Page 337 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Ajay
16,094
8,116
AFAIK AMD has not yet decided if Zen6 will be on AM5 or a new platform.
AMD has most definitely decided. They are just holding their cards close to their vest. Almost all of these decisions/changes occur internally a year a two b/4 they are leaked. Even board partners are getting specs far later than they did 10 years ago. Such is the state of a very competitive market.
eek2121
3,491
5,183
You guys are talking about AMD killing off AM5 and AM4 isn’t even dead yet. AMD has unreleased Zen 3 stuff on AM4 still.
Ghostsonplanets
774
1,228
Middling at best. MTL Arc already does that at elevated power levels.
Arc's excellence in benchmarks means nothing if certain games outright do not work with it, or require some fiddling to get them to work.
Doesn't Arc literally cheats in by replacing the programs shader with custom hand optimized shaders in the popular graphics benchmarks? And such results don't reflect the performance in games. So much that Intel had to add a option in their Graphics Panel to disable these?
I remember the MTL GFX IP hype due to TS leaks and people taking those results at face value and thinking it was way ahead of PHX. But in reality, MTL is basically a match or behind PHX, but with worse driver stack, incompatible games and power curve that is biased towards the higher end of the curve.
Don't take me wrong, MTL GFX is a fine piece. But it's amazing that Intel has been talking and pushing integrated graphics for 10+ years now and are still so behind.
tamz_msc
3,865
3,730
It's an MoP tablet part that was juiced a bit too high for its own good.
Strix is bigger meaner mobile.
Yes, even with 33% more CUs Strix Point is still scoring barely enough in TS to beat juiced up MTL. And Xe2 is supposedly twice as fast as MTL (8 Xe2 cores vs 4 Xe-LPG cores).
Reactions: DAPUNISHER
tamz_msc
3,865
3,730
That's literally what driver optimizations are. NVIDIA and AMD do it with games - the fact that they are ahead is because they have decades of head start.
uzzi38
2,747
6,657
You're forgetting about Lunar Lake.
No, you're underestimating how arse MTL is. LNL being as good as it is at 15W relative to MTL only puts it on par with PHX at 15W.
MTL is utterly unusable at 15W, it consistently falls far short of Phoenix on average frame rates and has utterly unplayable frame times to boot at 25W. It just gets even worse at 15W.
Glo.
5,930
4,991
LNL is the same perf as MTL but in smaller(lower) thermal envelope on iGPU.
What LNL does is it increases the amount of ALUs per cluster. Thats it. In terms of performance, it will still be 1024 ALUs vs 1024 ALUs between MTL and LNL. Yes, LNL will be more efficient, but will not mean it will be TWICE AS FAST. It means it will be the same perf. at lower power.
Ghostsonplanets
774
1,228
Well, yes. What I mean to say is that Arc Alchemist is an uArch that does exceptional well in benchmarks but these results don't reflect into real game performance. Intel literally had to add a "Disable performance optimizations" into their control panel due to Arc benchmark not reflecting real world performance and being called out for it.
Well not quite, SIMDs are twice the size (PVC-style) too.
So it's a fatter GPU per Xe Core? I always thought Intel GPU arch subdivision to be too high and leading to occupancy problems and others bottleneck, not too different from past Mali GPUs(I might be totally off base here).
So they going with fatter Xe Core to try to cram on area and increase per core performance is a nice change of direction.
Edit: I totally missed this is the Zen 5 thread. Sorry for going off-topic, mods.
TESKATLIPOKA
2,696
3,260
MTL has 8 Xe-LPG cores, not 4!
What we should expect from Lunar Lake IGP I don't know.
But I am not even sure, If AMD will have a direct competitor against It, maybe Kraken Point? 4+4 and 8CU looks pretty similar.
