Speculation: Ryzen 4000 series/Zen 3
Page 68 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
tamz_msc
3,865
3,730
BTW Mark Papermaster said that AMD will deliver at least 7% IPC jump each gen. Looks nice but In other words we will wait whole decade until AMD will reach IPC level of today Apple cellphones. And because Apple delivers approx +10-15% IPC every year means that AMD and Intel would need to bring +20% every year to catch Apple's IPC performance in one decade. So if completely new uarch like Zen 3 will bring less than +20% IPC I consider it as fail (in long term fight against ARM). If those leaks about 10-12% IPC are true, that's big fail.
Increasing IPC at a frequency of 4+GHz is much more difficult than doing the same at 2.5 GHz. If AMD can deliver another 15% IPC with Zen 3 then they would have delivered a 15% increase with each generation for two consecutive years. That's equally impressive as ARM delivering 20-25% each year.
Richie Rich
470
230
  1. - Cortex A77 is equal/faster then SkyLake and Zen (IPC)
  2. - Cortex core is delivering bigger IPC jumps than x86
  3. - ARM is increasing clocks while x86 decreasing
  4. - all above combined together means that overall performance increments are much higher for ARM (Appple A13 literally beats Zen2 at 4.6 GHz already today, just look at the picture bellow)
This trend is scary in long term. Problem is also that Zen 3 will need +20% IPC to beat RocketLake/TigerLake. So IMHO +15% IPC for Zen 3 is double fail (in short term with Intel and in long term with ARM/Apple/Nuvia).
tamz_msc
3,865
3,730
You didn't understand what I said, did you? ARM can deliver 20-25% IPC improvement with each generation precisely because they target such low clocks. If they were designed to operate at over 4 GHz, they won't be able to deliver that much IPC improvement with each generation. With that in mind, it puts into perspective AMD's 15% figure.
Richie Rich
470
230
I understood what you said. However there is not much things holds your IPC down at high speed uarch:
  • - for high clock uarch you need pipeline with more stages and shorter (to maximize clock at high voltage).
  • - for low power device like Apple A13 you need the same (more stages and shorter, to minimize voltage at reasonable clock ).... so pipeline is very comparable (A13 has 16? stages, Zen2 has 18-19?). Also we know that Cortex A72 can run at 4 GHz, so those Apples would run around 4 GHz if manufactured with same HP process as x86.
  • - ARMs operates at 2.6 GHz, Zen2 at 4.6 GHz. x86 has clocks +77% however this is not huge difference explaining +82% IPC advantage of A13.
  • - the biggest difference is in memory subsystem, cache, dealing with latency bottleneck due to high clock. However when absolute performace is equal means A13 has to deal with same throughput and latency as Zen2 (low clock advantage is gone).
Please explain your reasons why you think there is difficult achieve high IPC at high clocks. If you look in historical K6 vs. K7 you can see that K6 was 2xALU low clock CPU and more modern K7 was wider 3xALU (much higher IPC) with clocks almost 4x higher (partly from pipeline stage design, partly from better node). IMHO x86 high clocks are due to lowest hanging fruits (its much easier to design simple core at 4 Ghz, than advanced high IPC low power core at 2.6 Ghz).
NTMBK
10,444
5,807
Bananas and oranges is more like CPU and GPU. I don't see any problem to compare performance between two CPUs on different ISAs. If you are company like Amazon and you run your web/SQL servers on for example Linux&MySQL (you have both binary for ARM and x86) then it's very easy for them to compare performance at REAL load. Very easy. They did it and decided create their own server ARM called Graviton. Do you guys really think that Amazon invested huge amount of money into something incomparable? Do you think that people in Amazon don't see that huge +82% IPC advantage delivered by Apple's ARM CPU? Did Apple switched ISA from PowerPC to x86 because it was incomparable?
You'd damn well hope that the ARM chip has higher IPC, it's a RISC architecture. It requires more instructions to perform the same amount of work.
Reactions: Tlh97 and amd6502
soresu
4,115
3,570
That 4 Ghz example was a test chip, I saw nothing to indicate any advantageous power consumption in the news surrounding it.
It's pointless comparing A72 to the Axx cores, they are completely different uArch designs by different engineering teams.
