Page 510 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
CakeMonster
1,663
843
I'm wondering if Mike Clarks comments were made before the realisation that intel would go HAM with power usage, forcing AMD to increase Zen4 more than the average user wanted/liked. Zen5 is decent in laptops, and in server... ie at "reasonable" power limits. Without Zen4 being pushed to 170W already, Zen5 (@ say, 140-150W) may have been on track to be better positioned using previous power/perf estimates.
I have so many thoughts on the Clark interview now. IIRC it was in 2021. Did they still hope to make Z5 on 3nm back then?
poke01
4,887
6,232
that’s a good lead to have against Intel. ARL isn’t due till Q4 2024. So Strix will go against Meteor Lake for 5 months.
Yes I know but Lunar is a 4+4 part competing with M4/M3. Strix Point targets ARL-H and ARL-P.
Nothingness
3,374
2,475
PJVol
858
845
SteinFG
743
873
I've seen all kinds of speculation on this, I thought memory speed support was like 90% the controller in the CPU?
If memory traces will stay the same as before, 600 and 800 will have the same memory support on similar CPUs. But, If they're differrent, then... they're different
jasaero
4
Are you suggesting that I intentionally overhyped Zen5? Are you brain damaged?
Haha...I think a lot of the hype was too much focus on AVX 512 gains and integer gains. It seems you always need more drastic cache structure changes to get huge IPC gains in myriad of workloads...but I didn't see any leaks of any kind suggesting that...so I always assumed a lot of the "gamer" community might be disappointed. But I am still waiting for the more "mobile"/"efficiency" testing of strix vs all the competetion to see how good/bad zen 5 is. The release of Strix Point with Granite Ridge on it's own is very significant change in focus and I am sure Zen 5 cores themselves were designed more to maximise Strix point than Granite ridge. And it seems all the "geekbench" and similar focus of stuff that gets compared to ARM will be pretty big gains, while power efficiency might be also for a minor node shrink and still being a node behind some ARM designs. Seemingly Zen 6 is the generation that addresses all the more chiplet derived products more than this anyway.
poke01
4,887
6,232
Like AMD said it should be around 30% faster in Cinebench 2024 vs the X Elite at I think 80 watts
It should land in about M3 Max level in nt at 80 watts.
At 45 watts it’s about M3 Pro (6P + 6P) level. That P cores cluster is very impressive on the M3.
IMO, The sweet spot is 45 watts. Apple and AMD have both killer 45 watt parts that’s not crazy crazy expensive.
Reactions: carancho
tsamolotoff
262
513
may have to get expensive EXPO kits and a decent X870 mobo minimum to make the most of their Zen 5 upgrade.
First of all, I really doubt it can do 2400 fclk. Also, in reality, you don't need expensive boards and RAM, just get something that works with HV less half-donkey-ed like my Gigabyte board does, and get one of Kingbank $100-150 hynix 24gbit/16gbit a-die kits that can easily do 8000+ with good timings.
tsamolotoff
262
513
I've seen all kinds of speculation on this, I thought memory speed support was like 90% the controller in the CPU? Certainly overclockers are getting 8000+ on X670E boards today? It would really suck if the current high end boards can't handle a modest 'sweet spot' DDR5 increase to 6400/6800/7200, when the X870 chipset has the exact same hardware.
I think even low-end Asus 2DPC boards can easily do 7600 ish MT/s with one stick per channel, other brands (gbt/msi/asrock) can go even higher in general practice. It's all moot if IF is the same, which is the most probable outcome, I guess.
Hitman928
6,755
12,501
“IPC” depends on the workload, and I think it would be good to discuss it as such. Looking at GB6 subtests, M4 improved iso-clock performance between 0% and 30% (this is discarding tests that benefit from the new matrix hardware). In the few sub tests where the iso-performance did not improve (most notably, Clang), Apple already leads the industry by 50-60% iso-clock, so this is the area where improvements are most hard to come by.
Of course, but the generally accepted IPC comparison has been SPECint for a while now.
my goodness. The level of defence for AMD. ARM did 16% YoY. 16% in 2 years and a "new" core is not good. Its average.
Apple is stuck atm, we know that.
