Page 270 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
DisEnchantment
1,777
6,789
Me and @BorisTheBlade82 been discussing advanced packaging and disaggregation for AMD Mobile SoCs for quite a while but seems each year it is still one generation away.
What is the consensus with Mobile SoC disaggregation for AMD. Is it Strix or Strix successor?
Or there is no Strix Successor, just Medusa for both DT and Mobile?
SoC tile with DDR5 MC like MTL + Memory Attached LLC on N6+ would really take integrated graphics to the next level.
RDNA4 also seems to rely heavily on MALL as can be seen from the LLVM MRs.
Philste
297
474
LNL just won't have the power available to be competitive against Strix Halo since it's geared more towards low power laptops with all day battery life.
I was talking about normal Strix, not Halo. I mean what's the point of Strix when iGPU isn't better in games because of bandwidth Limit? You will have a CPU that destroys everything in Cinebench, but who needs that in a Laptop? AIE is also stronger but for 98% of consumers strix would be totally unnecessary compared to Pheonix or even Rembrandt.
Most useful upgrades that x86 Laptop CPUs need right now is Battery Life in surf/Video scenarios and iGPU Power. Will Strix bring anything meaningful here? From the Informations we got now, I would say no. It will have a beast of a CPU and NPU. But Lunar Lake will also have the latter, probably a competitive iGPU, and it has the potential to fix MTLs flaws, with putting the LPE-Cores on the Compute Tile. Sure, it's CPU gets trashed by Strix, probably by 100%. But who needs this perfomance in slim devices?
This doesn't mean Strix won't be an impressive product, but I kinda think AMD misses the point of a mobile CPU with it. The biggest upgrade seems to be in the parts where an upgrade isn't really needed.
18,762
That's actually how much my boss makes and I starve in comparison, with crappy health insurance and not enough to get my own apartment with a proper lease agreement.
And oh, you should watch him type a formula in Excel. You will want to kill yourself.
moinmoin
5,240
8,454
Strix Halo supposedly will be disaggregated and have the Zen 5 gen's peak high tech packaging. No actual details publicly known though.
jpiniero
16,683
7,162
I've been under the impression that Strix Halo is just Fire Range with a different IO die and packaging so that it has the 256-bit memory.
Philste
297
474
From what I understand it was rumored to have it's own CCDs with only 16MB L3. Sounds really unlikely, but if it is true it's just a sign of how expensive it will be. Every die would be an exclusive tapeout only for this one product, quite contrary to what AMD is trying to do with their chiplets so far.
FlameTail
4,384
2,761
depends on LPDDR clocks. 8840HS can run at 7500 MT/s, if Strix can run LPDDR memory at ~10000, it's gonna be fine
No LPDDR in the market can reach 10000
Fastest is LPDDR5T/X-9600
But the availability of this is limited, even in flagship Android phones today.
So I expect STX will max out at LPDDR5X-9600
aigomorla
21,065
3,572
Only wall of text i should be seeing is Zen5 in this thread.
I shouldn't be seeing Apple.
If you want to talk about Apple, there is a perfectly good apple thread.
But this is reserved for Zen5 and only Zen5.
Moderator Aigo
Markfw
May 16, 2002
27,163
16,048
Moderator Aigo
Isn't strix and strix halo Zen 5 ? I could be wrong, not questioning you, just asking. Is the below what they are talking about ? (STRIX POINT ??) the same ?
Kepler_L2
976
4,107
Strix Halo is already using chiplets, and I believe most of the Medusa lineup does too.
BorisTheBlade82
703
1,122
I could imagine AMD to follow the blueprint of MI300A. It was pretty surprising for me that they already included alternative D2D interfaces in the Zen4 CCD for which they basically just needed some different metal layers in order to enable them.
The question for me is if they could use InFO-RDL or if they rely on capacity constrained CoWoS.
FlameTail
4,384
2,761
How much die area do those D2D interfaces take?
BorisTheBlade82
703
1,122
Found it. Official slide from AMD. Look at the tiny blue squares compared to the GMI links.
Curently it's believed to use the same RDL tech that Navi 31/32 uses
Hoping this as well. That would mean, they solved whatever issues prevented them from using that for MI300.
TESKATLIPOKA
2,696
3,260
I really don't know why you still continue with your narrative how Strix Point will be BW starved.
We already have fast enough LPDDR5X on the market. Even handhelds already use 7500mbps for Zen4.
AMD is not so stupid to put 16CU IGP inside but not be able to feed It, that just doesn't make sense.
FlameTail
4,384
2,761
7500 not enough.
We need 8500.
Philste
297
474
Because AMDs APUs are Bandwith starved for 2 Years now?! It started with Rembrandt and now Phoenix is worse. Pheonix iGPU is clocked over 15% higher than Rembrandts and uses RDNA3, meanwhile it's not even 10% faster with same RAM and barely 15% with faster RAM. Also OEMs will always cheap out on faster RAM, so don't expect that every device comes with LPDDR5x-8533. New Tests of Desktop Versions also show that 7200 brings nearly no difference compared to 5200 (only about 7%). All this leads to the conclusion that Strix will be Bandwith starved to the moon.
Glo.
5,930
4,991
Also, 760M is just 15% slower than 780M while having 33% less CUs, than 780M.
If this is not memory starvation - I do not know what is.
18,762
Why couldn't it be latency?
Could also be driver overhead. Remember, the driver has to share system RAM with the CPU's other running processes. By the time it receives its quantum slice, the data it has may already be stale, needing to pull more which incurs another latency penalty waiting on the higher latency of LPDDR5 chips. The iGPU really needs its own slice of dedicated cache (256MB if possible).