Again, it's about power - it's not "low hanging fruit", it's sheer power consumption.
Zen and Core derivatives perform far more efficiently below 3 Ghz - even 12nm could get you a 45W 8C Zen+ CPU at 2.8 Ghz (2700E).
I'd be interested to see someone do some tests on the 8C Zen2 SKU's underclocked to that 2700E range and see how many watts it pulls on average loads.
Clock frequency was scaled faster than those node improvements allowed for, which is part of the reason we went from passive bulk metal heatsinks with a few thicc fins to active air cooled heat pipe augmented dense packed thin fin heatsinks in just a couple of decades.
What we see as ARM's awesome efficiency triumph is in no small way due to them waiting until much more advanced nodes to really pursue performance once smartphones took off.
Cortex A8 at 1Ghz was at 45nm.
Athlon 1 Ghz was at 250 nm
DrMrLordX
22,907
12,979
Depends on what voltage you give it. I managed to get down to around 1 volt @ 2.8 GHz on a 3900x and it pulled maybe 62W package power. Any voltage lower than that and I started noticing performance degradation. This was running CBR20 MT. Of note: SoC power was around 1/3rd the power budget at this point, probably due in large part to my memory overclock. Prolly could have gotten it to run lower without running DDR4-3733.
And um yeah, of course I'm not running an 8c chip. I estimate that you could knock maybe 15W off the power consumption by dropping four cores. Maybe.
soresu
4,115
3,570
My stock clocked DDR4-2400 sticks whimpered as I read this.
I'm hoping to upgrade straight to DDR5-4800, hopefully it won't impede my performance as much my current RAM on the CPU's of the future.
tamz_msc
3,865
3,730
Because when CPU performance is increased, the miss penalty becomes more significant. A higher performance means lower CPI, which means a greater proportion of time spent on memory stalls. An increased clock rate means that memory stalls account for more CPU cycles. That's why "IPC" increases if you benchmark a program while lowering the peak clock frequency. If you reverse that process, ie. scale frequency upwards, it is imperative that "IPC" would decrease. A 2.5 GHz A77 might be 25% faster than a 2.5 GHz A76, but compare them both at 4 GHz and suddenly the "IPC" gain is a lot less.
mtcn77
105
22
Isn't wider instructions always less efficient due to the wider MUX'es needed to run them natively?
lobz
2,057
2,856
I know you don't, that's why I know better than to waste my time and energy pointlessly arguing with you (about this).
amd6502
971
360
I agree, their pricier high performance cores are on the very newest bleeding edge nodes (giving their products a big efficiency gain and a large transistor budget).
Their budget oriented cores (eg A53, A35, etc https://en.wikipedia.org/wiki/Comparison_of_ARMv8-A_cores) are on trailing edge nodes like 28nm, but they were high efficiency in-order designs. These are sort of reused on new nodes as little cores, giving doubled up efficiency.
If x86 wants to compete in ultra efficient processing (eg tablets/2-in-1s or certain server markets) they will need a way to evaluate threads in a near in-order fashion with very little speculation and running ahead.
IntelUser2000
8,686
3,787
Because you need every part of the core to be synchronous. The faster the clock frequency, the harder it is to reach same perf/clock, because the same circuits need to be driven harder. Not only that, sometimes you need whole different circuitry that's more complex just to do the same thing at lower frequencies.
Intel's Atom-based Goldmont Plus has a L1 cache latency of 3 cycles. Skylake and Icelake is 5 cycles(Skylake is 4 in some corner case scenarios). Goldmont Plus aims for 3GHz, and SKL/ICL for 4-5GHz.
You see, 5 cycles @ 5GHz is same as 3 cycles @ 3GHz.
Same for pipeline stages. A10 had 12-13 stages, and based on clocks, its likely A13 is also at the same level. The Cortex A77 core also has a 13 cycle pipeline. The lowest branch mispredict stage is 10 cycles when you consider its uop cache.
In contrast, Skylake is 18-20 stages, and best case is 14-15 stages when uop cache is considered.
Back when Intel introduced the Pentium 4, some estimated each additional pipeline stage was responsible for 2-5% difference in performance. It's probably closer to 2% than 5%, but it adds up.
