Speculation: Ryzen 4000 series/Zen 3
Page 109 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
mopardude87
3,348
1,576
I think it is safe to say that we will not see RDNA1 in any AMD APU, this generation or the next.
Shame so even with the 5000 series and perhaps ddr5 we won't have such a option? I think 5000 may have ddr5? Barely wrapping my head around the 3900x that is coming quite later this evening then expected, then the idea 4000 series may be another good drop in replacement then we got the 5000 series next year or 2022 at latest? So much excitement in so little time!
lobz
2,057
2,856
5000 series APUs (Zen 3) won't have DDR5 yet. Also he only meant RDNA1, ergo the next APU will either have a further optimized Vega or already RDNA2.
Reactions: Olikan
mopardude87
3,348
1,576
Shame, i think it would be a absolute beast if it did. Well whatever APU ends up landing with DDR5 will be epic i think. I haven't followed Apus in a while but i got a friend who loves to run BOINC who is obsessed with them. MY htpc is turning into a 2500k/1070/1650 super before year is out so i got no need really for one myself.
soresu
4,232
3,724
If It won't happen then there is no reason to have more than 6-8CU RDNA2 or It will be bandwidth starved based on bandwidth of RDNA1 chips.
Do you mean quoted spec bandwidth or the actual bandwidth typically in use?
Because the 2 need not be the same thing, especially at lower resolutions.
Shivansps
3,918
1,570
LPDDR5 is already in some phones so the next APU planned for next year could(should) have support for LPDDR5. If It won't happen then there is no reason to have more than 6-8CU RDNA2 or It will be bandwidth starved based on bandwidth of RDNA1 chips.
That what i was thinking as well, anything that comes after Renoir will most likely have LPDDR5/DDR5 and probably be the first AMD Desktop DDR5/AM5 product. Maybe launching next year in notebooks and early 2022 in desktop.
Gideon
2,043
5,096
LPDDR5 and DDR5 are different enough that supporting one doesn't mean they will automatically support the other. Seriously, the name might be similar but "DDR5" is to "LPDDR5" what "car" is to "carpet".
I'm more than willing to believe they'll support LPDDR5. It would be nice if they'd also support DDR5, but considering that the standard still isn't finalised, I wouldn't be holding my breath ...
amrnuke
1,181
1,772
If they support LPDDR5 on Cezanne and exploit it, that means IF is going to need to be much faster, IIRC.
Is that's what AMD were getting on about with their Infinity Architecture? If so, this is something that may help close the inter-core and system RAM latency issues a bit even on Vermeer.
Valantar
1,792
508
If you are alluding to the link between IF clock and DRAM clock those two are entirely decoupled in Renoir (partly for efficiency and likely partly to allow for faster LPDDR4X). I don't see any reason why they would go back on this even though different clocks between DRAM and IF has some performance implications.
tamz_msc
3,865
3,730
They might be decoupled but there is still a limit to how high IF can clock in 1:1 mode, and 4266 MHz LPDDR4x doesn't actually run the IF at 2133 MHz - it runs at 1:2 mode at that speed.
NostaSeronx
3,815
1,294
Renoir doesn't appear to have a 1:1 mode.
.dram_speed_mts = 1600.0 => .fabricclk_mhz = 600.0
.dram_speed_mts = 2133.0 => .fabricclk_mhz = 1066.0
.dram_speed_mts = 4266.0 => .fabricclk_mhz = 1600.0
If it does follow the ratio at most it will be 2:1 and never 1:1 natively.
To support LPDDR5-6400 and keep the same ratio as the 1600/600 and 4266/1600 the fabric clock in Cezanne will need to be able to reach 2400. Which would also be enough to support DDR5-4800 at 2:1, and DDR5-6400 at ~2.66:1.
DrMrLordX
23,159
13,254
Some boards will probably get UEFI updates to support Zen3. Expect some headaches or lost CPU support to accommodate firmware ROM size limitations.
uzzi38
2,747
6,657
Yes it does, what are you on about?
1:1 mode is supported until:
DDR4-2666mhz on RNR-U
DDR4-3200 on RNR-H
moinmoin
5,248
8,463
Living under a rock? AMD said today that x370 and x470 motherboards are not supported.
I'd think it's "not supported" as in "not required" and up to the BIOS support by the motherboard manufacturers. After all we do have 300 series motherboards compatible with Ryzen 3000 chips even though AMD's chart states the opposite:
amrnuke
1,181
1,772
One of those slides shows Ryzen 3000 series not being supported on 300 series motherboards too, so perhaps don't read too much into it.
It's official support. I know the mobo manufacturers can work around it as they have for 300 series and Zen2, but it's a bit of a blow to those of us who would like to rely on some warrantied-ish ability to use a 4700X on a B450 for instance.
