Originally posted by: Zap
Good job on that Dell and welcome to the forums!!! :thumbsup:
Just goes to prove that there IS life after Dell.
Originally posted by: PoopyPants
i got a celie D 310 2.1ghz
ASUS P4P800-VM
this baord flipping blows another reason why asus is one of the worst mobo makers ever... sorry for the hate but i cant stand asus. i got this board buy going by the thread over at H on mATX boards and it said it had everything for overclocking , needless to say i have gotten the thread updated to reflect the bios doesnt give you anything but vdimm max of 2.65v and VID control that dont change the vid much at all... oh and mem freq. but no fsb and no real vcore control
anywho...
ok i am not about to read thru this whole thread.
Celeron D 310 478 chip asus P4P800-VM mobo the chip will boot at 200mhz FSB using clockgen (since clockgen writes to the PLL until the system is physically powered off. meaning you can reboot and the clockgen settings stay) anyway its not stable at 200mhz so i need two things
vdimm mod and more cpu voltage............
so what mod do i do for the vcore .... im not quite sure i understand the voltage mod. i am on air and if i pump 1.6v into this chip its gunna implode.
i can run 3.15ghz at less than 1.4v and the chip is already proven at 3.7ghz at a little over 1.4v so all i really need is maybe a max of 1.5v so what mod/wire setting do i use for 1.5v ?
lastly anyone wanna do a vdimm mod for me
i know Zap Joe just sent me over here to look at the vcore mod cuz he thought it might work for the Celie D prescott core also.
but can anyone else verify that the P4P800-VM has zero overclocking options aside from vdimm - mzx 2.65 and the usual cas timings ? there is a VID setting but it doesnt work ,,, atleast not on my chip it dont.
Overclocking in a notebook, now that's hardcore! I did that for a friend with a Celeron 2GHz (his Toshiba at the time used regular desktop chips). The Celeron was tested on a desktop board for stability at that speed, and worked just fine overclocked in the notebook.
That's what I used one of my first mobile Celerons for. My daughter had a Inspiron 5100 with a desktop 2.8 P4, you could fry eggs with it and the battery wouldn't even finish a short DVD.
Put a 1.8 in it with the BSELO pin mod, it ran 2.4GHz at low voltage with very little heat and had a battery life that could actually be used.
Originally posted by: buzzly
My first post.
Finally, there is a way to turbo-charge my old Dell Dimension 4500 (Intel D845EPT2 board). I was ready to junk the computer because it was just too slow even for my 7-year old's games. I kept it because it had a very quiet 1-fan design.
After reading this tread, I got 2 Mobile Celeron's off ebay (1.6 ($18 ship) and 2.2ghz ($30 ship)). The Dell mobo recognized both CPUs as Mobile Celeron without the bend-pin trick. I assumed the board assigned 1.3v or 1.25v to the CPU (the bios is locked down and showed no volatge info). After doing the 133fsb pin trick to the 2.2 ghz CPU, it would boot at 2.93 ghz @ 1.3v (??), but it was not stable at all. It ran fine now after the 1.6v pin mod (putting wire into the CPU socket).
Thanks OP.
Next project is to put one of these Mobile Celeron into my Asus P4G8X-Deluxe which has been running on a oc'ed 1.8a P4 running @ 2.6ghz, 1.65v.
Hmm this sounds like what I need to do to my Dell 9100 with its 2.8 Prescott.
One question, what did you use, if anything, to shim the heatsink?
Great thread, found it on google...
Isn't the board on that dell limited to 2.8GHZ? I thought so...... I have that computer. If its not, then, hell I'm going to have to find a mobile celeron to pin mod my 2.0GHz Dimension 4500 and add a 6600GT for a fubar gaming machine!
I might look into it. But mobile chips should scale better than p4s with normal voltage, so i'm weary of doing the mod and finding that it won't work
Great, thanks for the info.
Couple more questions before I cool that beast down, you did the 133FSB mod to the chip right?
Did you have to do any voltage mods on the chip to run in the Dell laptop?
Thanks again,
Rob
Does it adjust the voltage automatically or do you have to do a volt mod also? Any guides? thanks.(the link to the pinmod at the frontpage is outdated)
