More results on the Asus P4S8X-MX. I'm gonna post here instead of my mini review because this information is of more use to those using mobile Celerons.
My previous assessment with the voltage modded CPUs may or may not be correct because that CPU also had a BSEL mod for FSB. I had broken of the BSEL0 pin so that the CPU detected at 533MHz FSB and bent the pin for 1.2v. Well, after finding out the CPU won't POST in that board, I bent the VID pin back. Voila, the CPU POSTed in the board. Elated, I disassembled my HTPC (Coolermaster ATC-620 case) and installed this board. Once in the case I POST tested again and it worked, so I bolted everything down and plugged everything in... only to find out that it no longer POSTed.
Had to rip everything apart again, and testing the board outside of the case with just CPU/HSF/RAM/PSU, still no POST. Cleared BIOS, no POST. Swapped CPUs to my other mobile Celeron that had never been modded and it POSTed. Swap back and no POST. I thought I had a dead CPU on my hands, but decided to test it in the old Asus P4SP-MX board, and it POSTed!!! Back in the P4S8X-MX and no POST. Swap in the never-modded CPU and POST. Now what? Well, I manually set the BIOS CPU settings and swapped to the other CPU and now it POSTs!!! Turned it off and on a number of times and it was fine. Hmmm... Clear CMOS, no POST!!!
With the VID pin straightened again, the only mod was the BSEL0 pin that I broke off. It
should work because the motherboard (and chipset) officially supports 533MHz FSB CPUs, but... this board has a problem with mobile CPUs (
see pic, I have to hit F1 everytime it POSTs). A quick look at the Intel developer PDF files confirmed my memory... I then used the "wire trick" and jumpered BSEL0 and BSEL1 together in the socket and installed the CPU. Now it POSTs everytime, even after clearing CMOS with the jumper. Problem solved!
Well, there's another problem now involving RAM speeds and overclocking. Because the memory divider is based on the base FSB, a base FSB of 400 has 1/1, 5/6 and 2/3 dividers on this board. Well, at the lowest 2/3 divider, you get a perfect DDR400 speed with the FSB set to 150MHz, any higher and your RAM is out of spec. That's okay if you have good RAM or if the board supported vDIMM boosting, but the board doesn't and I don't (at least the RAM I intend to use in the board). So, at this time I'm stuck at 150MHz FSB (2.4GHz) even though I've Prime tested this exact CPU just yesterday in osage's P4S800 board at 180MHz FSB (almost 2.9GHz). Raising FSB to 160 and no POST, probably because of my el-cheapo RAM. I've had this board at 180MHz FSB with my P4 2.53GHz CPU to see it POST at just over 3.4GHz on default vcore so I know it isn't the motherboard, and because the 2.53GHz desktop P4 works fine in the board, I know the board does what it supposed to do which is support 533MHz FSB CPUs. Just doesn't like mobile CPUs, that's all.
Oh yeah, I've also deduced why the system magically stopped POSTing once in the case and all hooked up (everything but case cover). I had swapped in the CPU after manually setting stuff using the unmodded chip, so it worked on manual settings. Well, the last time it worked, I probably turned it off before it finished POSTing. Anyone who has fiddled with Asus motherboards know that the Asus C.P.R. feature will reset CPU speed if it doesn't finish POSTing because it considers that a failed overclock. Well, with the BSEL0 mod, the board won't POST on autodetected settings!!! The moment I shut it off before it finished POSTing, the board reset CPU from manual settings to the auto settings which doesn't work with the mod.
I now know this board a little bit better, and I've also wasted about 6 hours of my life. Hopefully someone was entertained by this story besides my wife listening to my curses.
