Page 688 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
19,125
Only thing I can think of is its a reliability/culpability play, and the voltage and current requirements to hit this ~45K are just not something they are comfortable having to warranty.
Or that not all silicon may be able to do that reliably.
bakyt115
97
170
may be if someone with 370 in hand can disable SMT and e cores and makes some test then we can compare results with 4 core zen4
also interesting to see core to core comparison with SMT on and off.
MangoX
623
165
I'm not sure it was mentioned, but why did AMD split stx into 2 ccx's? I think that totally killed the core to core latency. I mean it can't be a technical problem. Because after all, the 8500G has 2x z4 and 4x z4c sharing the same ccx without the latency problem. Why AMD? Why?
CouncilorIrissa
724
2,681
AMD's laptop firmware hasn't allowed disabling SMT ever since Renoir from what I've heard.
Reactions: Thibsie
bakyt115
97
170
to save area
MS_AT
868
1,762
The encoding test are also all over the place (looking at AV1), with there being large gap between Phoenix and Strix and then the difference gets swapped in the same test but different resolution? Feels like something doesn't quite work in the scheduling or in clock management. Could also be SVT having awful threading model perhaps. AV1 encoding via Handbrake seemed to suck in ComputerBase review too, perhaps the encoder sucks on big.little (although in massively threaded up, it should effectively stop being big.little except for the caches). Maybe the encoder is prone to some problem with threading or dispatching SIMD on zen 5 / strix for some reason.
That is another thing that would be nice if AT investigated. I mean it would be nice they could comment on both the core performance in isolation (pin the workload to single core, double check it stays there and measure whatever needs measuring) and MT/SoC performance where scheduling issues could be confirmed and pointed out. Now we get visual representation that something was not exactly ok [but was that the test procedure, the CPU itself or Windows] but we are left guessing what. Of course I understand those things take time but they could be highlighted in the review and it could be mentioned that they will be investigated in another piece [bonus points for keeping up the promise and doing the piece;)]
Reactions: yuri69
RTX2080
340
540
which of zen5 products will be on 3nm?
Maybe Strix halo too?
AMD is waiting for N3(E) for StrixHalo, and would be expensive for sure.
Certainly PBO or a manual OC though. If it achieved it at 230W, its so odd that AMD chose to require PBO to reach that perf instead of letting the proc handle it itself. Only thing I can think of is its a reliability/culpability play, and the voltage and current requirements to hit this ~45K are just not something they are comfortable having to warranty.
2 reason I guess: 1, there's no competition currently. 2, AMD is also afraid of silicon degrading which happened at Raptorlake.
MS_AT
868
1,762
AMD's Mike Clark gave interviews last week to Chips and Cheese and Ian Cutress. He said that practically all core resources can be used by a single thread.
That is why it would be nice if somebody would test decode behaviour with SMT on/off in BIOS for 1T load to put the doubts to rest.
Josh128
1,319
1,985
Interesting post by David Huang;
"The consequence of Zen 5's initial release to most media outlets for testing on ultra-thin notebooks is that you can't even find a few Cinebench tests where a single core ran at full frequency without being throttled..."
No wonder AT couldn't measure any ST IPC increase in Specint while David measured around 10% jump vs Zen 4 mobile part.
Another comment (spicey language):
edit;
One more
"I suggest you wait until I finish running SPEC and GB under Linux in a few days before drawing any conclusions.In addition, if you have read my previous analysis of performance bottlenecks, you will know that even for a 6-wide 4ALU x86 processor, the performance bottleneck is mostly not in the decoding width or the number of ALUs."
Problem is, from leaks we've seen in R23 ST, even desktop silicon is also not holding its full single core boost freqs.
Josh128
1,319
1,985
Almost certainly this. If it could be done with reliability guaranteed, theres no way they wouldnt have done it with Arrow Lake looming.
poke01
4,202
5,547
This also happens with Apples chips too, they don’t reach max clocks in the r23 ST test but they do in r2024.
bakyt115
97
170
there was paper about power consumption of x86 (in comparison with arm). and there was statement that decoding consume nearly 20% (can be wrong in numbers can't find article itself) of power for old tiny atom cores.
may be second decoder is now issue for zen5 core to hold max frequency in 1t workloads
MS_AT
868
1,762
Have you seen the clocks next to the score? Or do you base it on the fact that score is less than expected? These two things don't need to go hand in hand ;) [although it would be better if boost was not reached for the leaked scores, then there would be a chance something can be tuned in BIOS to boost the clock to advertised values]
Philste
301
475
The performance at the same wattage is 17-34% higher. Notebookcheck compared against the Z1 Extreme and 8945HS:
But this also shows that ZEN5 need more juice compared to ZEN4. The advantage at low wattages is pretty meh for 50% more threads. It only starts getting decent at power levels above ZEN4s sweetspot. I'm 80% sure we will see that every ZEN5 Desktop SKU is slower than it's predecessor at low wattages. Similar to Igors Leaks, the ZEN5 ES was besten by 7950X pretty much everywhere below 100W. ZEN5 needs Juice to run properly.
Josh128
1,319
1,985
Its because the scores are not equaling +17% vs known Zen 4 SKUs at known clocks. We are seeing ~9%-14% for 9600X and 9700X vs their corresponding Zen 4 SKUs depending on whether PBO is on or off.
LightningZ71
2,508
3,190
Thinking about the Zen5c CCX on Strix Point, that's the least amount of L3 cache per thread since Lucienne. Yes, the L2 is twice as large and still exclusive, so the apparent L2/L3 cache is 33% larger, but Zen5c, even restricted to ~3.6Ghz, is much higher performance that Zen2 at up to 4-4.5Ghz. This becomes an even bigger issue with AVX-512 code as that can quickly become memory throughput bound.
All of that is to say that the Zen5c CCX is very memory bandwidth starved and will be hitting the memory controller and snooping the other CCX a lot. This seems like a very hamstrung design unless the memory controller has gobs of bandwidth available at low latency. A MALL cache would have made this make sense. The current design just exacerbates existing problems with limited bandwidth.
This leads me to believe that AMD changed course hard after they had frozen critical aspects of Strix Point's design, like the rumored NPU expansion that removed the MALL. They wanted to hit a marketing goal of having a processor that looked like Alder Lake/Raptor Lake, but things went sideways along the way and they didn't course correct well.
