Discussion Speculation: Zen 4 (EPYC 4 "Genoa", Ryzen 7000, etc.)
Page 504 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Vattila
822
1,467
Except for the details about the improvements in the microarchitecture, we now know pretty well what to expect with Zen 3.
The leaked presentation by AMD Senior Manager Martin Hilgeman shows that EPYC 3 "Milan" will, as promised and expected, reuse the current platform (SP3), and the system architecture and packaging looks to be the same, with the same 9-die chiplet design and the same maximum core and thread-count (no SMT-4, contrary to rumour). The biggest change revealed so far is the enlargement of the compute complex from 4 cores to 8 cores, all sharing a larger L3 cache ("32+ MB", likely to double to 64 MB, I think).
Hilgeman's slides did also show that EPYC 4 "Genoa" is in the definition phase (or was at the time of the presentation in September, at least), and will come with a new platform (SP5), with new memory support (likely DDR5).
What else do you think we will see with Zen 4? PCI-Express 5 support? Increased core-count? 4-way SMT? New packaging (interposer, 2.5D, 3D)? Integrated memory on package (HBM)?
Vote in the poll and share your thoughts! :)
Reactions: richardllewis_01
BorisTheBlade82
722
1,149
On another note, the 2 IFoP on Zen4c made me think: Either it is just for low CCD count SKUs - simple as that. Or what about some kind of bridge in the CPU base die from IFoP to InFO-RDL for MI300? Any opinions?
Abwx
12,017
4,981
Zen 4 mobile used for DT, although it seems OEM dedicated but those chips are generally available in some retail stores :
Edit, i thought at first that these were APUs, would be great that they also release Phoenix based SKUs for DT...
jpiniero
17,184
7,565
There really isn't a point. The included IGP is more than capable for everything other than gaming. Not to mention it's probally cheaper for AMD to manufacture compared to Phoenix.
They may still release some Phoenix Desktop SKUs eventually if they have excess supply or to dump the IGP busted parts.
Reactions: lightmanek
Abwx
12,017
4,981
Those parts have much better idle power than the regular desktop variants at 8-10W instead of 13-19W, but a 8-12CU IGP would make sense for whom want to build a 620 chipset based ITX DT usable for basic gaming, so far these are only available in OEMs offerings that use BGA parts, so not upgradable with future AM5 SKUs itérations.
eek2121
3,479
5,162
The best I can do on the 9554, 3.48@100 load
According to AMD, the official numbers for the 9554 are base: 3.1, all-core boost: 3.75.
I think you're wrong with your prediction: I do not expect that gap between Zen 5 and Zen 4 would be equally big as it was between Zen 4 and Zen 3 (about 23 months).
I'm expecting that Zen 5 will be released on spring next year, 18-19 months after Zen 4.
I am expecting either a January announcement and March/April release or Computex announcement with a June/July release. They may even try to be silly with a 5/5 release, but I doubt it.
If I had to lean one way or the other I would say Computex for desktop chips, and laptop chips announced in January.
jpiniero
17,184
7,565
AMD's website says they are AM5.
moinmoin
5,248
8,463
Su explicitly mentioned that the IOD in Bergamo is the same as in Genoa, so the Zen 4c CCDs should be fully compatible with the usual CCDs an may well appear in consumer chips as well.
Also called Genoa optimized for performance-per-core and Bergamo optimized for performance-per-watt. Makes it sound like the latter should have been used for Dragon Range, maybe that will still come?
BorisTheBlade82
722
1,149
Surely there might be some people out there ready to pull the trigger for a 32c/64t Mobile Workstation 😉
And as you say, that should be next to no effort for AMD and OEMs, the only limiting factor being supply (as they might sell each CCD in DC for much more).
BorisTheBlade82
722
1,149
Depends how much the combo drop in frequency and L3$ per core offsets the increase in cores overall from 16 to 32.
I would say, even more than for Bergamo vs. Genoa in embarrassingly parallel workloads:
  • Twice the cores instead of 50% more
  • Even further constrained TDP budget
Ofc that is nothing for people who just want to play or have other lightly threaded workloads.
eek2121
3,479
5,162
The 7950X suffers very little going from 170->105w. shoot, at 65W the 7950X is slower, but still spanks a 5950X.
I say that because I don’t think thermal headroom would be an issue. That being said, AMD already indicated long ago that Zen4c was for cloud scenarios and IIRC it was stated at one point that the chiplet would not be coming to desktop.
Likely we will see some future iteration, however.
Geddagod
1,680
1,715
Impressive how Genoa only clocks 200mhz faster than Bergamo despite having way fewer cores. Of course that's assuming power draw is equivalent.
Markfw
May 16, 2002
27,401
16,247
Not sure how this app works, but my 9654 runs 2400-2750 depending on load. The 9554 seems to run at 3.5 no matter what the load, but thats windows. I will have a 9554 linux system also later this week. But its interesting that its running faster than the 9654. I would love to see the 9654 and 9554 ghz speeds here. I don't see it on that link.
Mopetar
8,529
7,795
It's not that surprising. The last 100 MHz always eats up a lot more power than the first 100 MHz.
The extra frequency isn't the killer, but the voltage necessary to drive the chip at that clock speeds while keeping it stable is what does it.
Power = CV[sup]2[/sup]F, where V is the voltage and F is the frequency.
If you only raise or drop the frequency it just increases the power proportional to that. However, the voltage usually rises or falls along with the maximum frequency so a 10% reduction in both voltage and frequency is actually a .9[sup]3[/sup] or ~37% reduction in power. Add in 50% more cores and you're only using 10% more power than originally.
BorisTheBlade82
722
1,149
The 7950X? At 65W? Absolutely. For example, 33k cinebench vs 26k on the 5950x. (vs 38k stock for the 7950x)
These chips were made for low power consumption. AMD just felt the need to blast them with power to compete with Intel.
Just have a look at the Top 10 of the MT PES ranking 😉
BorisTheBlade82
722
1,149
That was to be expected.
The most impressive comparison from the tweet above IMHO is this:
EPYC 9754 128c - 132.5k
EPYC 9654 96c - 94k
That's +41% for only around 70% 5nm area at the same TDP.
Reactions: Tlh97 and moinmoin
