. They just require that the CCD features both interfaces. Same as MI300A, same as X3D, they all use the same CCDs as the vanilla products.
No. GMI is uncore.
Per-core power is "low" in several Turin SKUs as well.