Where are you getting 16% IPC increase for ARM Y/Y?
SpudLobby
1,041
702
Yes, but the power consumption of M4 has more than doubled compared to M1.
It doubled per software estimated methods but in platform power (from USB) idle normalized I don’t think it doubled, but that’s also because people underestimate M1/2/3 power since they rely on powermetrics too much. By phone methods or AC minus idle you’re looking at 5.5-9W throughout the range, and more like 8-9W with M3 I think. You’re looking at like 11W with the M4 from one iPad test, and because some of the other stuff from RAM and power delivery is different and similar or even reduced thanks to LPDDR5x that helps. But I could believe core power alone doubled.
So it’s actually more than you realize in ST, but that’s true for virtually everyone, and in Apple’s case they’re still blowing AMD and Intel out of the water — and Qualcomm too, who’s already bending AMD and Intel over on this metric.
3700-4000 GB6 1T around 11W platform is honestly ludicrous. I will bet everyone here Lunar Lake comes in 2800-3200 range at peak and uses more power than that by probably a factor of 50% if not 100%.
One P-core in M4 running at 4.5 GHz consumes 7.2 to 9W. If you have 12 of them (in M4 Max), the total power consumption only for the CPU part will be nearly 100W.
I agree here. The iso-clock power gain is like 5% over the M3 so they’re not going to be able to do much MT gain other than by pushing power or by more E Cores.
Apple has to throttle them down back to M3 levels. As a result, the performance of M4 Max will be nearly the same as that of M3 Max on MT load.
Roughly speaking yeah something like this.
Reactions: Ghostsonplanets
SpudLobby
1,041
702
No, Geekbench is fair too. Wider code footprint in some ways? Both are fine. No diss to Specint tho.
Bruh?
Look above — not Yo/Y but this year. And Arm has been barreling forward for a while now. X4 was a 10-12% IPC improvement and really close — mid single digits — to Firestorm IPC, closer than Zen 5 for sure. X3 was around 5-8% gains I think and even then was doing rouuughly mobile Zen 3 ST at 5W total power in 8 Gen 2 or 9200, and ofc at less frequency.
It’s honestly strange people are so ignorant about Arm’s cores.
Matching Apple is a high bar on IPC, but even more so with power as the X4 showed, it’s true they’re not A+ cores and probably Qualcomm will have some power leads I can see too.
But “even” being a Firestorm Walmart/generic core like the X4 was (hitting 1600-1690 GB5 for ex, or at 2300-2350 in GB6) with worse power characteristics than Apple — but still doable in phones — is self evidently better than what AMD/Intel could offer in PCs for a similar perf.
The sneering about Arm’s Cortex IP is fair vs Apple and arguably QC, but not vs AMD and Intel anymore save probably some server stuff.
Timmah!
1,572
935
Just found out the base clock on 9950x is 200MHz lower than on 7950x. You think all core clocks are gonna be lower as well? Or the base value is due to some AVX-512 shenanigans being taken into account, while real-world all-core clocks might be actually even slightly higher in non AVX-512 loads, thanks to better efficiency of the updated process?
krumme
5,956
1,596
What a bean counter, no competition, cpu. Cache starved to death, cheap process. What a disappointment.
jur
47
37
Didn't really follow all the debate here; any info on AVX512 implementation? Can it do 2x AVX512 / cycle? Doubled load bandwidth seems to indicate it can load 2x512 bit, which is on par with Golden Cove.
Markfw
May 16, 2002
27,406
16,256
Didn't really follow all the debate here; any info on AVX512 implementation? Can it do 2x AVX512 / cycle? Doubled load bandwidth seems to indicate, it can load 2x512 bit, which is on par with Golden Cove.
Well, from what I read its supposed to be twice as fast. We will see when benchmarks hit.
This is hilarious to watch.
Do none of you remember the slow creep up of IPC from Sandy Bridge to Skylake, and the complete stagnation after that for years? 15% increase is fine, good grief.
Yes, I don't know where some comments come from. lack of knowledge I think.
jpiniero
17,209
7,582
N4P is anything but cheap.
AT confirmed that it is 2x512-bit now. That might be where the bulk of the transistors went (ie: AI)
