Alright that's better than screaming, per your links, what you got there is Intel winning the following 6:
Lame MP3 Encoder 3.96
MS Windows Media Encoder 9
Auto Gordian Knot
Windows Movie Maker 2.0
dBpowerAMP Music Converter
I can match, AMD wins the following 6.
1. Per your HardOCP link DVD2AVI DivX encoder w/ codec 5.1.1
http://www.hardocp.com/images/...82713dbCdJgsnE_3_2.gif
2. dBpowerAMP Music Converter ...conflicting.hmm
http://www.hardocp.com/images/...82713dbCdJgsnE_3_1.gif
3. Oggenc audio encoding
http://www.digit-life.com/arti...bo/athlon-64-3400.html
4. Windows Media Video 9 VCM+
5. Conopus Procorder
6. VirtualDubMod
http://www.hardware.fr/medias/...s/00/07/IMG0007895.gif
As we all know the P4 wins only the applications whose codecs and containers are very well optimized for HT / SSE2 and 3. Otherwise it will lose.
This may help to understand the percieved Intel econding/decoding lead: Copied from another thread curtosey of ALEXRUIZ:
First, you have to answer the question of what application you are going to run (you already have), then, check what version you will be running..... The P4 will be unbeatable in the application in question, if ALL of the next happens:
- Application is very well optimized for SSE2
- Application is very well optimized for hyperthreading
- Codec (and/or container) is very well optimized for SSE2 / HT
- Decoder (if transcoding) is very well optimized for SSE2 / HT
In addition to those, in order to generate the big margin of victory seen in some programs, it is needed that those softwares don't recognize all the features of the AMD CPUs. I am pretty sure everyone remembers the WME ver 7 issue where SSE was not properly set in the Athlon XP.
If the application and/or codec is not very well optimized, the K7 will win (yes, it says K7). The K8 will win by a bigger margin.
As examples, take these:
AMD wins
Codecs: xVID
Consumer programs: Ulead VideoStudio 4,5,6 and 7. Roxio videowave 4,5,6 and 7. Pinnacle studio 7 and older.
Mid range video edition: Adobe Premiere 6.5 and older. Ulead MediaStudio Pro 5, 6, 6.5 and 7
MPEG2 Encoders: Canopus procoder, Ligos, bbMPEG.
DVD transcoding: DVD2AVI, VirtualDubMod
Freeware: VirtualDub.
Streaming: Quicktime.
Intel wins
Codecs: DivX 5.1.1
Consumer programs: Pinnacle Studio 9 and 8.
Mid range video edition: Adobe Premiere 7 and newer
MPEG2 encoders: TMPGEnc, mainconcept
DVD transcoding: XMPEG, FlaskMPEG
Streaming: Windows media 9.
Unknown
Codecs: On2 VP6, Nero digital
Consumer programs: Nero vision express.
MPEG2 encoders: Cinema craft encoder
DVD transcoding: Nero recode, DVD shrink
Streaming: Real video.
As you can see, it is basically a wash. For any application you give where the P4 wins, there will one where the K8 wins. Remember also that the setting used in some sites (retarded by the way) are not realistic.... Who converts a DivX resizing at fastest quality without sound? Those figures of 100 fps are cr@p. Quality is key. I am yet to break the realtime barrier encoding DivX and half real time encoding DVD compliant MPEG2......
Proffesional video applications are usually NOT heavily optimized for SSE2, but rather optimized in features. So, the fastest CPU for video encoding will be the one that fits your application best. Pick your application based on that.
Same goes for audio. A true professional application (cakewalk) runs in a celeron 300. This means it is not optimized for SSE2 / HT, so you know who wins "
Keep in mind that even among applications there is a lot of difference. Nobody encoding MPEG2 looking for speed will use TMPGEnc.... Would you dare to pit your northwood overclocked running TMPGEnc against my barton running CCE? Come on, say yes! You are the advocate of the HT, so you have nothing to lose.... or do you prefer my clawhammer as rival?
Most of the applications I wrote ARE not arcaic, but as I mentioned, many are optimized in features, not speed. The web reviews give the idea that the P4 is a monster because look at what they use: WM9, divx 5.11 with XMPEG...... Someone used them, then the rest of the field (sheeps) followed that site using the same.... Why not DVD2AVI, a better transcoder? Why not realvideo for streaming? Why not CCE for MPEG2, regarded as the fastest (I know, it's expensive)? Why not Ulead for transitions, also regarded as the fastest? Duvie, by the way, none of your programs are "industry standard". With the exception of windows media video that has a good chunk, the rest are virtually unknown. Corporations used ligos / CCE for MPEG2 encoding, and DivX is just gathering more support.
