The major uncertainty in the Wells Report scientific analysis lies in the pregame measurement of ball pressures: there were two gauges that differ by approximately 0.4 psi, it is not certain which was used in the pregame measurement, and the data were not recorded. If the pregame measurement of Patriots balls was made with the gauge that gives the higher number (high gauge) – as was the Official’s best recollection – then when you compare the Patriots ball pressures at halftime using the same gauge, you observe that the average Patriots ball pressure drop (1.0 psi) falls precisely in the range predicted by the Ideal Gas Law (1.0 to 1.2 psi) for the temperature differences the balls were thought to experience on game day. In more detail, 8 out of 11 Patriots balls fall within that predicted range, and the three with a larger drop (by 0.1, 0.3 and 0.4 psi) can be explained by measurement error (see below). Further, if the pregame measurements for Colts balls were made with the other (low) gauge then the Colts balls dropped 0.7 psi (only 4 Colts balls were measured at halftime). The smaller drop by 0.3 psi of the Colts balls can have a scientific explanation – they were measured at halftime after the 11 Patriots balls and thus had more time to warm up and increase pressure. Is it possible that the same Official could use one gauge for the Patriots and the other for the Colts measurements? Not only is this possible but it is exactly what happened at halftime. The Wells Report describes a detailed procedure in which each Official used one gauge to measure pressures of 11 Patriots balls first then 4 Colts balls. Only on subsequent data analysis did it become evident that the gauges were inadvertently switched in between measuring the team balls. It is very easy to understand how this could happen because the gauges look almost identical. This could also have occurred for the pregame measurements because the Official who made those measurements owned both gauges and brought them to the stadium. Imagine the Official has a bunch of balls from each of two teams that he has to measure and two gauges that are almost identical, so much so that they were interchanged during the rigid protocol of recording described for halftime.
