Page 810 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tup3x
1,301
1,438
Yes. Why wouldnt it be?
Yes with cutdown AVX-512 to save die space
Zen 5 in Strix is far more different than RPC compared to GLC if anything.
It's not only the lack of 512-bit wide datapath, the vector PRF for 128- and 256-bit operations is smaller and the FADD latency is higher.
Yep. Cache or even manufacturing process means little. Zen 5 in Strix is indeed quite a bit different than on desktop (let alone monolithic die) yet it's indeed Zen 5. Considering how little has changed Intel side, it's fairly accurate to say that they are "pretty much the same thing" even though they aren't exactly the same thing.
Reactions: del42sa and Thibsie
MS_AT
936
1,856
I know what mysticial said.
Strix is also 2c effective and has the same scheduler hazard.
I am getting lost in the hazards, do you mean the scheduler hazard that adds 1 cycle latency to ops that are supposed to be 1 cycle only or is there some otherwise undocumented FADD specific scheduler hazard that prevents 2 cycle FADDs to be used every time? As according to all official info on the former, it shouldn't apply to FADD as FADD is anyway is at least 2 cycle op.
Thibsie
1,179
1,395
Was just trying to explain what I think Tup3x had in mind.
LightningZ71
2,692
3,392
Has anyone seen how Phoenix/Hawkpoint did after the windows updates and how they compare to Strix Point in ST and MT afterwards? I've been trawling the interwebz and haven't seen anything.
cellarnoise
860
451
The lack of Zen5 turin server stuff sucks... All you keep enjoying these toys :)
I want 64 core or more leaks, cause this is boring... HAHA
Markfw
May 16, 2002
27,403
16,251
10 October, (If my leaks are correct) I will fire up my Turin and give you some info !
Reactions: inf64
CakeMonster
1,662
843
AMD did say they will fix the core latency issue so hopefully more performance yet to be unlocked
If true, that's great for the people getting 1 CCX cpu's. But it doesn't make the 9950X with core parking mechanisms and thread prioritization schemes more attractive than a 7950X.
MS_AT
936
1,856
And did anyone check if core parking helps?:)
Mahboi
1,058
1,969
note to self: svgz images won't work.
image.php
I mean it looks stylish to see an 8 core Zen 5 beat Intel's best...but let's be honest nobody should care.
It's 50% more power draw on both the 6 and 8 cores. For a growth level of 10% at best.
Reactions: Tlh97 and Elfear
Philste
308
486
I'm surprised the extra power gives it so little. It's 50% more power for about 10% more perf. Absolutely not what I expected.
But why tho? There were plenty PBO Benches at Release Day, which showed the same 10% Uplift too.
Reactions: Thibsie
Mahboi
1,058
1,969
Well I was suspecting that the 8 core was seriously starved and would show more than 10% after the boost.
Turns out I was very wrong.
In2Photos
2,626
2,794
The crazy thing is had AMD released the 9700X as a 105W chip and it had the additional 10% uplift, no one would have cared what the results were at 65W. But since it was released at 65W and reviewed that way, now all anyone will talk about is the cost of the performance increase, i.e. 40% more power for only 10% more performance.
