nickdigger
- Apr 24, 2002
- 487
- 0
- 0
If it only lasts 1 minute in Prime95, it will affect your daily use. You can find the temp limit from the datasheets at support.intel.com. Most of the p4-478's seem to say 100celsius, FWIW.
Originally posted by: GL Joe
Hello all! I've been following this thread and picked up a mobile CPU to try out myself. Forigve me if I missed it earlier in the thread, but has anyone tried any of the boards that have a 478 socket but are based on the Intel mobile chipsets?
I have a mobile p4 (not p4-m) 3.2 HT I picked up. Also arriving tomorrow is an Asrock P4915GM-Dual, a micro atx board with the 915mobile chipset and a socket 478.
WHile I haven't been able to find where anyone has used this board for a Mobile P4, I am hopeful it will boot up and recognize the CPU since it IS a 915 mobile chipset.
It also has PCI-E and AGP support, though it looks questionable for supporting really high end cards. For me, if it support my X1600 Pro PCI-E then it will be a real boon for my HTPC.
At any rate, the Mobile P4 3.2 booted with 12 multiplier x 133 fsb for 1.6Ghz.
Edit: Forgot to mention...enabling Speedstep in Bios did not survive reboot. Also. I tried using RMCLock and EIST.exe in Winxp with no luck...all multiplier options were grayed out.
Originally posted by: nickdigger
Zap: according to one datasheet the mobile Celeron should default to 01001 but it doesn't "act" that way on a desktop board, thus I say 01010 is the way it "acts."
It acts as advertised on my GA-8IGX. The damn nail polish kept stripping off my pins, so ultimately i had to pop the s478 hatch & stick scotch tape into the AE3+4 holes.
1.300Vlap == 01001 == 1.625Vdesk, stock pins.
01111 == 1.475Vdesk, AE3+4 insulated
I assumed his chip was 1.200v default (01011), which made the best explanation, to me, for how he got 1.18 (1.175 == 11011).
Do SpeedStep chips typically need chipset & BIOS support to access GHI#, or can a simple app do this on an old 478 board? Also, the sheet says GHI# = Low --> high speed; GHI# = High --> low speed; is Low eq to Vss or Vcc? On the surface, it seems to be a bit tricky due to Sleep State changes, etc.
Google found a discussion here: http://www.howtofixcomputers.com/bb/ftopic92449.html
