- Dec 20, 1999
- 1,980
- 1
- 86
Ok I have a Venice 3200 listed in my sig coupled with a DFI ULTRA-D. I decided that the bottleneck in my system is my CPU since with my new 1950XT I am not seeing much of a performance increase in games, 3d applications yada yada.
My goal originally was to get my Venice 3200 to 2.6 GHZ but it does not seem I am having much luck. I have another Venice 3200 lying around which I will try if this fails. Listed below are the steps I have taken and I am looking in seeing A. What I am doing wrong, B. What I am doing right or C. My cpu is just not a good chip for O/C (could be memory)
What I have done:
A. I followed the O/C guide and some other guides. The method I took to find my max CPU was as follows:
What I have done:
Now as for my memory I just kept it at the default settings and set the dram Frequency set to 100. I believe that I did not set my ram to its SPD. (CPC = auto??)Due to how I am not 100% actually what settings these equal:1. Max HTT/FSB
-set CPU multi to 6 or 7, this will take CPU out of equation
-set memory to SPD and 100, this will take memory out of equation
Rated Timings 2.5-3-3-7 at DDR400
SPD (Auto) Timings 2.5-3-3-7
Rated Voltage 2.6V
Please tell me if I performed this correctly since I am not 100% sure.
The setting I got performing this was a HTT/FSB of 220 after 12 hours of prime 95-Increase HTT/FSB up until you fail to boot or there abouts, back down 5%, (HTT * 0.95), this is your max safe HTT.
2. Max Chip capable
- I set my multiplier to 10 (CPU FSB Frequency Ratio)
- I set my Vcore ( CPU VID CONTROL) to 1.475v
I did the same as above-Set mem to SPD and 100, this will take memory out of equation
- I set my LDT/ FSB Frequency Ratio to 3x
-starting with HTT 200 raise in about 5Mhz to 10mhz increments up to boards max found earlier or until you start failing PRIME95 which will probably happen first..only give it 5 minutes max, that's good enough for now.
I started actually at 220 to see what would happen and it got a BSOD, I then went ahead and went down to 215 and got a BSOD, Last night I went to 205 and its still running prime95.
These numbers to me seem very low. I BELIEVE I took the ram out of the equation but I will let you be the judge if I performed something incorrectly. I have another Venice 3200 but I am out of Artic silver so I will have to buy some ( or if you can recommend a PC store I can go to on my lunch break to buy some that would be great). Otherwise if this does not work I will just have to do what I was considering,
Buy new RAM,
Buy new Mobo,
Buy new CPU
As for the ram I am using listed below in my sig I bought it originally due to this review:
http://www.anandtech.com/printarticle.aspx?i=2392] Anandtech Review [/url] I do not know how to go around setting up this ram in my bios as per finding the max of my ram. However the current settings I am using for my ram on the Ram section are:
Currently I am running these at some really low settings:
CPC - Auto
TCL 2.5
TRCD 04
TRAS Auto
TRP 07
TRC 07
TRFC Auto
TRRD 03
TWR 03
TWTR 02
TRWT 03
TREF 4708
TWCL Auto
Dram Bank Enable
DQS Skew Control AUto
DQS Skew Value 0
DRAM Drive Strength Auto
On memtest this is fine but it seems like I am getting no Juice out of this so I am curious if you have any ideas as to what is to be expected of this. My system is listed below in my sig.
EDIT: Wanted to just say thanks for all help ahead of time!
