Originally posted by: Inappropriate4AT
Broke off the pin for 133mhz fsb, but for some reason it didn't detect the change. In my IS7 the only divider available by default was 3:4, changing the N/B strap to 667/800 allows 5:4 3:2 and 1:1 for anyone else that might pick up this board. Wish I knew that to begin with, could've saved myself a lot of headache.
I was about to tell you that. I ran an IC7 with a Mobicel and dicovered that I had to mess with the bootstrap to get the more usefull mem deviders.
Did you have to bend the pin away to get the CPU to post? They woudn't work in mine unless I bent the pin.
Also, for those using the P4P800 DLX with the Mobicels, what BIOS are you running? I have 1019 (newest non-beta bios) and I seem to have to bend the pin to get it to boot reliably. With the pin not bent it refuses to do a soft-post after changing the bios settings. Needs to have the PSU shut off to get it to boot. It works fine with the pin bent but the overclock is weak. I expenreinced this same 'issue' with a p4p8x flashed to p4p800.
Great work Joe and Zap, keep it up.
Thanks, jon...
BTW, the Asus P4VP-MX works great with these CPU's. They default to 1.6v but have no FSB adjustments in the bios. I have two different setups with Mobicel 2.4 (d1 stepping) that have both been pin modded to 133 fsb and they each run 3200mhz in the Asus board (micro atx full onboard video, sound, land, and has prescott support).
