Speculation: Ryzen 4000 series/Zen 3
Page 110 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Valantar
1,792
508
They might be decoupled but there is still a limit to how high IF can clock in 1:1 mode, and 4266 MHz LPDDR4x doesn't actually run the IF at 2133 MHz - it runs at 1:2 mode at that speed.
Decoupled means decoupled, as in "not connected". As such the "ratio" for Renoir only exists in that any two numbers can be made into a ratio. Renoir as such never runs at a 1:1 ratio as there is no such mechanism in place in the system. Renoir can scale its IF clock up/down entirely unrelated to DRAM clock. This is necessary to support IF power saving alongside DDR4 (which doesn't vary its clock speed whatsoever) and LPDDR4X (which varies its clock speed, but goes far too high for IF to follow suit reliably - 1:1 goes to 3600-3800 (1800-1900 FCLOCK) on a good desktop chip, so 4233 (2133 FCLOCK) isn't happening). The issue is that mismatched speeds introduces latency in the data path as a signal coming from one bus moves onto the other, causing performance inconsistency - but obviously not enough for it to seriously hamper Renoir. And who knows, maybe hitting 3:1 around (~4800) with (LP)DDR5 will be better than some weird non-integer ratio?
Shivansps
3,918
1,570
Personally i belive that if the CPU is not EOL and there is no technnical issues, support MUST be given, And the fact is APU 3000s and CPU 2000s arent EOL... there is no excuses for having worse compatibility than X570... Ryzen 1000 and APU 2000 are EOL so i can accept that.
What will likely happen is that OEM will support everything just to avoid this confusing mess, but AMD had no reason to drop support like this.
CHADBOGA
2,135
833
I wonder if PCI 4 is what may cause the OEM's to not offer the support for Ryzen 4000, as they did for Ryzen 3000?
DrMrLordX
23,157
13,250
Some of the older boards have large firmware ROMs. Thoes are the ones most-likely to have support for Zen3.
Yes you've been very clear about that. Many, many times.
I think we won't see beta UEFI revisions that try to support it like we did prior to the Matisse launch.
maddie
5,193
5,591
I suppose you can always write a bios that removes support for Zen1. Not good for new sales however.
Reactions: RadiclDreamer
DrMrLordX
23,157
13,250
There were some OEMs that did that already for Zen2. Or at least they removed support for Raven Ridge in some cases.
Avalon
7,571
178
Yeah, for my Gigabyte X370 Gaming K3 board, they removed support for Bristol Ridge to be able to accept Zen 2 3000 series processors. Gives me a bit of hope that they'll be able to update further to support the Zen 3 4000 series. I'm still rocking my trusty Ryzen 5 1600, so at some point later this year it's going to come down to a decision of....can I drop in a Zen 3, do I just drop in a Zen 2 3000 series chip, or do I get a new motherboard and Zen 3?
DrMrLordX
23,157
13,250
@Avalon
I expect them to kill support for Bristol Ridge, Raven Ridge, and Picasso first, depending on the board. Maybe Summit Ridge as well. x570 already doesn't support Raven; Bristol; or Summit Ridge, so they may knock off Picasso and Pinnacle Ridge.
Valantar
1,792
508
@Thibsie
News to me. Looks like they're holding back AM4 Renoir for the Vermeer launch.
... Or they are going forward exactly like they did last year with no word on desktop APUs until after the summer despite laptop ones being announced at CES. If Vermeer doesn't launch until late Q3 or even Q4 there is little reason to think APUs will be held back until then (unless they are facing very serious production shortages (which there shouldn't be now that Apple has left TSMC's 7nm node) and laptop demand is absolutely overwhelming).
DrMrLordX
23,157
13,250
Vermeer should coincide with the B550 launch. At this point it's looking like July-September, and the pessimist in me is thinking September.
soresu
4,222
3,699
It makes sense to hold back on desktop APU's so that they can press the advantage Renoir has at present by concentrating on laptop.
Reactions: Tlh97 and Thibsie
soresu
4,222
3,699
Another 4-5 months for an already long overdue product? Ouch.
I'm not sure this is the case though, as they discussed B550 being Zen3 compatible, but not at the moment BIOS wise - which implies to me that it is currently being readied for deploying on cheaper Matisse rigs now that their cheaper Matisse variants have been announced with 3100 and 3300X.
