Venice 3200 and DFI ULTRA-D O/C problem??
DPOverLord
1,980
So I got home,
Prime95 failed at 11 hours and and 7 minutes it said, "FAtal Error: rounding was .5, expected less than .4
I was also running 3dmark06 at the same time. I maxed out all settings and set it to run for 11 hours 4 minutes in a continuous loop until failure.
At the time of the failure my room-mate said he had disconnected the router / cable modem. I am not sure if this would have any play ( which I doubt) But I was wondering what you would suggest I look at next. The cpu itself idle is at 27C from the MBM reader.
myocardia
9,291
30
So, at least with the voltage that you were giving it, 2.6 Ghz is about all you're gonna be able to do. That's about average for Venice 3000's. Now, you're gonna have to decide whether it's worth it to you to raise the vcore, or just stay at 2.6 Ghz, with that vcore. Also, it still isn't time to run SP2004 for 12 hours, unless you're planning on leaving that expensive RAM @ 100 Mhz.
DPOverLord
1,980
No definitely not,
I got it at 150 atm and I am trying to think out from what we have posted how to get it to at 180 hopefully.
myocardia
9,291
30
No definitely not,
I was talking about your cpu, of course. But, the same thing applies to your RAM. You aren't even going to be able to go to the 166 divider, unless you've got a 120mm fan on your RAM, and are giving it more voltage.
DPOverLord
1,980
So at this point its about getting a fan on the ram increasing the voltage on the Dram. Then moving it to 166. Last night I Prime 95'd at 3.0 volts @ 150(dram) and it was fine until this morning. The temperatures are hovering around 50C. The guides say this is the Caution point and when I go above 55C is when there are probs. I have the HTT set to 3x. Should I move it to 4x? Or does it not really matter since @ 4x it will be 1060x2 which is above 2000.
DPOverLord
1,980
Stable since friday at 2.6ghz running on a 150MHZ divider. Next thing is to get it stable at 166mhz.
gorgeousjorge
Ok here are my settings since your board is the same:
Dram:140 7/10
Cpc: enable
Tcl:2
Trcd:3
Tras:5
Trp:2
Trc:7
Trfc:10
Trrd:2
Twr:3
Twtr:2
Trwt:2
Tref:3120
Odd divisor:Disable
Dram bank interleave:enable
Dqs skew control:auto
Dqs skew value:0
Dram drive strengh:level 8
Dram data drive strength:level 1
Max async latency:07.0
Dram response time:fastest
Read preamble time:04.0
Idlecycle limit:016
Dynamic counter:Disable
R/w queue bypass:16x
Bypass max:7x
32 byte:Disable
More settings:
Fsb:268 mhz
ldt/fsb:auto
ldt bus:16/16
cpu/fsb:10x
pci:100mhz
cool n`quiet:Disable
cpu vid startup:1,500v
cpu vid control:1,500v
cpu vid special control:113%
ldt:1,20v
chipset:1,50v
dram:2,50v
dram+.03v:enable
I have 2 patriot sticks(dual channel) in the orange slots both by spd:2-3-5-2
Cpu is a winchester core 3200+(2000 mhz).
Cpuz
Cpuz1
DPOverLord
1,980
Just wanted to say thanks to everyone it is prime stable @ 2.6 GHZ I had it running for 7 days and just got my first hiccup last night. So I backed it down to 2500 mhz. This is like a drug. Now I want test the other venice I have lying around. I probably should have sold it when I got it 1 1/2 years ago lol. Now its worth change.
Edit:
Actually I reallly like the idea of the cooler Pro... However how do I find what the metal is on my retail Venice3200 Cooler?
