WMP9 = Suck
Cerb
17,484
33
86
Originally posted by: werk
I love WMP9. It's all I use for music and videos. The media library kicks ass.
Media Library? Useless.
MP3 share\artist\album\song
Add/subtract items by directory, use a few separate playlists, and you're all set for using any app; WMP, XMMS, Winamp 2/3, Fubar, etc.. Media library is a feature that lets you easily bloat everything and have files scattered wherever, so when you format you lose half of them. An extra 5-10 seconds per file (or album) saves all of that.
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
WMP7 with all the codecs run fine :D
Cerb
17,484
33
86
I tried that. According to MS it should have worked. Didn't, so I installed WMP 9.
Any tricks on this stuff? I'll be formatting within the month, so I get to do it all over again.
mchammer187
9,114
i use wmp 6.4 for everything except asf and wma because wmp 9 is the only thing that will let you seek fast with those formats for some reason
and you can use older versions for certain types of files you just have to associate it and remove the association in WMP 9 itself
i also like the mp3 tagging functionality though i use QCD player as the mp3 player
loup garou
35,132
um...I have everything nice and organized outside of media library; a directory on my server where WMP rips WMA to (yes I use WMA :p), organized by artist with album subdirectories. Multiple computers on the network use WMP Media Library monitoring tool to monitor the directory and update themselves automatically when new albums are added. Whenever I play music from any pc, it is nice and organized, with correct song names, artist info, album info, and album cover art...with little to no work on my part, except for inserting a CD and walking away.
Now if you're a thief and download music and then have to organize it manually and fix all the problems with filenames and ID3 tags from idiots who don't use a standard naming convention, I can understand how this is all just one big hassle. :brokenheart: But for people, like me, who rip and store music from their own cd's, it's a godsend.
And bloat? Who cares, all the PC's on my network have at least 1GHz processors...WMP9 runs like nothing.
LordJezo
Banned
May 16, 2001
8,140
The seek feature in WMP9 is so much faster then the old one.. on my 2100+ I can see a huge difference between how it use to work and now when I skip halfway through a long movie. I wouldnt give that up.
pecel
1,837
I love WMP 6.4
It's the best. The fastest to load, etc.
No ads, and all that junk :)
Cerb
17,484
33
86
...so what's the point of the media library, then?
Both, actually, over 90% CDs, and amount of rip-offs is growing smaller with actually getting the CDs.
I care. 1GHz? Yes, that's so things can work damn near instantly, not like WMP likes to...2-3 seconds load for most files on an 1.53GHz Athlon...no thanks.
loup garou
35,132
Why open another explorer window if I don't have to?
You're doing something wrong. WMP9 opens up instantly on the XP1600 system I'm on right now.
silent tone
I just compared WMP9 to MPC with 3 different videos. They were equal on CPU usage, but MPC used about twice the memory. Strangely, CPU usage shot up if the video was minimized in either player.
LikeLinus
11,518
670
I use and like WMP9. Haven't had any problems with it and i love the ability to minimize to the toolbar.
Luagsch
1,614
only using wmp9 for some formats (wm-stream stuff) else using bsplayer for about everything video-related and winamp for sound-stuff. oh and then there is real one for rms and qt6 pro for movs. not to forget power-dvd for dvds and vcds... is that it? ... i think so...
EDIT oh forgot musicmatch stuff for my panasonic mp3 player.../EDIT
XZeroII
12,572
WMP runs great for me. The library is awesome on it. There's no need to manually put everything into separate folders and such. I have just one folder with all my MP3's. WMP opens instantly and runs great. Plays all movies w/o a problem or anything. Hardly uses any memory or much CPU power. If you seriously have a problem with how much memory or CPU it uses, upgrade your piece of crap to something made within the last 5 years. I don't ever use the skin mode though, so I don't know about that issue. I just minimize it.
0roo0roo
64,795
84
good god, one folder with mp3s? is there a file number limit per folder in windows? i think i'd hit it lol:)
Cerb
17,484
33
86
Good question...I usually just have one up. That and quick access to the MP3s...easy. I use multiple playlists, and it works fine. I rarely need to go and add files except when they are first put there or I feel like adding something to the current playlist, at which point I hit five keys and I'm there (+ for command line focus, "mp3" and enter). Drag & drop a folder or three.
Then what on Earth are you doing right?! Even with a near virgin install it took forever (and that was using Explorer for the shell, too).
KeyserSoze
6,048
Winamp 2.91 for all Audio.
WMP 6.4 for all video. (Installed all video codecs)
Ahhh.....no bloat. What a feeling that is :p
KeyserSoze
Ryan
27,519
I agree wiht Werk, WMP9 opens instantly, not lag at all. Not to mention my system is hovering around 2% cpu usage with it playing an MP3 right now. YOu're doing something wrong.
LikeLinus
11,518
670
It appears it doesnt like something in your system. Be it the soundcard drivers, maybe something about your bios? Do you have onboard audio?
All my WMP 9 load instantly and are rock stable.
Looney
21,938
Not sure... but you're doing something wrong. It opens instantly for me as well on a XP1600 system.
Cerb
17,484
33
86
...but what? Installed it from Windows Update, and had it install most everything, then just took it off the desktop and quick launch, and had it use the "classic" skin.
Cerb
17,484
33
86
0-3% is about normal w/ Winamp, AIM, RivaTuner, MBM, Norton AV, etc. on and running.
But Winamp comes up instantly, and WA3 isn't as slow as WMP 9 is. Will be trying MPC.
The BIOS stuff should be fine. AK35GT2 with onboard CMI 8738, using the latest Win2k drivers.