DrMrLordX
23,157
13,250
@soresu
Hey if they want to launch B550 early let them, I have no problem with that. I don't think they've done that before except with A320 (which launched maybe 6 months before Ryzen).
Reactions: Tlh97 and soresu
Valantar
1,792
508
@soresu
Given that B550 "technically" launched yesterday (though no boards have been announced yet) it would be utterly unheard of for boards to not arrive until late Q3 or Q4 alongside Vermeer. I would expect B550 boards to trickle out as summer arrives, with the weird launch likely being due to various OEMs being hit by Covid-19 in different ways, necessitating a weird, staggered paper launch.
I agree that it makes some sense, but considering how small the consumer desktop APU market is the impact of allocating a few thousand dice to the desktop would be minimal. A quick and dirty dice-per-wafer calculation based on Anandtech's measurements gives ~384 total Renoir dice per 300mm wafer (including defects), so they really don't need to set aside many wafers to cover initial global consumer desktop APU demand should they want to appear as if they care about this market. Not to mention that desktop APUs could use chips that are otherwise too power hungry to fit 15W or 45W mobile bins. After all, these chips have been in mass production since late '19 so even if the roll-out in laptops is slow, that doesn't mean AMD doesn't have a significant stock of chips.
jpiniero
17,063
7,465
For DIY it is small, but very much not as a whole. Getting OEMs to use AMD's APUs is another story. And they have shown they are fine with using mobile parts.
Valantar
1,792
508
As I said above, while that does happen, it isn't common, and it's more expensive and less flexible for OEMs - so they tend to avoid it if possible in normal form factors. But I was talking specifically DIY consumer sales, not OEM sales (of course OEM SFF like the tiny Dells and Lenovos out there universally use laptop parts, but those also rely exclusively on bespoke motherboards and generally don't have PCIe expansion). I doubt there's enough of a market for consumer facing OEM dekstops based on APUs (or enough attention paid to them) that AMD would prioritize those over the rather loud DIY market for something like this.
DrMrLordX
23,157
13,250
@Valantar
Q3 is only 2 months from now (July). If B550 launches in July, you think that would be abnormal? Granted, it was supposed to be out in July of LAST year, but we all know why that didn't happen . . .
coercitiv
7,448
17,757
jpiniero
17,063
7,465
Hmm, was thinking about it, AMD's probably raising prices on Zen 3 at same core counts. Could just slide the Renior AM4 APUs into the same price points as Matisse and release it right around when Vermeer launches.
Valantar
1,792
508
@Valantar
Isn't it pretty much confirmed at this point that Vermeer is slated for an "end of 2020" release? If that falls within Q3, it definitely isn't July - I would be very surprised even if we saw Vermeer launched in September. AMD's desktop CPU release cadence so far has been a year and a few months, so unless Zen 3 is arriving significantly faster than previous generations it won't be here until fall at the earliest, though late fall or "holiday" is more likely IMO. Thus I would assume desktop Renoir arrives first, possibly alongside (or more likely during the slow trickle out of) B550.
DrMrLordX
23,157
13,250
Nothing's really confirmed. AMD is staying pretty quiet. We have seen fewer ESes floating around for Vermeer than we did Matisse. It's all very secretive. I would think September would be more-likely for Vermeer than anything else, but that's just a guess. I could see B550 in July and Vermeer in September.
DisEnchantment
1,779
6,798
I am not aware of any Zen3 ES let alone Vermeer ES thus far. In Contrast, Zen2 ES were common almost 8 months before launch.
They stated that they have been sampling since Q4 last year. But till now not even a part number anywhere. Nothing.
If they are this quiet it must be very good. Can't imagine otherwise. Looking at the 3100 vs 3300X comparison, just having a unified cache raised "IPC" considerably. Optimize some DRAM latency. Just like that, IPC will improve without touching the core.
From HarwardeNumber3rs testing, increasing frequency does not do much for Zen2, so I guess that was the reason they did not bother much with it. In fact would have been negative PR with higher frequency.
I still believe they will be on track for late Q3 this year at the latest just like they stated on their slide from last Nov (Also confirmed from the NERSC PR). Probably earlier for Desktop.
Otherwise it is going to be almost TWO years from tapeout to Launch and one year from sampling to launch. That is nuts. That is way too long.
Reactions: Tlh97
