It's 54F and raining here in Missourah, on our way down to lows in the 20s this week. The leaves are pretty, but the storms have been ripping them off the trees the last few days.
57 in the house, and a freeze warning tonight. Got most of the windows closed. Bedroom window's still open. See how tomorrow morning feels. It may get closed tomorrow. Calling for a high of 40 this coming Wednesday. Perfect fall weather!
Already got the thermostat set for 78. Still chilly inside.
Holy crap that's 25C. I don't even think my furnace can go that high. Well maybe on a warm day but not on an actual cold day. Crank the humidifier and put wet rags on the registers and you got yourself a whole house sauna.![]()
With the poor insulation in my place it feels more like 65-70ish even though the thermostat is set to 78.
My place is kinda bad too. Insulation is ok, it's standard R12 fibreglass batts. It's the vapour barrier that's horrible. There is no tape at any of the seams so the house is super drafty. I fixed one spot when I redid my patio door, might tackle the rest of that wall this year. Basically need to remove the drywall and then put new vapour barrier with acoustic sealant and actually tape it properly. Then new drywall, plaster, and paint. It's not so much a hard job, but a messy one. I'd really have to do all the walls to get a proper result too. I might just leave this to a future owner to worry about.I will be removing the fireplace though which will leave a big hole in the wall so I may as well do that side at least. Fireplace on it's own is probably a big heat loss too.
An old co-worker just had his siding replaced, and while it was all off he had them add a 1-2" (can't remember) thick layer of styrofoam insulation. He said his house is much more comfortable now than it was before. You should look into that; a lot easier than trying to insulate from the inside, especially if your house is one level. You get air sealing and insulation all in one shot.
There are also companies that will drill ~1" diameter holes throughout the exterior of your house and inject expanding foam (Icynene is one of the popular ones, I think) into all of your stud cavities. They can do this without removing any existing insulation since it will simply compress the fiberglass batts.
I've been air sealing my basement and it's a PITA, but if you do it right you only have to do it once. I'll probably be done next weekend, then I might move on to the attic. My walls have R-24 fiberglass, while my basement ceiling/rim joist is insulated with R-30. The attic is ~R-44.
