Page 809 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
MS_AT
920
1,842
It's 36% performance gain, not IPC. An X925 clocked at 3.8 GHz will score ~3000 points in Geekbench 6 Single Core, on par with Lunar Lake and AMD Strix Point.
Wasn't this assuming so OS side patches, or something like that, I remember in footnotes they somehow alluded to tuned software for the highest perf improvement they quoted.
Ah, that would be unfortunate as it would suggest a cut down die, to be honest, or something that did not pass tests to become Strix Point, hmm
StefanR5R
6,821
10,901
Truly measuring IPC involves counting both the actual instructions and the actual cycles. Which is possible to do but somehow hardly anybody does.
The issue is that IPC might be misleading and not exactly what people are looking for. For example in Zen4 case, and avx512 vs avx2 […]
Yes; IPC measurements have their uses more (but not exclusively) in microbenchmarking and less in "macro"benchmarking. Hardly anybody performing IPC measurements is largely for the same reasons as hardly anybody performing microbenchmarking.
I'd love to get the average clocks per GB6 subtest with iso-cooling and iso-cache. It's simply hard data to get; that is, I hope I'm not inadvertently neglecting some great data sources that you might suggest? Anyone who's seen a clocks over time chart during a Geekbench run knows it's a mess.
Sounds as if we both conclude that Geekbench(6?) is not a very practical workload when the idea is to determine the influence of clock speed on performance. One could still resort to fixed-clock GB runs on platforms which support it. But this in turn would not say a lot about practical performance of GB-like workloads on platforms on which largely variable clock speed is part of the designed mode of operation.
my point was, that 5% gaming improvements weren't something unheard of before even across 2 generations. The whole media coverage of Zen5 sounds like it is an utter failure of a chip. Just going by the titles of some videos one could think it's actually worse than Bulldozer for gaming... It's a bit tiring. That's all.
"For most or all games we report on, CPU performance, as an isolated factor, has got only marginal influence on game performance. Get back with us in five years or so for any updates on the state of affairs" is not something many media outlets would be comfortable with to spell out to their readership or viewership.
Reactions: Thibsie
LightningZ71
2,656
3,340
Isn't there already a cut down version of Strix with 4+6 and 75% iGPU at greatly reduced clocks?
Cutting down much farther for anything other than an OEM specific recovery dump is just weird and counterproductive.
Reactions: SteinFG
Josh128
1,505
2,256
Looks like another WR for Zen 5. Architecture has potential, just doesnt look like it really can be fully realized with 4nm and current IOD/mem setup. 353W for 60K on 4nm.
Raptor Lakes best submission is 452W for 56K.
fastandfurious6
861
1,018
100% 💯💯
zen 5 is rushed and unfinished - they know what they want to do but they didn't have enough time to finalize
zen 6 with 2/3nm, DDR6, new IOD and moonshot pathway bugs fixed will destroy the benches themselves 🥋🥋
announcement should be just 12 months away
FlameTail
4,384
2,762
All aboard the Zen6 hype train!
On a more serious note, if Zen6 is indeed 2027 as Kepler said, I wonder if there will be a Zen5+ refresh before that.
Reactions: Tlh97 and rosetta
Josh128
1,505
2,256
yes it is , it´s just GC with 2 MB L2 cache
Adding L2 makes it different by definition. Its also using Intels 3rd gen enhanced superfin 10nm process while Golden Cove used 1st gen. That alone lets it clock >10% higher. Its not the same, lol. Thats like saying Zen 3 and Zen 4 are the same because Zen 4 has more L2 as well.
Tup3x
1,296
1,434
Well, is Zen 5 in Strix actually Zen 5 then?
MS_AT
920
1,842
Zen 5 in Strix is far more different than RPC compared to GLC if anything.
It's not only the lack of 512-bit wide datapath, the vector PRF for 128- and 256-bit operations is smaller and the FADD latency is higher.
Number of 512b entries is noticeably smaller. For 128/256 the number is either exactly the same or very close to Granite Ridge depending on the source.
