Originally posted by: pelikan
KayGee- By "stable" I mean no artifacts. I found that 3DMark 2005 and Doom 3 are great ways to make sure the card is stable. Your issue of missing textures sounds a little different. Games should look exactly right, with no missing textures. If I had your card I would experiment with lower clocks and maybe even a different bios like the latest ATI XT PE bios. I'm sure you are using the latest driver but if not try it out. And disable VPU recover.
Originally posted by: KayGee
i'm sorry if i'm being a nuisance with these posts, but please bear with me. i'm a n00b who's new to all this flashing and overclocking stuff and i've got a few questions :
1. in the beginning of far cry, after you get the binoculars and swim across to the camp on the other side, i noticed that the doors to the cabins appeared as a partial piece of wood that was sawed in the shape of a triangle (instead of rectangular) and i could see through the portion with no wood into the room (kinda like a weird shaped window). this is an artifact right?
2. in the canyon flight of 3dmark05, sometimes the canyon walls appeared as triangles which flickered occasionally. also artifact right?
3. when i flashed my initially, i used the X800 XT PE (AGP) 256 MB compiled on Apr 30th 2004 10:24 PM because it was the exact same size as my original pro bios. does the size matter if i flash to the most recent bios on the techpowerup site (the one compiled on Jun 9th 2004 3:28 PM)?
4. also if i see occasional artifacts(?) like the ones mentioned above, does it damage the card. i mean, personally, i don't really care if there are small defects which don't affect my gameplay, but is it harmful to run the card in this way?
thanks for all the help so far, especially pelikan. i look forward to your replies/suggestions.
Originally posted by: GopGuyCA
Would this mod apply to my X800 XT I got from Dell?
I see the X800 Pro and then the X800 XT PE, but never the X800 XT....
Is the Pro and the one I got from Dell the same thing? Or the PE and the one I got from Dell the same thing? Or is mine just some other thing?
Also, is there any risks in trying to mod my X800 XT?
thanks so much pelikan. i'll try what you suggested. thanks again.
Originally posted by: boodi
so it's like I should expect to see some artifacts ( and what temperature should i look to avoid..? ) before having my card dead , am i right ?
Originally posted by: Ordy
Did my upgrade from a VIVO Radeon X800 Pro to X800 XT PE and have the 16 pipelines and 519 core +560 memory. Glad I found you folks. Was a huge accomplishment for me. I'm always scared to do stuff like this to my hardware.
I ran the 3DMark05 test and got an unbelievable score of 3522!! Quite possibly the best score ever recorded on these forums I know!!! Just kidding of course. Not sure what my score would have been before the flash upgrade to XT PE speeds. I am running an older motherboard and processor to so that's gotta be a reason for the low score.
P4 1.9Ghz
ASUS P4T-E with maximum AGP 4X motherboard
1Gb PC800 RDRAM
ATI Radeon X800 Pro 256 running as Radeon X800 XT PE 256
Windows XP Pro SP2
I had all applications closed when I ran the test. I had the latest drivers from ATI and checked default settings under the Catalyst Control Center. So it looks like my motherboard and processor are the real crippling factors now. Just thought I would post my findings and also post a BIG THANK YOU!!! You folks are grrrrrrreat!
Thanks again,
Ordy
this is good to know
..do you think that tunning the card on a better cooler ( ex. ati silencer 5 cooler ) will avoid damaging an x800pro@pe speeds ?
anyway i saw that really the 6800 has the verge on the x800xt pe many times on games performances ( halo , doom3 , recently i also psotted some half life benchmarks that show 6800 with updated drivers quite on par with x800xt pr high settings >1280*10244 ) and i saw the desktop display quality on this card , it really didn't seem as much bed as I've read around here
so.. I'm quite valuting to sell the zti pro vivo and get the 6800 to not have any kind of issues