Arzachel
903
Apple's cpus are a great example of this, A12 has double both L1 caches of Skylake X and 6x the L2 and targeting higher clockspeeds would require much worse latencies.
NostaSeronx
3,811
1,290
Since, everyone is talking about other stuff might as well...
149 mm2
octo-core CMT
2x32-bit DDR5
4x PCIE 5.0 (GFX)
4x PCIE 5.0? (GPP)
2x SATA or 4x PCIE (STG)
No iGPU
Budget/Essential/Casual Media Socket 1. (AM1 successor)
AMD PIPE PCS with 3rd party PHY for PCIe Gen1/2/3/4/5 <== 5.0
Led feature checkout and enablement for PCIe IP based on PCIe 4.0/5.0 specifications for discrete GPU ASICs with exposure to various PCIe end point and root devices <= 5.0
With that the major thing to pull from this is that Ryzen 4000's X670? might be incoming with PCIe 5.0 w/ RDNA2.
Reactions: amd6502
lobz
2,057
2,856
149 mm2
octo-core CMT
2x32-bit DDR5
4x PCIE 5.0 (GFX)
4x PCIE 5.0? (GPP)
No iGPU
aaaand we're back to fairy tales again...
NostaSeronx
3,811
1,290
PCIe 5 without DDR5? Or are you implying DDR5, too?
DDR4/DDR5 are compatible with each other physically(same pin)/electrically(same pin). So, it is possible that the AM4 X670? will also bring DDR5 DIMMs. With PCIe 5.0 being available w/ the IOD&Mobo refresh.
Reactions: amd6502
A///
4,351
3,160
Right, both are 380 pin and the latter newer contains the vR on the modules as opposed to the mobo. But you run into the issue of the old days when you had mobos supporting DDR2/3. They had limitations as opposed to boards supporting DDR3 or the older modules. You'd still probably need a new pin layout for DDR5, and possibly another one or squeezing in PCIe5. And it's easier to hard launch multiple new feature sets rather than stagger them over multiple generations + a socket change. Another issue is how AMD does releases. 7/7 for 7nm. DDR5 is a go for 2020 with SK Hynix and Samsung promising good stuff at launch as opposed to DDR4's launch. Now assuming a 5/5 launch in 2020 for PCIe5 and DDR5 and USB4, you've only got a lead time of six months until we hear the just before launch of Ryzen 4000. So a 5/5 date doesn't work, unless they utilize the 5/5 date launch for Milan, which makes sense as AMD plans on releasing Milan months ahead of Ryzen 4000. Otherwise you go to 2021 which allows the following:
AM5 Socket
DDR5
USB4
PCIe 5.0
5/5 release
This would give AMD enough time to work with their vendors and deliver a solid product launch. AMD's problem is their launches aren't very good. And often quite buggy. 2-3 years of bad launches vs one large launch that gets cleared up in a few months is a lot easier to swallow than 2-3 years of bad ones that will leave a bad taste in customers' mouths. Anyway, you do bring up a reasonable suggestion as to why. It's a lot easier to take in than some of the wild theories people have come up with.
I'm going to stay out of the 4SMT discussion on the basis I haven't had to read the Hennessy books in over a decade. Anything I learned then is severely outdated let alone been in a fabrication plant.
Veradun
564
780
AM5 Socket
DDR5
USB4
PCIe 5.0
5/5 release
I want to casually point out that 5nm, PCIe5, DDR5, AM5 would fit nicely on a 5/5/2021 launch date. Note that 2021->2+0+2+1=5 :D
soresu
4,115
3,570
Only if Zen7 comes on a seventh day of the seventh month at 7AM!
Edit:
Zen6 could come in 2023 when PCIe 6 might be due!
666 - the Red Devil cometh!
Reactions: lightmanek and OTG
Richie Rich
470
230
And this test chip proved that A72 is capable to run at 4 GHz if it's manufactured on HP process and rise the voltage. And Apple's A13 could run at 4 GHz too if manufactured same way. This comparison is very useful when you know how CPU stages work. Doesn't matter how many stages CPU has (useful but might be misleading) because more important is how many transistors contain the critical path chain. Signal velocity propagation across this critical path for every stage is known value called transistor characteristic (freq/voltage curve). Thanks to this we can indirectly compare how short (fast) all stages in pipeline are. For example if A72 runs at 2.5 GHz @ 0.7V and A12 at 2.5 GHz need same 0.7V this basically means their stage lenghts are very similar (no matter how many stages in total core are). Similar stage length means similar scaling to 4 GHz also for Apple CPUs. That's physics.
