Page 910 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
fastandfurious6
984
1,092
If AMD really wants the laptop gaming performance crown, then they can release a 9745HX3D any day of the week. They didn't release that for Dragon range, and I suspect that won't do it this time either.
exactly they make a huge mistake on this - everyone would only buy 9745hx3d laptops, then halo for AI/workstation and some lower model for office/redundant. strix point makes no sense
they're losing so many opportunities to drive intel out of business lol
LightningZ71
2,694
3,394
They can supply to wherever they can make a profit. The issue is more that the laptop motherboards for these products are rather unique and, given the price range that they sell into, low volume. Since this generation is still on AM5, we'll likely see the few (only?) vendor(s) that made Zen4 series laptops reuse the same board and cases for these products.
I wanted to correct myself. It would have been named 9755HX3D...
Gideon
2,044
5,103
AMD also announced new handheld SKUs. I have to say I'm not the biggest fan of fitting 3 generations of products under the same name:
  • Zen 5 based 8-core 16CU "Z2 Extreme" (3xZen5 + 5x Zen5c)
  • Zen 4 based 8-core 12 CU "Z2"
  • Zen 3 based 4-core 12CU "Z2 Go"
The biggest thing is that Valve will use Z2 in Steam Deck!
The biggest upgrade there is the CPU side. Many games need more than 4 cores nowadays, but it's not even that. I think that quadrupling the L3 from 4MB -> 16MB is actually more benefitial to most games. Clock speeds upticks due to 7nm -> 5nm and Zen 4 don't hurt either. Valve could also use AVX-512 in proton or use x86-64-v4 based linux binaries (cause why not?).
The GPU upgrade is nice, but in 15W envelope, RDNA3 hasn't really outshown RDNA2 all that much. I wouldn't be surprised if the actual uplift is only 10-15% in GPU bound scenarios (unless Valve also upgrades memory).
The biggest thing for the GPU might turn out to be the eventual release of FSR 4, as RDNA3 should be ~2x faster using FP8 than RDNA2
LightningZ71
2,694
3,394
This was corrected. The slide isn't supposed to say that the Steam Deck will use the Z2. It's supposed to indicate that it would be good for similar type products.
LightningZ71
2,694
3,394
For the Z2 Go, I wonder if that is a specifically cut down Rembrandt based design? That's a LOT of wasted silicon to have 4 cores disabled just to keep the iGPU of the full die. It would make more sense to have a smaller, re-floorplanned die that dispenses with some of the unneeded parts of the die, like 4 cores, one PCIe root, a couple of USB roots, etc. Either that, or they got a good deal from TSMC for keeping older litho tools in use.
Is there even a substantive difference between the Z1 Extreme and the Z2? Did they take the time to shrink that one as well by lopping off the NPU, a PCIe and some USB? I kind of doubt that.
I don't even want to think about how bad some of the more heavily threaded games will suffer on the Z2Extreme. Those split CCXs will not be friendly to it, and having such limited L3 on the C cores will hurt.
WelshBloke
33,551
11,698
9800x3d vs 285k / 9950x3d vs 285k
From amd slides.
I've not really been keeping up with the rumours (or this thread tbh) but doesn't the 9950x3d have a higher boost click than the 9800x3d?
If so the 9800x3d in that chart is scoring higher because of its base clock being higher?
So if the 9950x3d should benefit more from a beefy AIO cooler more and pull ahead with a bit of tweaking?
Reactions: Joe NYC
Abwx
12,025
4,987
8C + L3 amount to 51mm2, so there s only 20mm2 lost, barely 10% of the chip surface, and they can sell it at 100$ and still get 60% gross margin, not counting that they can harvest chips with 1-4 bad cores.
gaav87
659
1,279
No clue i just used amd slides vs 285k
WelshBloke
33,551
11,698
I'm just speculating, its not like I can buy a 9800X3D at the moment, they are all oos!
*All the below is based on rumours!*
9950x3d matches the 9950x in cinebench which suggests they have the same clocks. Base 4.3, Boost 5.7
9800x3d has a base clock of 4.7 and boost of 5.2
So its going to be fun to see if the 9950x3d can be pushed up to match the 9800x3d base clock! It would be nice to have a CPU thats the best in nearly every situation!
CakeMonster
1,663
843
That's quite a regression for 9950X3D of several percent (3% and above, some very high) compared to 9800X3D in a significant number of games if I read those supposed stats correctly. Surely that's worse than 7950X3D over the corresponding part?
fastandfurious6
984
1,092
it's just scheduler shenanigans really, can't be otherwise
amd really lost an opportunity to do 2 things
1. 9950X3D with double Vcache - in each CCD
2. 9800HX3D 8 core 1ccd, mobile equivalent of 9800X3D & big market availability
if they did these two things they'd have complete market takeover in both top-end desktop and laptops
Reactions: Joe NYC
