Wireless Network for Security Cameras
Anthony Rivera
I am getting ready to install a number of wireless security cameras to record 24/7 and have a few questions.
  • Will this bog the wireless network down?
  • Should I dedicate a wireless router or AP for the security cameras?
  • What is the best setup to maintain optimal wireless connectivity of all devices?
I think that your questions are too General.
Networking and Wireless is about Bandwidth available and Network's Hardware demands in bandwidth terms.
Lacking any info about the hardware and what else is on the Network makes it impossible to provide credible answers.
Yes it can bog the wireless network down. Dedicating another wireless router or dedicating one radio (2.4G or 5G) of your existing router will help. Best setup is wired. I suppose wireless for those sacrificial cameras. In my opinion, I wouldn't bother putting cameras outside, put them in your windows sills inside your home with a flashing red LED to let thieves know to behave.
Thanks for the input! I will try that.
It could, video is a fairly high bandwidth process. On the other hand most people have a lot of unused intrAnet bandwidth since they are typically limited by their intErnet speeds.
Yes if you can afford it. Also it would be best not to be on the same frequencies.
Run wires...
If the cameras have IR night vision, it won’t work through glass.