It looks like you don't want to understand. If TDP limit for desktop CPU is typically 65-105W then Intel and AMD have very different design constrains than ARM chips with TDP 4W. And very different low hanging fruits too. For such a high TDP is higher frequency (by rising voltage to 1.3V) very simple way how to rise performance (+77% 3950X). Frequency is low hanging fruits for x86 desktop. Apple's mobile chips cannot waste such a energy so they have to go the hardest way - by increasing IPC. However the hardest way always pays dividends (same in real life with training and learning) and Apple ends up with the most advanced CPU core on the world with massive +82% IPC advantage over Zen 2.
Apple's A13 is beating very fine binned Ryzen 9 3950X @ 4.7 GHz. If you would set Zen2 at clock every chip is capable of (like A13 is) then it would be somewhere around 4.2 Ghz.... and A13 would win over Zen 2 with higher margin. 64-core EPYC with TDP 280W (4.4W/core at 2.5 GHz) looks very competitive with A13 (5W/core @2.6 Ghz). Until you realize A13 has a massive +82% IPC advantage. EPYC would need more than 1000W TDP to be able to run at 4Ghz and be still slower than A13@2.6 GHz. I tell you guys Nuvia server chip with IPC like A13 would be total killer for most x86 server world today. AMD needs +25% IPC jump every year to stay competitive against Nuvia on 2024. That's why Zen3 must be something very good. Much better than leaks suggests. If +12% INT IPC gain is correct for Zen3 then AMD will fall into mediocrity again (same as K10.5/Barcelona/Thuban age).
Nice argument and I agree with that. However when you take Apple's A13 instead Atom there is same level of absolute performance as SKL. Just achieved at much lower clock. This means A13 core has to deal with same amount of instructions per time as SKL@4.5 GHz..... this means both cores (A13 and SKL) suffer with same latency issues. So memory and cache system is probably very similar for both cores.
But the main question was whether there is any hard obsticle to design very wide 6xALU core operating at high clock as SKL. There isn't. Yes, it would need good cache system and yes, it would suffer at some type of code still. But look at Apple how they handled it. Their first 6xALU core A11 Monsoon was faster than their last 4xALU core A10 Hurricane but not as you would suggest from +50% ALU increase. Apple kept working hard on cache and memory system with A12 and A13 and finally got great IPC. The old good receipt for success is also my wish for everybody here into new year of 2020: much success through hard work, no excuses.
soresu
4,115
3,570
AMD will not fall into mediocrity unless they manage to fall far behind Intel when they should be in the lead.
The ARM server/desktop market may certainly grow in the future, but it's not going to displace x86 significantly anytime soon.
Besides which, by 2024 Nuvia will have competition from ARM themselves inevitably, A78 is due in May and we will probably still see a new core every year from ARM
It's easier to just write K10 age (or Stars using the desktop codenames).
You somehow managed to use 3 different variants of codenames in differing generations of it there.
K10.5 is the second gen core, Barcelona is the first gen server SKU (Agena is the desktop variant also affected by TLB errata), Thuban is the desktop SKU for K10.6/third gen core/6 core monolithic.
I get testy about the K10 comment because I had a Phenom II X4, it was a great chip for much better value than the Intel product on the market.
Bulldozer was mediocrity, K10 was just second best of it's generation, but a good second best well worth buying at the time.
The most advanced CPU core? Arguable to say the least with the likes of A64FX knocking around now with 512 bit SVE - there's more to being advanced than great scalar IPC.
Remember that for all that vaunted scalar oomph, Axx cores are currently crippled in the SIMD arena when comparing to x86 Zen and Core competitors.
Apple also lacks the software on any iOS platform that compares to x86 systems using MacOS, Windows or Linux - all that awesome IPC is as useful as a paperweight for most serious work outside the new Photoshop iOS release.
