Page 272 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
S'renne
149
108
86
On package RAM isn't a totally new idea. Intel already shipped it in the Kabylake+Vega wacky product they made back in 2018:
So yes, putting dedicated VRAM on package is certainly doable. But I still think that configurable, user replaceable LPCAMM is the way forward- 256 bits of LPDDR5X should be plenty of bandwidth for any APU that fits in a laptop thermal envelope.
Unless the entire SoC shares the entire bandwidth instead of separating between the CPU and iGPU it'd be quite troubling to feed both components
Shivansps
3,918
1,570
Can 256 bit LPDDR5X feed the potential 40 CU RDNA 3.5 iGPU though? The 6700XT itself has 384 GB/s bandwidth..
Not even 256bits of LPDDR5X-8533 can get near that, they will need to include some cache and maybe RDNA3.5 is a bit more memory efficient than RDNA2 as well.
S'renne
149
108
86
RDNA 3 is 33% more memory efficient iirc but they will need even more efficiency or more/better cache technology unless Strix Halo is destined to be always bandwidth starved
S'renne
149
108
86
Isn't this how Apple does things or can AMD make something similar for Strix Halo
Tigerick
844
797
Yeah, I have been wondering about memory bandwidth for a while...As FP32's TFs are based on clock speed; I believe AMD would clock Sarlak's GPU lower than usual. As calculated here, with 2500MHz, Sarlak's GPU theoretical speed is double of Strix Point which has half of memory bandwidth.....
Of course, the above Sarlak is for 256-bit LPDDR5x version, we should see LPDDR6 version one year later.... ;)
Shivansps
3,918
1,570
If they are aiming for LPDDR5X this late the reason has to be LPCAMM2, and just so happens 2 x LPCAMM2 = 256bits.
Glo.
5,930
4,991
In terms of why Strix Point Halo would be released 2025 I think this is the answer:
soresu
4,099
3,553
Wasn't Radeon already an AMD trademark in 2018?
Radeon branding comes from years before AMD acquired ATi after they transitioned from the earlier 'Rage' 3D accelerator branding.
Hypothetically AMD would have acquired all ATi's trademarks and branding along with Radeon back in 2006
The Qualcomm Adreno GPU brand is an anagram of Radeon in reference to their original low power ISA/µArch acquisition from AMD/ATi.
FlameTail
4,384
2,761
LPDDR5 came about 17 months before regular DDR5 did.
It's not a stretch to imagine that LPDDR6 will follow a similar cadence and appear significantly before regular DDR6.
The thing is LPDDR6 will initially be very expensive and limited in supply, hence being relegated to flagship smartphones that are of course very expensive and sell in low volumes.
When have laptop makers been so quick to adopt a new LPDDR version?
Ajay
16,094
8,114
Their source is MLID.
Pretty sure he's guessing. MB manufactures can just reuse their current boards and just add 'now supports Zen XXXX CPUs!!!" Or, call them x670E Super Overdrive Extreme or some other marketing gobbilty beloved patriot.
WTH? beloved patriot?
Tigerick
844
797
Yep, but this round LPDDR6 and DDR6 should launch within the same 2026 year.. Of course, nobody cares about CAMM2 anymore by then :p
Tigerick
844
797
LPDDR6 are selling directly to OEMs which are much cheaper than DDR6 at retail prices
19,099
Probably just better memory overclocking with more expensive traces or extra PCIe 5.0 lanes.
Glo.
5,930
4,991
Go calculate memory bandwidth of 192-bit LPDDR6 and think why AMD going to launch Sarlak with 40CU? (instead of 32CU which is double the Strix Point's 16CU)
You are just speculating.
P.S. If there will be a replacement for Strix Halo - it will use 9600 LPCAMM2 LPDDR5 memory, because that is the next logical step.
Reactions: S'renne
