Speculation: Ryzen 4000 series/Zen 3
Page 117 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Well, some new OPNs showed up for Vermeer/Ryzen4000
Slight clock bumps, 200 MHz Base while Boost remain the same which if AMD learnt from its fiasco with Zen2 should be a more sustainable boost.
BTW these are A0 samples, things could still change(improve?)
One interesting observation by Igor
This could impact latency positively. (aside of the downside of the lack of BC for non X570 boards)
Wowza!
They are hitting those clocks on A0! 😱
Bobcat anyone???!!!
"AMD's updates also mark the end of the line for 400-series motherboards: AMD will not support future processors on the platform. The company also confirmed that Ryzen 4000 will land this year. "
The way this is worded makes it sound like the 500 series will see cpu's after Zen 3
No Marketing
AMD - AM4 will not support any more future CPU releases after ZEN 3
Marketing
AMD - 400 cheapset will not support any more future CPU releases after ZEN 3
Same thing but they need to sell B550 and X570 for now 😉
Bobcat anyone???!!!
Could you please explain?
I had many friends with the socket 7 and socket A cpus where they put cpus that the boards didn't say it supports and the cpu worked just fine.
I think official support and support is two different things, just looking at this anandtech chart we can see that according to them the A320 doesn't work with zen2 cpus and it works perfectly fine:
It has nothing to do with motherboards.
I was refering to bobcat CPU. It went to market as A0 stepping. That was unheard of in semiconductor industry. Or at least as rare as chicken teeth.
Sorry for the confusion.
Edit: Bobcat was also low power core and Zen is high performance core which is even more impressive. It is actually crazy impressive.
Very good clocks for early silicon, and if the IPC really improved 10-15% than Sunny Cove shouldn't be a threat, right?
I'm curious, the improvement to cache a latency that people keep talking, it's something in like with the improvement in core communication latency seems on the current Zen 2 mobile? Or even better? Is this even possible? ( think it's around 10-20ns better than in the Zen 2 desktop)
That was a different time. At that time you get not needed the most basic of code for a single chip and the chip itself would handle specific. A Tbird 700 would only difference with a Tbird 900 by connections established on the packaging (look up pencil trick). A socket might only need microcode for 2-3 much simpler chips.
Now there are so many variations that have to be covered. The full CPU has to be identified for defualt clocks, turbo, in AMDs case PSP, and the full chip name value (to fight counterfeiting).
Why do I feel like we've been baited? Remember AMD cutting the price of Navi at launch by $50?
It's possible, but I don't really think that is something their marketing department intended to happen. They usually stick to the "harass Intel" strategy as of late.
That $50 price cut at launch was just a last-minute course correction to slot their Navi cards in just right. AMD needed to get as much profit as possible out of Navi in order to atone for some of the financial performance of previous Radeon products, so that meant a last-minute price adjustment. Price your cards too low and you are leaving money on the table. Price them too high and you won't move enough volume to keep shareholders happy.
I made the confusion, should have made two posts.
Aah, no biggie.
Didn't know about that, it seams amd works very well with tsmc.
It was almost decade ago on 40nm proccess. I have almost forgot about it.
And yes, they certainly both have top class engineers. You don't produce this results by sheer luck.
I cannot express how much I am impressed.
No Marketing
Marketing
I thnk it's not exactly just a marketing. I fully expect future AMD APU's based on Zen 3 core to still work on AM4 500 series boards but will not be supported on older chipsets.
Not if they are released on AM5. They are coming out in 2021 AFAIK, if true, then AMD is free of it's promise anyway.
Yeah, given the staggered launch cycles of APUs and CPUs there will need to be a break somewhere - either the 5000 series is split across both AM4 (APUs) and AM5 (CPUs) or Zen 3 is split in the opposite way. I would say the former is far less likely than the latter simply as having parts nominally in the same series that use different sockets and are entirely incompatible would be extremely confusing for everyone. In addition to that APUs have far more to gain than CPUs from DDR5, so they would be a logical first launch for a DDR5 platform (even if that comes with the drawback of an early controller with all the issues that brings with it).
And the price tag for the new ram on a lower tier product
Not denying that, as it is entirely possible, but I remember reading or watching a report stating AMD plans DDR5 platforms for 2022 earliest. If that's the case, we will have one more round of APU's on DDR4 platform for sure.
ASMedia is the manufacturer of AMD's B550 and A520 chipsets, which are set to launch in June and September 2020, respectively, the sources said. AMD's Ryzen 4000 series CPUs are scheduled to become available at the end of the third quarter or early fourth-quarter 2020, supporting only B550 and X570 chipsets. ASMedia has also recently landed orders from AMD for its 600 series chipsets that is scheduled for the end of 2020, the sources said.
Well next quarter its going to be then.
Also ASMedia's record orders from AMD. Somebody is dreaming BIG.
ASMedia's gross margin, operating profit margin and net profit margin all achieved new records in the first quarter thanks to strong orders from AMD, the sources said. As AMD is set to unveil its new platform and may see market share rise further later in 2020, ASMedia expects its financial results for the second quarter and whole-year 2020 to both reach new heights, the sources added.
Hopefully we get and APU with at least 14 CU on DDR 5. I also hope AMD gets their APU processors out around the same time as the non APU processors since they no longer have to utilize Global Foundaries.
No chance since that would mean delaying the non-APU processors. AMD first finishes the cores and uncore/package/platform, and then builds a mobile optimized APU from the building blocks of that.
While I would love that, I find it relatively unlikely as it would require AMD to bet on the market viability of a very large die SoC (Renoir with Vega 8 is already quite large, so unless there are dramatic density improvements from 5nm anything with 14 RDNA CUs would be very large) - unless of course MCM APUs are feasible at that point. That would of course be the ideal scenario, as they could pair an already existing CCD and possibly even reuse a low-end dGPU die for the iGPU as long as it's small enough to fit on the package, which could give us a lot more than 14 CUs (though likely at low clocks to avoid burning our motherboards). But without MCM APUs I doubt we'll see that big an increase.
Damn, June for B550 - must have missed this. The missus needs a new computer and I wanted to do a 550 build 🙁
