At least it's not some performance engine that I hand built or something. Then I'd be furious at myself.Originally posted by: Colt45
leanness burning up engines sucks :'(
:laugh:Originally posted by: angminas
There are two ways to look at this.
1. At least if you trashed an engine it was only a Tercel engine.
2. You trashed a Tercel engine? NOOOO BASTRD
I can't figure out which I like more. I will ask the beer.
:laugh:Originally posted by: BUTCH1
Try a new set of plugs and see what happens, and your driving habits are going to have to change.
Your car is now 17 years old and must be driven in a more moderate fashion if you wish to continue
driving it..Also it's not uncommon for ANY 17 year old engine to have problems with valve stem seals.
The GT @ 90 was barely breaking a sweat while your ride was @ warp 9 on the edge of a warp core
meltdown, just drive it as intended and enjoy the MPG as gas gets insane again. Installing a great stereo
is a good diversion, I did that when I had my Escort, it helped....
I did, but I wouldn't have been able to hear anything @ 90.Originally posted by: iamwiz82
Did you have the windows down? Usually pinging is fairly hard to hear. It sounds like a bunch of little things ended up causing the problem.
This thought has crossed my mind, actually. I did notice that suspicious substance on the plugs. . I equated it to the cylinder not firing, yet recieving moist air.. condensation.Originally posted by: funboy42
Cylinder #1: 65PSI
Cylinder #2: 45PSI
Call me crazy, but after reading that, seeing the plug, and noticing, the psi in #1 & #2 I would say you cracked the head, or blew the head gasket, the water rushed into those two cyls and caused the spark plug damage. That low of PSI next to each other is a indication of a compression leak between the two escaping into the block or cooling system.
Take the #1 plug out, and get a air hose adapter to fit into the head and hook it up to your air compressor and pop off your rad cap. When you start to pump it full of air and you start to hear air escape, it you dont have bubbles pouring out of your radiator, then its going into the block.
But Id bet dollars to donuts thats what happened, and caused what it did, and why you have low pressure at #1 and #2 and not 3 & 4, and why the spark plug went to crap with a huge rush of water going into a super hot chamber. Not to mention if you didnt doctor up the pic, that looks like a milky substance on the the pic of the plug.
I didnt read all the replies, please ignore if this has already been brought up.
Originally posted by: Eli
lol
Well, that was easy. Head gasket blowage most likely confirmed. Goop under radiator cap, and missing coolant. Should've checked earlier.
Hmm. Suckage. That radiator is brand new.. I better flush it out ASAP.
Doesn't really change a whole lot overall, I figured I was going to replace the head anyway.
Anybody know where I can get a cheap reman head for a 3E?lol
I don't know that it's that suspiscious. Those are the two cylinders where the plugs shattered and sharpnel ran through the cylinders. Makes sense to me. A little coincidental that it was those two, but not enough to make me suspiscious.Originally posted by: Pacfanweb
Changing the plugs definitely didn't cause this problem.
I agree that it's too suspicious that only two cylinders next to each other are the ones without compression.
Originally posted by: Old Hippie
You guys are much handier and optomistic than I. I'm sure, I would have already picked a grave site.![]()
ZV
That was my original line of thinking too, but it definitely appears that the head gasket is blown. It is a little strange, since the only "abnormal" thing about the engine at the time of failure was full output operation, but I guess if a head gasket is going to fail, that would be the time.Originally posted by: Zenmervolt
ZV
The question isn't really about the metal, although that in itself is fairly concerning ... but more importantly the missing center ceramic insulator. Plug #2 was actually worse than #1, which would support the debris or burned valve theory(lower compression).Originally posted by: funboy42
If it got that hot, and was not the head gasket that caused the water to do that to the plugs, I highly doubt there was any metal at all that was bouncing around in there to cause the head/gasket problem. If it was hot enough to melt the tip of the plug that stuff then became part of the head or piston and welded itself to something.
I would bet he was cruising at that high of speed, 2 steps hotter plug, big mistake there, would of only jumped one if it were me, the engine was hotter then snot, racing at 5000 rpm, when the gasket said no more causing water to rush in, hit that hotter then hell plug, and did what you see in the picture. Cool 190 degree watter on a 1000+ degree plug and metal parts, will cause that and a hell of alot more like bent valves, cracked head/pistons, and if all he got away with is a messed up sparkplug and the tip melted to the piston he is very lucky.
Now the million dollar question would be did the other end of the spark plug after it fell off make itself part of another piece, or has it been bouncing around in the chamber, scratching the hell out of the cylinder wall? I wouldnt start that car no more till the head comes off and see![]()
Originally posted by: Raduque
Ouch, man Eli, I feel for ya.
I blew the head gasket on my 88 Accord a couple months ago, I think it was due to the fact that the oil leaked out and caused the engine to overheat and boil the coolant all out, then when I replaced the coolant and the oil it was too late, damage was done...... except my temp gauge never read that the engine was overheating! I haven't done anything to it except curse and fume after I checked the dipstick.
